Re: intercoolers
I dont have any data to back up my opinion but I would say the only REAL advantage to one of the big name CAC's is the fact that it comes with everything you need to install. If you do a SD intercooler you have to find a cooler then the rest of the plumbing, or you could order a kit from GTS. I dont think there is really any HUGE benefit temperature wise...Now the 6.0 CACs are larger than the 7.3 CACs, so those would probably cool ya down a little more.
-Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
