Old 03-15-2005, 12:01 AM   #1 (permalink)
Send a message via AIM to Groves
Installed my Ambulance Alternator today. w/pics
Hey All,
Just thought I'd let you all know about the installation of these ambulance alternators.
Some pictures are here
I ordered from the site that others have recommended.
Ambulance alternator purchased here
It didn't come packaged the best, but the thin metal fan shroud was all that was bent, and it bent back easily.
The bolt pattern on the new one is the same as the old, but you need to buy longer bolts. Any old hardare store should carry what you need. They're just metric bolts that are a little longer.
The plug that plugs into your stock alternator has one wire that plugs into an additional place on the stock alternator. The new alternator doesn't use that second, smaller plug, just the big one.
Others have suggested that the wire that carries the current works fine for 130A, but not for 215A, and have suggested replacing it with something more stout.
The stud on the back of the stock alternator that carries the current is smaller than the behemoth on the new one, so it won't fit even if you wanted to use it.
I bought 3ft of #4 welding wire (not wire for wire-feed, but wire that carries current in electrical welding) for $1something a foot, and two copper ring terminators of different sizes, 5/16 and 3/8 I think.
It's a cheap cable to make, and it will handle the current fine.
The serpentine belt is the last change you'll need to make. I didn't ever read about needing to change this, but I found my stock belt *just* barely too short. Maybe I could have forced it??
Anyway, the shops around here did have a separate listing for the ambulance package for the belt, and it is .5" longer or something like that.
It's a spendy belt at $60, but not so spendy that I didn't want not only one, but two. Can't hurt to have a spare in the toolbox, right?
Anyway, it runs like a dream, my old stock alt definitely having a bearing going out, as I can tell now when I spin it.
It charges at idle, and my battery light is once again at rest. My batteries have to be lovin getting charged instead of only drained, too.
97 F-250 HD PSD CC Shortbox. Mods: FPR Shim, Open Air Intake, Sonnax Valve, Tricumulator Springs
Groves is offline
Old 03-15-2005, 03:05 AM   #2 (permalink)
Re: Installed my Ambulance Alternator today. w/pics
Great instruction and pics. I'll be saving this for future reference.
Thanks, bud.
Quadzilla
'95 F-350XLT Crew Cab SRW 4X4 PSD,
35X12.50X16.5's, LS 4.10's, Air bags front and rear, PS 2000 propane, TYMAR intake, 1.0AR turbine housing, gutted EBPV, downpipe, 5" exhaust system, DP chip, Autometer gauges, Fumoto valve, Tru-Cool, HX mod, Tricumulator springs, Sonnax valve, 4R100 pan,
Magnefine tranny filter, reverse shackle kit, Big_Fig power pedal,
(Thank God for a wife that likes big trucks.)
Pictures
I'm not affilitated with the vendor "Quadzilla" in any way.
Quadzilla is offline
Old 03-15-2005, 10:49 AM   #3 (permalink)
I should have taken more pics. I can snap some of any part that someone needs to see.
I do like the fact that the heater hose doesn't rub on electrical parts, but can wear til it's heart is content on the metal housing of the alternator.
Matthew
Groves is offline
Old 03-15-2005, 11:39 AM   #4 (permalink)
Nice write up. If I ever decide to do it, I'll know what I need.
[img]/ubbthreads/images/graemlins/biggrin.gif[/img]
95 F250, 4X4, E4OD, 4.10, Hypermax DP and Tymar 4" Exhaust System, Tymar Air & Coolant Filters and HPX Kit, Tymar fuel fill mod, External Transmission Filter, Schaeffer's ATF. Add-a-leaf, Redline Differential gear oil and Redline ATF in Transfer Case. OilGuard By-pass oil filter. Schaeffer's 5W-40 in the engine. A-Pillar...Autometer Boost, Pyrometer and Trans. Temp. Gages, Under dash...Oil Pressure and Water Temperature gages, 1705 Superchip Tuner, Stancor GPR, Factory Tech Valve Body, Evans Waterless Coolant, Two 4590 Tru-Cool Transmission Cooler in series, Explorer Overhead Console, Diesel Turbo Lifesaver, Tymar Fuel Filler Mod.
Griz is offline
Old 03-15-2005, 03:53 PM   #5 (permalink)
This just got sent to my favorites. Thanks for the great write up. I will be doing this soon to my truck.
