1996 crew cab 4x4 black psd BDP 250cc hyrbids BDP fuel system Stealthhinator dual ipr hpop
H2E TDP tuning 515hp 1158tq
99.5 psd reg cab 2wd
334hp 740tq
rdrcm #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke Truck and misc pics
bdp looks like the favorite i think stage 2 would work did any body stay with stock fuel pump or should guy get bigger one
does guy need to get hpop for stage 2??
any tranny upgrade should be done ??
5 spd will need a good clutch. You don't need a bigger turbo, fuel system, HPOP or CAC. To get the most potential you'll need all that and most importantly good programming.
Um, my stock turbo won't clean up my smoke from the Stage I's...
You'll also need an Innercooler unless you are planning on leaving your chip on the lowest setting a lot.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
thanks all wondering if i did injectors and have twildman program a chip
if i leave it on stock for regular driving and switch it to extreme to whup up on some dodges if i would be ok not changing turbo ,ic, tranny upgrades ect.
You'll want to get a better clutch, a SBC Con O at the least. Do you have any other mods on your truck? Intake, exhaust, guages? You'll want to do those before you get injectors unless your injectors need to be replaced. But you will still want to change the intake, exhaust, and guages regardless.
97' F250 CC 4x4 SB PSD 5spd 188,000 4:10's LT265/75R16 Cooper Discoverer ATR's Tymar Intake, HPX, 3X4 DP, 4" Street Exhaust
Custom Injectors
17deg HPOP
SD HT Starter
Shimmed FPR
Uniden Pro520XL
MaxRad Antenna
1000cca Everstarts
AIC
Autometer Gauges
Disconnected EBPV
ES bushings
Warn Premium Hubs
Rhino Liner
Custom goose neck
Chrome bed rails & body skirts
Custom wife dents
Stickers that make it faster (no really)
