What are the durability issues as far as upgrading injectors with the 5 speed. I was thinking of bdp 130's. Would I need a new clutch. What else would I be replacing soon?
1994 F250, Tymar, Tuff country 2" lift
I would definately recommend the Southbend OFE clutch, its got a lighter pedal to it, and holds more power in case you tow something heavy and/or decide to do a few more upgrades later on. You will not regret it I promise you. I have baby swamps and a 6 position chip and tow about 6000 lbs with it and you cannot get that clutch to slip if you tried. Few more bucks than the CON O but well worth it, as well as a very smooth and quiet engagement.
1995 F350 PSD 4x4 Reg Cab LB 5 speed. Babies, 6 po chip, Southbend OFE, Autometer Ultra-Lite EGT, Boost, Oil Pressure, Poor man Tymar, 3" downpipe, cat delete, 4" exhaust with muffler, 4.10 gears, Bilsteins, crushed white with pearl clearcoat, all black interior with tan Eddie Bauer seat. SOLD 12/06
2003 F350 King Ranch 4x4 6.0l powerstroke CCSB
AFE stage 2 Pro Dry S
4" Turbo back Magnaflow
With the 130's you will not have to do the clutch right away, they do not have enough fuel to slip it but will more then likely shorten the life of the DMFW due to the extra power. When you replace it a SBC Con-O will work fine.
<font color="red">bdp</font> Custom Injectors
<font color="red">bdp</font> Custom Fuel systems
<font color="red">bdp</font> Custom Turbo systems Stealth Dual HPOP Systems Get Destroked W/Destroke Cummins Conversion Kits
Whatever else you may need to go fast or tow with your truck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 5SPD F350 4X4 4:11LS For Sale
New Truck- 02 F350 Dually 4x CC 6spd- 05 CR Cummins Built For Pullin And Raisin Hell
Yep the Con O should be plenty. It will hold a little more if you decide to throw some more mods in but if you plan on more after that I'd look at the OFE.
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
