Old 05-17-2005, 05:07 PM   #1 (permalink)
Injector questions
Ive been looking through the forum and have found many posts talking about problems with stage 1 injectors? But not wat the actual problem is. I was wondering what it is and what you can do to fix it? Also, what are the best ones to run with say a 4in exhaust, an intake, and an intercooler?
1995 Ford F-250 7.3L 5spd Std. Cab- My "Mods"-
4 Stickers, Fuzzy Dice, Leather Steering Wheel Cover, and AIC Pedal Covers. LOl. Go Fast mods ASAP
StncldCrzy663 is offline
Old 05-17-2005, 05:43 PM   #2 (permalink)
sea97stroker's Avatar
Re: Injector questions
[img]/ubbthreads/images/graemlins/biggrin.gif[/img]
1997 F350 CC 5 Speed 4x4 , BDP Stage 2's, Wildman Chip, Isspro Gauges, 5 inch stacks, SD Turbo Setup,Banks Intercooler,Tymar Intake, SD Leather Seats. Dyno 427hp/813tq
www.BeansDieselPerformance.com
sea97stroker is offline
Old 05-17-2005, 05:59 PM   #3 (permalink)
I don't recall a LOT of people having problems with the stage 1's, I know of one forum member that recently had trouble with his, but I think it was an isolated incident [img]/ubbthreads/images/graemlins/shrug.gif[/img]. I know most of us who got Beans stage1's haven't had any problems at all with them...............Dave
Dave
11
#3
FOREVER THE MAN
LEGENDS NEVER DIE
1997 F350 CC DRW 4X4, Black. Centaurus2 conversion. Banks IC & powdercoated tubes. Stage 2's by Full Force Performance,BDP Dom 66, BDP Fuel system , TS 6 pos chip with Bills & T Wildmans burns, AFE intake, 4" exhaust. Gear Vendor Overdrive. E4OD with Suncoast Pro-Loc TC, 4.10 gears. Sky's RSK, Kelderman air ride, Bilsteins, 40 gal Transfer Flow. Alcoa's. Pioneer stereo, full floor and overhead console.
As of now 391 & 740, Going for 400
pictures > http://community.webshots.com/slides...986&key=uYblzs
97Strokerman is offline
Old 05-17-2005, 06:09 PM   #4 (permalink)
no problems with mine, as mentioned above i can only think of one "problem". which was taken care of very professionaly. [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/cool.gif[/img]
<span style="color: #FF0000">#18</span> not all trucks are created equal
THE COWBOY'S CADILLAC,<span style="color: #FF0000">my pics.</span>, 96 F-350 XLT SC DRW PSD, 4x4 conversion(D60),more oil than you, auto tranny by faubion motorsports, tuned by a backwoods hack(thanks tony), 230cc injectors, D66 turbo, head studs, 910 valvesprings, open element intake, homebuilt fuel system, 3-4"DP, intercooler with homemade spider and piping, 5" chrome stacks with turnouts, front hitch(for my weight bar), member of the <span style="color: #FF0000">WNYPA</span>
on the way: more power
bullridin_fool is offline
Old 05-17-2005, 06:22 PM   #5 (permalink)
ThreeStarJR's Avatar
Partner, you are going to have to link the threads that are showing the problems with the stage 1's, there are a BUNCH of us that are absolutely thrilled with the performance gains we have achieved with these economy priced MASSIVE horsepower gainers! Not only that,we are also thrilled to have the backup information source of Ryan Bean and cass (the stout one) [img]/ubbthreads/images/graemlins/biggrin.gif[/img] in the real world of retail you buy it, it don't work, its yours...with BDS they go to end of the world to help you with problems that you may already have and the new injectors are making those problems show up...Of all the money I have spent for upgrades, the money spent on the stage 1's was my best money spent....nuff said, I'm off my soap box....
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Wildman Tunes
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
play it loud!
#3
ThreeStarJR is offline
Old 05-17-2005, 06:34 PM   #6 (permalink)
NO problems here !!! Unless your the E4OD behind them [img]/ubbthreads/images/graemlins/eek.gif[/img]. I'm very pleased with the performance of my stage I's. Actually the only trouble I had was getting it fired back up. Make sure you have a good set of batteries, AND a set of jumper cables when they start getting low. The job itself was actually quite easy. The usual story, the hardest part of the job was screwing up the courage to start taking it apart. If you have any questions in that department, you'll find all the answers you need here.
Chris
1997 F-350 CC PSD 4X4/4" Softride/Weld Super Singles/35X12.5 BFG MT's/RS 9000's/Hypermax downtube/300MAX chip/Bean's stage I injectors/4" straight pipe/EBPV guts removed/shimmed/Auto Meter Pro Comp pyro & trany temp guage/exposed K&N cone/52,000 lb. trany cooler/tricumulator springs/sonnax valve/4.10's
"Horsepower is like hamburger, you can buy as MUCH as you want",
"If cool were cheap, everybody would be"
1997Crewbus is offline
Old 05-17-2005, 06:37 PM   #7 (permalink)
Banned
Both sets of BDP injectors ive had good luck with. Stage 1's i had for 6k miles and upgraded to stage 2's, i already have 4.5k miles on them [img]/ubbthreads/images/graemlins/grin.gif[/img]. I did have a bad idle with stage 2's, did a cct and found 3 injectors not funtioning right, Bean sent 3 more and took care of it asap.
The only mechanical problem ive had was poor hpo bc of a weak pump. I replaced it with a pump from a 2002 and it will hold 2500 psi with the stage 2s.
luke
lukecline is offline
Old 05-17-2005, 07:03 PM   #8 (permalink)
Luke, first time I have seen your numbers of HP/tq...maybe I wasn't paying attention.... [img]/ubbthreads/images/graemlins/eek.gif[/img] "WOW" your are making some serious power, how is the daily drivability? I am very happy with the 160's, but with the boost I'm making with what I have, I'm concerned with the stock turbo not living....I think I'm experiencing turbo "flutter", which according to the SD guys, is a serious problem, I want to step up to a better hpop to give the stage 1's every thing they need, but I'm afraid the turbo can't handle it...any incite?
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP Fuel system
Wildman Tunes
Caltracs
play it loud!
#3
