Old 01-21-2008, 07:15 PM   #1 (permalink)
My Photos: (6)
Intake plenums
I found my boast leak the Intake plenums need to be resealed.
Two questions
1: I what year Intake plenums will fit the 97 heads and the early 99 Y spiders> If I have to take them off anyway. I might as well get ride of the reducer boots and stock Intake plenums??
2: Do I use the gray sealer or what works best. To reseal them?
Curt
97 F-250HD Super Cab 4X4
Jasper E4OD, 3.55 gears
Auto Meter Dash Mounted: Trans temp, Boost, EGT, Oil Temp, Oil Pressure.Water temp. Gauges. http://photos.thedieselstop.com/show...t=1&thecat=500
Homemade Open Air Filter, 3 in SS DP, SD, 03 Intercooler. GTS kit. Modified Pedestal, ITP SS HX, CCV Mod, BABY SWAMPS & SWAMPS 6 POS Chip, 17 Deg HPOP, Gutted EPBV, Jasper Stage 1
249,000 Miles, and still going Strong.
TSM Disk Rear Brakes
Cratos is offline
Old 01-21-2008, 07:46 PM   #3 (permalink)
My Photos: (6)
I already have the spider and intercooler installed.
Cratos is offline
Old 01-21-2008, 08:08 PM   #4 (permalink)
BardOrBrad's Avatar
Cratos, I was wondering if you have changed out your boots on the intakes? Mine are in need of changing, BAD! I still have my stock boots which I think are still 2.5 diameter.
97 350 XLT SRW CrewCab, 4X4, 4:10's, Gauges, Tymar OAE, HX hose, 6p chip, no EBPV, ORU RSK, Evans Coolant with inline filter, PLM tranny and diff covers, 203 T-stat, Spin-on in-line trans filter & true cool cooler, 5" exhaust, IDM mod, AC mod, Banks IC, hada PULSE HPOP but a 17 willdue4now, DIY Stage I's, Dieselsite CPR OBS electric fuel system, Gregg Evan's Monster in a BOX!
BardOrBrad is offline
Old 01-21-2008, 08:14 PM   #5 (permalink)
ThreeStarJR's Avatar
If you want to go ahead and use the 3" superduty plenums....(it does open up the area for more volume, but you might never feel that you have increased power by doing so..), you can get the 2 3/8" inch x 3" inch boots here: http://http://www.turbohoses.com/Transition.htm they are pricey...but if you ever decide to upgrade to a larger turbo then you don't have to replace the plenums again....They may actually help with more air....I did them on the motor build and already had the d-66 so there was no way to see what change they might make....
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Wildman Tunes
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
play it loud!
#3
ThreeStarJR is offline
Old 01-21-2008, 08:18 PM   #6 (permalink)
with the sheetmetal "Y" pipe your boots to the plenums are 2" inch.....the early 99 y is 2 3/8".....
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP Fuel system
Wildman Tunes
Caltracs
play it loud!
#3
Old 01-21-2008, 08:26 PM   #8 (permalink)
BardOrBrad's Avatar
Where do you get a 3" intake spider? I have a banks kit and would like to ditch the stock intakes.
Old 01-22-2008, 09:29 AM   #9 (permalink)
My Photos: (6)
3 star
the way I look at it there MUST be some restriction from the E-99 spider ( form the intercooler) to the stock Plemnums any time you neck something down it has to slow thens down. are you still happy with your D-66? I'm thinking of maybe doing it this summer.
Curt
Cratos is offline
Old 01-22-2008, 10:15 AM   #10 (permalink)
I still have the stock intake plenums on my truck. I don't know this for a fact but I would assume that you will need to have a larger than stock turbo to be able to tell a difference in power. The stock turbo only flows so much air and I bet the 2" tubing is able to provide sufficient flow.
I have also heard that you can bend the crap out of the intakes getting them off if you are not carefull because the silicone holds so well. Some people say it's not worth the effort to take them off easy and reuse them. They aren't too expensive through International. If this is the case then I would get the 3" SD plenums for sure.
96 F-350 CC Dually
B codes, head studs, valve springs, 6.0 IC, electric fuel system, Wildman tunes
346.7 hp 12/15/07 Greeley, CO w/ stage 1 injectors
racehauler is offline
Old 01-22-2008, 10:47 AM   #11 (permalink)
I would do the 3" superduty plenums. They are cheap enough and then you don't have to worry about upgrading them again. I have several sets of intakes (all OBS) that were taken off and didn't have a problem damaging them. Just can't muscle them off is all.
I would go to Intercooler Pipe Fabrication - Silicone Intake Systems Auto Parts for your boots. They are mostly an import site. But they have great prices. I just ordered some new boots and T Clamps from them for my intercooler reinstall. Shipped day after I paid (which was Sunday). Got them 2 days later.
Sam
96 CC F350 SRW - 3" DP - 4-5" exhaust single stack - DIY K&N Intake - coolant filter - secondary fuel filter - rear airbags - Rancho 9's in rear and 5's in front - Pac Brake - 17k Tranny cooler w/ fan - Aux Engine Fan - 1000lb lift gate - jumper cables - Oil temp/coolant temp/boost/pyro gauges - turbo timer - 120 IDM
Soon to be installed Tranny gauge, air horn, Steering Stabilizer, IC, E-350 battery tray/relocate
genie144 is offline
Old 01-22-2008, 10:49 AM   #12 (permalink)
Does anyone have an International part # for that?
95d1 is offline
Old 01-22-2008, 04:02 PM   #13 (permalink)
My Photos: (6)
hope I'm wrong but it looks like the turbo has to come off to get them off ??? anyone know for sure.
Cratos is offline
Old 01-22-2008, 10:50 PM   #15 (permalink)
Tha late 99 and up stock y-pipe is 3". that's the only 3" available. it will not line up to a stock obs configured turbo....
Cratos, got to remember we are dealing with positive pressure boost, not normally asperatied motors....the 2 inch ID, early 99 y, is not that much of a restriction from the 3 inch cac pipe/intercooler system. Look at the tube coming off the compressor side of the turbo feeding the intercooler...it's not 3 in.........
The D-66? almost 40,000 miles and I get a smile on my face everytime I start the truck......If Bean had all the sophisticated testing equipment that the Garrett's and the TN turbo's had, I guarantee you that the cfm's that this turbo produces would knock their socks off!! it spools ever so slightly later than the stock turbo ....so sudden 1/2 to full throttle pedal will produce smoke in the performance settings on your chip until it lights, but when it does..........holy hell!
and it is a towing truck owners dream! The egt's with an intercooler are awesomely low.....much has been negatively said about it useing the stock center section, but as long as it is used with an intercooler and maximum of stage three injectors, (230cc and below, it will live a long life and make the owner keep perma-grin.......
Jim
529/1220 10 17 08
BDP "DOMINATOR 66,"
BDP Fuel system
Wildman Tunes
Caltracs
play it loud!
#3
Similar Threads
Intake plenums duallyduty 7.3L Power Stroke Engine and Drivetrain 3 05-09-2007 02:53 AM
Intake Plenums dpantazis 7.3L Power Stroke Engine and Drivetrain 2 11-04-2006 09:05 AM
3" intake plenums DieselWiezil Power Strokes 1994-1997 Upgrades and Aftermarket 7 06-09-2006 01:36 PM
Upgraded Intake Plenums f250power Upgrades and Aftermarket - 7.3L Engine 1 05-16-2005 02:55 PM
&r
