I'm wondering if there would be any benefits from trying to make the intake flow better from the turbo to the heads, like shorter spool up time or more boost. I mean, the Y with the 90 degree turn and the flat boxes at the heads don't seem all that flow-friendly.
I haven't seen anything from the aftermarket suppliers, although there is a lot of various free-flow mods like the Tymar type intake for pre-turbo part.
I suppose if it was vital more people would be doing it, or are they and i'm just missing it?
I know that intake design is less critical with turbo engines than NA's, but it still matters, otherwise the pre-turbo intake would not be getting so much attention, and air still needs to flow, pressurized or not. Any thoughts on this?
-97 F250HD PSD 4x4 LB SC AT 102K, stock
Plans: some gauges, Tymar-type intake, mild chip
There are some improvements available such as billet intakes(Beans I know sells them others are probably available from other vendors). How much do they help??? I havent found any data on just how much the improve flow. The y-pipe, only improvement I know of besides building your own is to add an intercooler.
97 F250 X-CAB, LONGBED 4X4 w/ 3"downpipe,DIY Tymar intake, hx hose, and 203 stat, stage3 injectors, D60 w/Sky's rsk and shackle flip plus 4" lift riding over 46"michelins, other mods include 5.13 gears arb front and detroit rear plus purple cranium products diff covers and gaurds, ats s5 tranny, bushwacker cutout flares and more to come.
We do not have huge valves you are only going to push soo much air thru the valve at a time.
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
I just put the 3" billett intakes on along with the Hypermax 3" ypipe that matches up for my hypermax intercooler. I also installed a twin electric superduty fuel pump system at the same time. I can now pull hard no fall off all the way to the redline of motor. But I think the majority of that came from the fuel system. I am sure I gained better airflow, They look great and impressive on the motor, but if money is a factor I would spend it somewhere else, I think you can get alot more bang for your buck on other things
96 f250 ordered and owned since new, 4.10 gears custom built e40d by jim galatioto of ato transmissions. hypermax intercooler,hypermax stage 2 injectors, hypermax h2e turbo,downpipe,4" exhaust,, terminator pump with 2 new 17 degree pumps dp tuner F5 chip with 6 programs,Beans 3" billet intakes and dual superduty electric fuel pumps, tymar 4" intake system, gear vendor overdrive on transmission, ,new 3/8" transmission lines all the way up and v10 cooler in the bumper and dieselsite transmission filter. cat gone up the tree. Coolant filter added, A/C vent mod done. diamond clear headlamps,park lamps and cornering lamps,remote start & ford alarm. Complete inside cab doors floor and headliner completely DynaMat Extreme lined.Late model 3 pinion posi trac installed. SD Starter. LoJack installed.