Thanks, Dave
'97 F350 XLT CC, 4x4, SRW, H2E, Modified babys, BTS Trans, Head Studs,,,,,too much to list.
dtosh is offline
Old 03-16-2005, 04:04 PM   #6 (permalink)
I replaced alternator on my B-II at 200Kmiles. Heater hose layed accross it. Hose wore about a 1/4" groove in the alt, but never lost a hose. I think hose holds grit, and the harder surface takes the wear rather than the softer one.
-KF-
97 '250 SC 4WD ZF5, 3.55 axles, ATS WG volute, '99intercooler, Hypermax DP feeding 4"straight pipe, US-Gear chip, Maddog stage-1 injectors, 140Volt IDM.
"If it ain't broke, fix it 'till it is!"
Kevin Ferguson is offline
Old 03-17-2005, 10:56 AM   #7 (permalink)
Paul H's Avatar
My Photos: (10)
GEt a second hose braket, and put one on each side. No more hose rub issues.
Paul H
OWNER
2004 Ford F350 6.0L Dualie
1996 Ford F350 7.3L Dualie
FOKISD CLUB MEMBER
FOKISD CLUB SITE WEBMASTER
double U double U double U Dot FOKISD Dot ORG
My Pictures
Paul H is offline
Old 03-17-2005, 02:11 PM   #8 (permalink)
What you using extra amps to run?
I thought about adding a 1800watt inverter in the tool box sometime, so I can run a saw or something. Some places have reasonable prices on inverters comparable to a gas generator.
97 white F250HD ex.cab, long box; 5 sp. ZF; 3.55 rear; 4x4 ("86" the bedbox stickers); 185K miles.
markcprice is offline
Old 03-17-2005, 02:59 PM   #9 (permalink)
In typical upgraders fashion, I don't have anything to run using the extra amps yet. Nothing at all. For $120 something after core returned, I thought it was worth it.
I've thought of a nice high wattage inverter, maybe an electric winch. Maybe I could just hook up some cables and arc weld from it! Kidding of course.
I couldn't see any downsides, and I like the option, and just wondering how easy it was. And it was.
Matthew
Groves is offline
Old 03-17-2005, 03:59 PM   #10 (permalink)
Gotcha...
If you want to weld without buying a kit, you may have to set up a 24v system; but I know what you mean.
Old 03-17-2005, 07:12 PM   #11 (permalink)
Is that a ford remanufactured alternator or an aftermarket? I have a Ford AIC and I remember reading something about not using aftermarket alternators with the AIC.
1997 F-350 Powerstroke Crew Cab 5-SPEED SRW 4x4
Lund Visor, Velvac Stainless Steel Mirrors, Ford AIC
1976 Jeep CJ-7
totljeep is offline
Old 03-17-2005, 11:35 PM   #12 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
With the coolant filter, mine runs right over the alt case. I just used a pice of hose, split down the middle to sleeve the heater hose (should be able to see it in my pics). Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is online now
Old 03-17-2005, 11:51 PM   #13 (permalink)
I'm not sure. The link at the beginning of the thread shows where I bought it. It's a mitsubishi made alternator I believe. No experience with the AIC yet.
Matthew
Groves is offline
Old 03-18-2005, 09:43 AM   #14 (permalink)
Paul H's Avatar
My Photos: (10)
Even with the 5ver on and running lights at night it is a huge draw on the Alternator.
If I use the turn signals, as soon as the signal lamp comes on, the rest of the marker lights will dim a bit.
That is where the extra amp output would be worth it to me.
Pluss running the radio equipment. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Paul H
OWNER
FOKISD CLUB MEMBER
My Pictures
Paul H is offline
Old 03-18-2005, 10:11 AM   #15 (permalink)
Thanks Groves. I will be doing this soon myself as I have a lights dimming and discharge at idle that I am pretty sure is ruining my new batteries. The belt info will save a lot of cussing [img]/ubbthreads/images/graemlins/grin.gif[/img]
96 F-350 4x4 CC LB, International block and heads from Mcandless IH in Denver, <span style="color: red">Baby Swamps </span>, Luk Cerametallic Clutch, 5" straight exhaust,5 speed ZF, 4.10's, Evolution programmer, Banks brake, non-EBPV IH turbopedestal, AFE Magnum force, CA reg. kit, 12,000 lb. Milemarker on reciever mount, 215amp ambulance alt., 33" muds on factory aluminum, Class 5 bumper hitch, hidden gooseneck, pillar gauges, fosgate amp, 12" sub.
Colorado National Gaurd.
"Firearms stand next in importance to the constitution itself. They are the American people's liberty, teeth and keystone under independece. When Firearms go, all go's. We need them every hour!"
President GEORGE WASHINGTON
bigbore is offline
