hey all, bought a set of ARB air lockers for Deezel a while back and still haven't installed them. i know axles but to be honest i am a little timid to jump into these with no real idea what lies ahead. is it a pretty straightforward thing or does it get really complicated? anyone nearby who would like to come and supervise over a 12-pack, lol? seriously, anyone who has advice/pics if you could please help me, please do!
thanks in advance!
Josh
1996 Ford F350 XL SuperCab shortbed 4x4, PSD, 5-speed manual, D60 swap, 6" Skyjacker (all spring) lift, 37" Super Swamper SSRs, 16x10 Ultra Stargazer wheels, South Bend Con-O-FE clutch (HIGHLY RECOMMENDED!!), SMFW, Tymar air intake, Swamps 150/146s, shimmed FPR, Northern Diesel Performance 4-position chip, 3.5" Hypermax downpipe, 4" Airflow exhaust, Dieselsite's BRV, Husky lo-profile toolbox, Reunel front "Import Mauler/Chevy repair kit-gotta do my part to clean-up America" DYNO'D 1 October-308.8 RWHP, 620.1 RWTQ!!...see her here www.cardomain.com/id/rattlinford
have one, almost finished wiring it yesterday, I had a shop put it in, I would have done it myself, but I know better, good thing too then had a tiem fitign it, you must have teh special tools and extra shims to get it to fit right. I could not remove teh carrier from teh case to start with.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
If you have successfully changed a carrier in an axle before, the ARB is no different other than the airline and a few tricky fittings. You also have to drill the top of the housing for the air fittings. As Nit said, you also need to have an assortment of carrier shims to obtain the correct backlash.
Cheers...
BB
__________________ BigBopper 97 F-350 CC XLT 4X4 PSD, E4OD and a few other goodies...
thanks guys...don't know if i will do it or not...i know about having to possibly spread the case and whatnot, but i really don't wanna spend $900 or so to have these installed...
Josh
less than that to install, mine was only $500 up here, but I was in a huge rush to get it doen.
I've installed a Detroit Locker and 5:13 gears in a Dana 60 before. Since you are installing a whole new carrier you need to set backlash and preloads, which requires a dial indicator and an in/lbs torque wrench. You need a press also. I would just order a rebuild kit with all new bearings and it comes with an assortment of shims.
Installs around here go for ~$300. If you want to do it yourself, take your time and read up on it as much as you can. It was fun and I'll be doing it again. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Travis
1997 F-250 HD 4x4/OR SC LB XLT PSD E4OD 3.55LS, TDE1, Baby Swamps (150/146/A), BTS Trans, BTS programming, Front and Rear Replacements, Gooseneck, Autometer Pyro, Trans Temp and Boost in Rockin' S Pod, Cab/Clearance Lights installed, Tymar style intake, 6.0 Intercooler, Tru-Cool Max tranny cooler, Warn Premium Hubs, Shimmed FPR, Gutted EBPV, Super Duty 3" DP, 4" Exhaust, 175,000 mi., 7400 lbs., 310 HP 559 TQ
I installed an ARB air locker on my Mustang. I feel the ARB instructions are the best I have ever used. They are step by step. Read through the instructions one time and see if you think you have the tools for the job. I had to make a case spreader. I took a pic of the install. It is the 13th picture down on my Mustang web page. I know it is only an 8.8 rear, but the job is still the same.
