Old 08-30-2006, 06:49 PM   #1 (permalink)
Intercooler Brackets
I am lookig for the dimensions for the brackets for the intercooler. I am putting on an intercooler from a '99 Super Duty and wondered if anyone could give me the dimensions so that I can fabricate them. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Scott Fosdick
Brazil, Indiana
96 PSD CC 4x4 Two tone green/white,TS Six position flip chip( thanks Jonathan for the Tune),rebuilt tranny w/heavy TC and shift kit,ranch hand bumpers,KC Hilite HID 4000's, 285/75/16 BFG's, 4" straight piped w/downpipe,Baby Swamps 150cc injectors, Three gauge pod w/Autometer gauges,Tymar intake,323,000 Miles and counting.....Replaced turbo pedestal and EBPV delete,Dominator 66 from BDP(thanks goes to Tubbz),Intercooled ( what a job that was),new o-rings on oil rail fittings,new alternator,water pump,powersteering pump,and vacuum pump)Nfab step bars. Member of S.L.A.P.S.
(http://community.webshots.com/user/bigdogstroker
coachscott is offline
Old 08-30-2006, 07:24 PM   #2 (permalink)
Briansshop's Avatar
Re: Intercooler Brackets
Can't help ya w/the dimensions,but there's a few pics of my mounts in my sig.
Brian
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,open intake,SD IC,1.0 Housing,Pedestal Mod,Gutted EBPV,dp,5"no muff, Baumann TCS controlled e4od,"I LOVE that thing"!,Baumann VB kit,UCC Custom Billet T/C-VERY low stall speed,Mag-Hytec pan,dual True-Cools,remote filter,3 pos.T/C lock-up switch w/LED,Elec.fans on trans.& engine w/Derale adj.stats,Gauges,Kingpin D60 w/Lock Right,Detroit Locker in the 10.25,4.88s,4" Nat. springs w/ORU-SRK in fr.,crossover steering,10" Atlas springs in rear-no blocks!,Bilstein 5100s,38" PJ Dirt Grips on 16x12" M/T Classic Locks w/Centramatic balancers,Warn hubs,Powerslot rotors,Hawk pads,Can-Back canvas top.
http://s77.photobucket.com/albums/j70/Briansshop/
Just getting broken in, 50,000 miles!
Briansshop is offline
Old 08-31-2006, 02:17 PM   #3 (permalink)
Thanks a lot! NICE TRUCK! Where are you from?
Scott Fosdick
Brazil, Indiana
Old 08-31-2006, 03:18 PM   #4 (permalink)
Made mine from some 2x2x1/8 angle. Pics in sig.
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 08-31-2006, 09:38 PM   #5 (permalink)
Briansshop's Avatar
Thanks,Scott,I'm in Maryland about 30 miles south/east of Wash, DC.
Good luck w/the IC install,it's not so bad,just takes some time.I still haven't piped mine.I'm planing on doing it over the winter w/some stage IIs.
Brian
Old 09-01-2006, 10:36 PM   #6 (permalink)
My Photos: (32)
I have the distance I used, between the rad support and the front side of the mount, in my I/C Install page. The link is in my sig. Note that the distance is based on using 3/4" angle iron for the vertical support that sits behind the installed I/C... if you use a thicker support, you'd need to push the I/C farther from the rad support. There might be some other tips in there that might help...
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
TimC63 is offline
Old 09-02-2006, 02:07 AM   #7 (permalink)
WOW! Thanks a lot! That is awesome how you put that together!I will let you know how it goes. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Scott Fosdick
Brazil, Indiana
