is putting a intercooler from a 99 or newed PSD be benificial for my 97 non intercooled?
I already have a chip waiting to get a different style (SCT chip) stock intake w/ 3" down pipe and gutted cat. so as far as these mods go will the intercooler make a difference?
97 Tan PSD 193,000mi exhaust w/ 4" downpipe, EGT waiting for install (stinger series) Wide Band Commander waiting for install as well.
I think the general premise is that if you monitor your exhaust temps and your pre-turbo temps stay under 1,250 you are probably OK without. When the level of mods you have done push your EGT's over 1,250, you need to start looking for ways to reduce the EGT's, a 99+ I/C is one of several ways to keep exhaust temps in check.
I retro'd a SD I/C into my truck to allow me to tow our travel trailer while running a race burn chip. This afforded me conservative EGT's for the long hauls up and over mountain passes, without walking the fine line of EGTs. Again, there are other ways of addressing high EGT's, I/C is one of them!
Hope that helps!
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
Most definitely! I have an '01 Superduty intercooler, and it has dropped the "exhaust gas temps" by about 200°F! It is most notably noticed when towing, but overall keep the EGT's down to a liveable level!
Some notice more lag, but I found I had no lag issues, which I
personally believe my IDM mod happened to eliminate, but overall, the intercooler mod is definitely worthwhile.
You'll find alot of guys on here have done this modification, and you can find more info on it at Geoff's <font color="blue"> GTS Motorsports </font> site. Just click on the "Ford Powerstroke" link, and you will find the "Intercooler" link.
You can actually see his <font color="blue"> Intercooler Instructions </font> at this link.
Yes, it's necessary. Why do you think all the late model diesels run them? [img]/ubbthreads/images/graemlins/wink.gif[/img] The piping is simple. I built my own with stainless 3", but any exhaust shop can do it for you(that does 3" anyway), CHEAP! Just install the IC and find a reputable exhaust shop to build your pipes. Shouldn't be more then $200. [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/wink.gif[/img]
__________________ 95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Precision Hybrid from BWD), Industrial Injection BD Injectors, DIIC with custom stainless 3" piping, Terminator HPOS, DI headstuds, BTS tranny, TruCool 40GVW cooler, DP LIVE TUNED F5 with Extreme ICP(ya, it works)!, Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be shortened.
97 F350 Regcab4X4: Twin Turbo's, lots of fuel and oil.
Well if you have any exhaust shop build your pipes for you they aren't going to work as well as they should because all the bends will be drasticly reduced in size as exhaust shops don't have mandrel benders. You want to use mandrel bent pipe so that the size stays the same all the way through the bend and doesn't get crimped on the inside of the bend like exhaust shops do it.
Right on, i dont tow much but my last vehicle was a fox body mustang that had a 347ci stroker motor in it...to im always looking into speed mods or something that will help. I bought the truck completely stock ...stock exhaust,intake everything cept a 4" lift and some 33" tires...that was all that was done...and me...i have a tendency of wanting to go fast, not to mention my buddy who has a 01 SD with the banks 6 gun, intake exhaust ...AND HE SMOKES ME...LITTERALY... [img]/ubbthreads/images/graemlins/phoney.gif[/img]
i was told to contact Banks and see if they have any "take offs" my buddy bought one for a car set-up from them for like 180 bucks....so im thinking about doing that!
[/ QUOTE ]AHHHHHHH? WRONG! A good exhaust shop can and will have mandrel bend elbow's and 45's in stock, if not, they can get them. Oh, I used all mandrel bends on my IC pipes, and I did my own(not that tough). [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
They don't go through the engine compartment very well. Especially on the passengers side.
When I called all the exhaust shops around here NONE of them had mandrel benders. Regular exhaust shops don't as they are WAY more expensive than the standard benders they usually use and the majority of their customers wouldn't want to pay the prices for the more expensive mandrel bends as a lot of their work it repair work not necessarily performance work. Most likely they could order in some mandrel U bends but you could order them up just as easily and probably for cheaper from somewhere like Summit.
What about getting some Super Duty stock pipes and modding them to fit? That's my plan. Just need to get a hold of the parts.
Yes this will work, I used them without modding them but they didnt fit real well and I made a custom ypipe and stuff to fit them. If you cut them and repositioned them they will work just gotta do a little fab work and welding.
Cool, that's the plan then. It doesn't look too hard to fab up a y-pipe either. 135 mig welder and bandsaw are my best friends [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Travis
1997 F-250 HD 4x4/OR SC LB XLT PSD E4OD 3.55LS, TDE1, Baby Swamps (150/146/A), BTS Trans, BTS programming, Front and Rear Replacements, Gooseneck, Autometer Pyro, Trans Temp and Boost in Rockin' S Pod, Cab/Clearance Lights installed, Tymar style intake, 6.0 Intercooler, Tru-Cool Max tranny cooler, Warn Premium Hubs, Shimmed FPR, Gutted EBPV, Super Duty 3" DP, 4" Exhaust, 175,000 mi., 7400 lbs., 310 HP 559 TQ
Lucky dog. The best I can do is an arc welder and a hacksaw! [img]/ubbthreads/images/graemlins/wink.gif[/img]
1996 F250 4x4 5sp shortbox, ats intercooler, DIY Tymar, 3" dp, Dual 5" stacks, South Bend Con-O clutch and SMFW. BDP Stage 1's up and running!!! my truck
TS 6 pos. chip-High idle, Economy, Tow, Jody Tipton Hot (75 hp), Diesel Power Extreme, and TWildman's "Move it or lose it" Extreme
"A man can always stand a little bit more horsepower" - Chris Ledoux
