Just wandering if water injection is just as good as an intercooler and what the pros and cons are of the two.
95 f350 powerstroke crewcab 4x4. 4" exhaust 5" tip . Tony wildman chip,no cat. Tymar intake.Autometer guages,pillar mount.FPR shimmmed,160cc injectors.Superduty intercooler. 4.10 gears. Detroit Truetracs front and rear. Idm modded. Airlift 57215 airbags in rear.Sky RSK with Superlift 4 inch lift in back and V codes up front.Homemade 6 foot traction bars.
I've been pondering H2O for a while. Snag I see is my EGT's get out of control at lower, lugging, RPM where a 'cooler would work well. H2O comes on when you're building boost, like 10 psi or more. My truck rarely ever sees boost unless I'm on it hard and by then the EGT's are in the 1200+ and climbing range where a 'cooler won't help much by then.
I cruise at about 1000*, so a 'cooler would drop that to a comfy 800*(?) or so.
So my solution would be to do both. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-250, 4x4, CC SB DzlJim.com for some redneck engineered projects.
www.racerxautomotive.com for your upgraded E4OD/4R100 needs.
H20 injection + 10 psi boost = hole in block! (<- experience speaking!)
Do the intercooler!
H20 injection needs 18 psi up to be safe and 2 staged at that.
You would be for ever filling the water container.
Rick H...
__________________ Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp [color:"RED"] RDRCM#20 [/color]
Sounds like it would be to do the intercoller then.Which one would be the easiest to bolt on and could some one dirsct me to a link to that.
Your best bang for the buck is to retro fit a superduty (7.3 or 6.0) and modify 7.3 supderduty tubes. Tubing kits are also availible seperately from banks and GTS. A complete IC kit will run you $1500 or so, Tubing kit plug Either IC about $7-800, and a complete DIY retro between $200-$400 depending on your parts hunting skills.
