Old 03-12-2006, 12:10 AM   #1 (permalink)
Installed muffler on my 4" straight, results
I had 4" straight from the downpipe all the way out, exit in stock location. I cut out a section and added a 16" spark arrestor off of a 4-53 detroit, which is straight through but has about a six inch gap between the inlet and outlet. With the 4" straight, I could easily get to 32-34 lbs boost, now only 27 max with a slower spool up [img]/ubbthreads/images/graemlins/frown.gif[/img] I had no smoke, now rolls some black smoke. It is quieter, but I do not like the performance drop [img]/ubbthreads/images/graemlins/shrug.gif[/img](who would have thought)-I would rather have the noise! Guess I'll be looking for a magnaflow or aeroturbine or something, and I am tempted to call Dale I and ask about his 3" to 4" downpipe since I discovered how much this matters.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 03-12-2006, 12:52 AM   #2 (permalink)
STurbo90's Avatar
My Photos: (9)
Re: Installed muffler on my 4" straight, results
I believe it is from the turbelunce you introduced into the system. Having a gap in the piping will slow down the exhaust gases from exiting the system, similar to the crushed downpipe. The magnaflow is a nice piece, it is baffled instead of having a gap between the inlet and outlet, I went with one and am happy with it.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 03-12-2006, 09:27 AM   #3 (permalink)
Briansshop's Avatar
I bought a 5" Magnaflow &amp; it necked down to 4" on the inside-sent it back.I liked mine w/out a muff,but tried one to see what it would sound like.Right now I'm using a big rig muff-it's like a glasspack,straight through,just louvers.I'm sure 4" is big enough, I just didn't want to run all that 5" pipe and go down to 4" at the muff.
Brian
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,open intake,SD IC,1.0 Housing,Pedestal Mod,Gutted EBPV,dp,5"no muff, Baumann TCS controlled e4od,"I LOVE that thing"!,Baumann VB kit,UCC Custom Billet T/C-VERY low stall speed,Mag-Hytec pan,dual True-Cools,remote filter,3 pos.T/C lock-up switch w/LED,Elec.fans on trans.& engine w/Derale adj.stats,Gauges,Kingpin D60 w/Lock Right,Detroit Locker in the 10.25,4.88s,4" Nat. springs w/ORU-SRK in fr.,crossover steering,10" Atlas springs in rear-no blocks!,Bilstein 5100s,38" PJ Dirt Grips on 16x12" M/T Classic Locks w/Centramatic balancers,Warn hubs,Powerslot rotors,Hawk pads,Can-Back canvas top.
http://s77.photobucket.com/albums/j70/Briansshop/
Just getting broken in, 50,000 miles!
Briansshop is offline
Old 03-12-2006, 05:57 PM   #4 (permalink)
jimzpsd's Avatar
I am using a Walker glass pack, p/n 24217. It is stainless steel, 4" in/out, and about 20" long. I did not lose any power, and I spool up just fine. Its nice and silent while cruising, but sounds REAL nice when you step on it. It is the flow thru type wrapped in glass wool. I too tried various muffler assys. but all were too silent and/or reduced performance.
1997 F-350 XLT, 4wd, crew cab, E-4OD,TDE-1, 4:10's
jimzpsd is offline
Old 03-13-2006, 02:07 PM   #5 (permalink)
Dale I's Avatar
My Photos: (19)
You probably don't want to run a muffler that utilizes a baffle. It will significantly reduce the available cfm flow. For instance:
4" in/out baffled: 1750cfm @8"H2O
4" in/out w/o baffle: 3200cfm @8"H2O
Of course, this may or may not be the measurement for the exact muffler you have. You will have to contact the manufacturer for their spec. But, even with a bit of variance you can still see the difference.
Thanks for reading, Dale
Pics 1995 F350 - To much stuff to list,
more money spent than I want to admit.
Dale I is offline
Old 03-15-2006, 03:10 AM   #6 (permalink)
Covah's Avatar
So Dale do you reccomend a muffler or straight 4"
95 crew cab,5spd,4x4,edge evo,3"downtube,no cat,4"exh,k&n,autometer pyro&boost,stancor,10k,smfw,240k
Covah is offline
» Sponsor Links
»Garage Storage and Cabinets
