OBS two wheel drive 4-5 hours with a break or two.
Did mine earlier this year.
__________________ THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
I was buy myself, and never done anything like this before.
I got it out and ready to go back in the first day taking many breaks and looking at many things. Had to have a friend help get it back in place morning of the second day.
Jack and straps across the frame to catch the trany are a must.
