I am so excited, I went to a big truck junkyard today and came out a happy person. I went there to look for rims for my truck and ended up coming out with an intercooler spyder to fit my truck for the intercooler that I have. I found it off an older school bus. Its not a one piece y-pipe its a two piece, looks kinda weird but works!! I'll have to take some pics of what it looks like!!!
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
1997 F-250** Ext-cab Afe stage 2,Mbrp stainless turbo back Auto meter Z pillar gauges, Tony Wildmen 4 pos chip, Fs-2500 Bypass filter, , DI mini-me injectors, Mod h2e, h11 studs,regulated fuel 6.0 intercooler *Pyro Fabrication FrontBumper my truck pics
gotta pic of the IH IC y-pipe in my webshots link in my sig. Great find! I looked into that option but then was offered a bank y-pipe for $50. Good job and thanks for sharing.
__________________ 1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Ya I'm just happy that I found one cheap so i can complete my intercooler installation. It isn't one of the best looking y-pipes, but it will work just fine!!
Allright i defiantly will, b/c i will be installing it here hopfully in the next week or so. The only problem I can maybe see right now is that the y-pipe is pretty tall, so I don't know if I will have a clearance issue with the hood. But from the looks of it right now, I don't think it should. But if it is, it should be hard to fix anyways. I got the y-pipe and all of the intercooler pipes and rubber hoses for $40. So all in all i have less than $200 in the intercooler and everything that is needed. The only other problem is the intercooler piping. I will need to fab some little pieces together, but it won't be bad. Afther I get all of this done I plan on getting it powdercoated to make it look better and look cleaner. I'll keep you guys posted!
I just finished installing an 6.0 intercooler in my truck. I couldnt find any Y pipes that were cheap so I ended up just building my own from scratch it really wasnt as bad as i thought it would be, and i just bought some mandrel bent 3" pipe and fabed my pipes as well it all worked out really nice and was cheap to do, I have one pic of it in my web shots.
__________________ 96F-250 4x4 Red Ext Cab
DP Tuner F-5 6 pos chip
Autometer 3 Pillar guages
Industrial Injection Hybrids
City Diesel custom 6.0 intercooler
AFE Stage2 magnum force intake
Garrett GT38r ball bearing turbo
Custom Fuel System
CCV Mod
HX Oil Mod
4.10 rear end
Built E4OD
Custom 5" exhuast w/stacks
4" lift
35x12.50x16 BF Goodrich All Terrains
Good find, don't forget to post some pics when you are done!
Robs96,
Nice clean installation. Would you consider adding some close up shots of that Y-pipe you made? I think that will be helpful to a lot of people since it is unknown if Ford will ever make the Early 99 Y-pipe available again!
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
Not trying to put your Y pipe down but you neck it way down before the Y. That's KILLING your flow!
I know that the kneck from 3" to 2" really sucks im working on going 3" all the way to the y and going 3" from the turbo out. I built it that way just to get me going with the intercooler, and ill have some more pics of the intercooler parts soon.
Custom Fuel System
CCV Mod
HX Oil Mod
4.10 rear end
Built E4OD
4" lift
