Old 12-09-2006, 02:06 PM   #1 (permalink)
injector instructions
Hey folks. I just got my DIY kit today for my injectors and would like for someone to point me to a post with instructions for R and R of the injectors.Thanks.
95 f350 powerstroke crewcab 4x4. 4" exhaust 5" tip . Tony wildman chip,no cat. Tymar intake.Autometer guages,pillar mount.FPR shimmmed,160cc injectors.Superduty intercooler. 4.10 gears. Detroit Truetracs front and rear. Idm modded. Airlift 57215 airbags in rear.Sky RSK with Superlift 4 inch lift in back and V codes up front.Homemade 6 foot traction bars.
oldblue31 is offline
Old 12-09-2006, 02:56 PM   #2 (permalink)
maloney's Avatar
Re: injector instructions
this helped me
http://www.beansdieselperformance.co...torinstall.htm
-Black 1997 F-250 4X4 regular cab
-K&N intake/filter
-stainless Bully Dog 3" down pipe and 4" exhaust
-Tony Wildman chip
-Beans Stage I injectors
-Tru-Cool 4739 MAX transmission cooler
-A-pillar with Autometer gauges boost/trans/pyro
-Donaldson semi-truck oil filter
-John Deere coolant eye (thanks deeretrac)
-Bronco rear fuel tank (33 gal)
-Fuel tank vent mod
-150,000 miles
maloney is offline
Old 12-10-2006, 12:02 AM   #3 (permalink)
I might as well change out my glow plugs while I am there .What are the best to use?
Old 12-10-2006, 12:17 AM   #4 (permalink)
AlaskaRedneK's Avatar
Go down to your International dealer and get them there.
What size DIY's did you get?
Best of Luck [img]/ubbthreads/images/graemlins/smokin.gif[/img]
-Stouff
'97 F-350 CC/LB 7.3L PSD 4x4 4.10's, ~111K miles/ 3-4" Down Pipe hooked to 5" Turnout Stacks, Isspro EV Guages, Tymar, 6 pos. Northern Diesel Performance TS Chip, 7.3 IC, gutted stock fan- w/ single electric fan, Stage 3 DIY Hybrids
In the garage: RacerX Tranny kit, headstuds, 910s, pushrods
Next: New TW tunes!
AlaskaRedneK is offline
Old 12-10-2006, 12:45 AM   #5 (permalink)
KRP
Autozone also carries/stocks the Motorcraft GPs for about $8 each. You can check the GPs with an ohmeter to see if they are still good.
2000 F-250 Ex.Cab 4x4 Auto with Homemade Intake, 4" Exhaust, DP Tuner Chip, Tugger Kit, 2 HPOPs, ITP Fuel System/Boost Regulator, AC injectors, and Van Turbo/WW
KRP is offline
Old 12-11-2006, 12:08 PM   #6 (permalink)
I got the stage 1's.How do I check the glow plugs?
Old 12-11-2006, 02:49 PM   #7 (permalink)
PSDfreak's Avatar
If you have the VC's off I would go ahead and just do it. You'll take the GP's out anyway to evacuate the cylinder of any oil or fuel...you're really better off just doing it now than having the do it again later.
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 12-11-2006, 07:46 PM   #8 (permalink)
Like PSD said, pull the GPs out first to help with the oil evac during the injector install.
I put each one lightly into a vise to ground it, then I used a multimeter set to ohms and touched the harness plug end of it. Less than 1 ohm is what you want; with the exception of one, mine checked out at .6 to .7 ohms.
I just successfully did the injector/GP job last weekend with no issues. Take your time and you'll be fine.
Good luck--
Mike
94 F250 SC, 4x4, 5spd, 4.10ls, LuK, Toyo Country AT 285/16s, 190K, edge evo, shimmed FPR, Bilsteins, Add-a-leaf, 3"DP/4" exh, new ACs, ISSPRO, Term. 17* HPOP, pedestal mod, Tymar Intake and HPX, IDM and CCV mods
335HP, 716TQ (3-08)
mandkole is offline
Old 12-11-2006, 07:56 PM   #9 (permalink)
Nit
I normally go ahead and replace all of them , hell you have to take them out anyways.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 12-11-2006, 10:48 PM   #10 (permalink)
Well, I got all of the glow plugs out and even bought new ones and decided to check resistance on the old and new ones.Everyone of them checks out at 1.2 ohms.So should I return the new ones and get the 75 bucks back or go on and put em in?By the way i am having a hard time finding a machine shop in my raea that can mill these injector intensifier pistons.I am gonna try the tech colege tomorrow.
Old 12-11-2006, 11:17 PM   #11 (permalink)
Mine were OK after 35K but I bought new ones; $75 insurance...
335HP, 716TQ (3-08)
mandkole is offline
Old 12-11-2006, 11:22 PM   #12 (permalink)
i guess they could go at anytime huh? Those valve covers ain't near as easy to remove as the ones off of my 390 either.
Old 12-12-2006, 12:28 AM   #13 (permalink)
If I remember right if it reads < .6 Ohms they are good anything higher should be replaced...? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
-Stouff
Next: New TW tunes!
Old 12-12-2006, 01:36 AM   #14 (permalink)
Nit
na, maybe your ohm meter is jsut off, if they all read the same tehn there is nothign wrong with them.
pictures
dirty30
Nit is offline
Old 12-12-2006, 12:00 PM   #15 (permalink)
the rubber boots inside the connectors on most of my injectors are missing.is this gonna cause a problem and if so are they available anywhere?
