Old 02-14-2006, 12:01 AM   #1 (permalink)
PSDfreak's Avatar
Installed 3 Position...Couple ?'s
I installed a 3 position chip from T. Wildman (Econo, Tow, Xtreme) on Saturday and am VERY VERY happy with it...but have a couple of ?'s.
1) When I switch from Econo - Xtreme, or Tow - Xtreme the WTS light comes on and the truck kind of stumbles for a second them evens back out...is that normal?
2) Today when I was showing my Roommate my new found power, we got on the freeway (in Xtreme), took it up to about 2500-2700 in 4th, shifted into 5th and put the pedal all the way down. I was trying to watch my boost and EGT gauges while merging into traffic. EGT's hit 1200 for a second and boost I think hit around 23-24 lbs @ 75 mph. I let off and when I looked down I had a CEL. Got off freeway, turned truck off and turned it back on, CEL gone. Didn't seem to run any different when it was on (the CEL). What causes this? Too much boost? HPOP?
Thanks guys,
Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is offline
Old 02-14-2006, 12:08 AM   #2 (permalink)
Banned
Re: Installed 3 Position...Couple ?'s
I would guess hpop is getting weak. Yes its normal for truck to stumble a bit when you change settings.
Luke
lukecline is offline
Old 02-14-2006, 12:17 AM   #3 (permalink)
PSDfreak's Avatar
HPOP getting week? [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Would it be any gain to me running a SD HPOP with the setup I have now??? What do they go for?
Thanks,
Casey
PSDfreak is offline
Old 02-14-2006, 11:08 AM   #4 (permalink)
Get a HPOP pressure guage and check your #'s first, make sure thats the problem. What other mods are you thinking about??, injectors, turbo ect. I would base you decision on which HPOP on you future mods if any.
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 02-14-2006, 12:29 PM   #5 (permalink)
Some days i can set a CEL others i can't. I know my is ICP pressure above/below desired. Get your guy at work to scan it, even though the light is off, the code is still stored in the computer.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
TimMiller is offline
Old 02-14-2006, 05:42 PM   #6 (permalink)
Soaggydogg's Avatar
My Photos: (11)
If you go through the hassle, definately a SD HPOP. I know eventually you'll do injectors. I would guess a SD HPOP is $200 plus an IPR. More if new, less if you find a great deal.
'95 F250 _Running on Pump Diesel
'02 Excursion
Total Diesel Performance LIVE Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 02-15-2006, 10:03 PM   #7 (permalink)
Can we re-use our IPR with a SD HPOP? Or do we have to use a SD IPR?
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
My Pictures
DD- SILVER 11/97 F350HD XLT RCLB Auto 3.55LS 4x4 OFFROAD
Mods: Redneck straight-pipe, TS/2L Moto chip.
smokyred is offline
Old 02-16-2006, 01:24 AM   #8 (permalink)
You can use the old IPR (unless it's from a super early one like 94...I think).
For $200 expect a used pump, though.
Casey, is your truck a CA truck (does it have splits)? They are large enough that extra oil will come in handy. [img]/ubbthreads/images/graemlins/grin.gif[/img]
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 02-16-2006, 10:01 AM   #9 (permalink)
My Photos: (6)
[img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
97 F-250HD Super Cab 4X4
Jasper E4OD, 3.55 gears
Auto Meter Dash Mounted: Trans temp, Boost, EGT, Oil Temp, Oil Pressure.Water temp. Gauges. http://photos.thedieselstop.com/show...t=1&thecat=500
Homemade Open Air Filter, 3 in SS DP, SD, 03 Intercooler. GTS kit. Modified Pedestal, ITP SS HX, CCV Mod, BABY SWAMPS & SWAMPS 6 POS Chip, 17 Deg HPOP, Gutted EPBV, Jasper Stage 1
249,000 Miles, and still going Strong.
TSM Disk Rear Brakes
Cratos is offline
Old 02-16-2006, 01:11 PM   #10 (permalink)
PSDfreak's Avatar
No its not...its got single shot squirters....
-Casey
PSDfreak is offline
