Old 04-26-2006, 09:59 PM   #1 (permalink)
Send a message via ICQ to arffdiesel
K&N Oil Filter
Are the K&N oil filters anything special? are they worth the extra 2 bucks? I have just been running a federated, which is made by purolator i believe. i think purolator manufactures the motorcraft filters. i did a search, but couldnt find anything on this one. thanx
Nate 97 Powerstroke 4x4 Extended Cab. Vector Lightbar, strobe headlights, dashlight lots of other misc lights. Warn 8274 winch. SD HPOP, Gutted EBPV, variable 10k, homebrew intake, 6 pos dp tuner, k&n filter, HPX mod, MBRP Stainless exhaust, and Autometer gauges, Monsterbox Trans, fpr bb mod, and alot more on the way.
Trucks
Truck 2. 97 PSD LB 4x4 SuperCab. Immaculate one little old man who hauled nothing truck. Brings back flashbacks of a 1997 Ford Showroom Floor. Bone stock original at the moment. 108k. - Sold
P-19 4x4 Oshkosh Crash Rescue Truck with a big cummins and 54in Tires (at work)
74 Bronco with Warn XD9000i winch, 3in lift, glass body....
arffdiesel is offline
Old 04-26-2006, 10:04 PM   #2 (permalink)
Re: K&N Oil Filter
When looking at filters, see if you can find out how much and what size particulates get filtered out. Example, 97% at 10 microns. Then compare.
Flow rate is another thing to look at too...
hth,
Jeff Blumenthal
Austin, Tx
97 F350 CC SWD 4X2 4:10, Wildman chip, AFE Stage 2, 6.0 IC, BD 4" Exhaust System, BD Exhaust Brake, BD AutoLoc, Tranny Shift Kitted, Billet Torque Converter, Tru Cool 4739 w/Thremal Bypass, EGT Shutdown Monitor, Air bags, EGT/Boost/Tranny Piller Guages
warpdriv is offline
Old 04-26-2006, 10:55 PM   #3 (permalink)
Re: K&N Oil Filter
I tried one on my gas truck and didnt notice anything special, I dunno, Im happy with my reg old wix/hastings filters. But if K and N made a fuel filter Id most likely give it a shot.
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 04-27-2006, 09:49 AM   #4 (permalink)
My Photos: (18)
Re: K&N Oil Filter
I spend extra money on the Mobil 1 filters as they have better specs than the motorcraft ones. I can't find my data on the specifics anymore so sorry I don't have them to share.
Tim
2001 F-250 Crew Cab, short bed, 4x4, 4R100 with VB tuned by Travis's Automatic Trans, Lariat, Snugtop shell, Line-X bedliner, 265/75/R16 GY Silent Armor. DIY open element air filter. DIY 4 inch exhaust, from stock DP back to 45 degree turn down. Quadzilla Recon XZT moniter- EGT, Trans temp, Boost. DP tuner Stock, 40T, 40T high altitude, 80E, Curt MFG Q5 20K slider hitch, P3 brake controller, ATS housing. Blue Bullet
Sold-- Bright RED 1996 F350 XLT, 4X4, CC, 4.10 gears ,E40D, SRW, Rebuilt E40D at 190K with a 3yr/36K mile warrenty, by Travis's Auto Tranny 719-574-8104. Big Red
Proud Member of the NRA, helping to protect our American Rights!
New Toy: Can-Am Outlander MAX XT 650 -- AWESOME
5th wheel 2000 Dutchman 24RL with 12' slide
TCH777 is offline
Old 04-27-2006, 09:40 PM   #5 (permalink)
hheynow's Avatar
Re: K&N Oil Filter
Tim
What's the part number?
1997 F-350 PSD XLT RC 4x4 E4OD
303K miles and still running very strong
Using WVO and biodiesel since May 2006
hheynow is offline
Old 04-27-2006, 09:42 PM   #6 (permalink)
My Photos: (38)
Re: K&N Oil Filter
IMHO one of the best oil filters out there for our trucks is the Fleetguard with the Stratopore filter media.
some stuff
14.8 @ 90
gregrob is offline
Old 04-27-2006, 09:46 PM   #7 (permalink)
Re: K&N Oil Filter
where is the best place to get those fleetgaurd filters? are those the ones flying j has sittin on the shelf? what pn would i run? i also have heard about a 3qt donaldson filter? those work?
Trucks
Old 04-27-2006, 10:04 PM   #8 (permalink)
My Photos: (38)
Re: K&N Oil Filter
See This Thread for more info.
LF3374 is the normal-sized one.
LF3974 is the larger one.
Read the whole thread and decide which one to you use. AFIK they both use the Stratopore media.
some stuff
14.8 @ 90
gregrob is offline
Old 04-30-2006, 01:24 AM   #9 (permalink)
Re: K&N Oil Filter
I noticed a big difference when using the K@N oil filter in my dodge. I think i may give it a try with my PSD.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
TimMiller is offline
Old 04-30-2006, 02:18 AM   #10 (permalink)
PSDfreak's Avatar
Re: K&N Oil Filter
What did you see that was different? I stopped at Kragen Auto today on my way to wally world (for oil and filter) and I saw the K&N filter on the shelf...they had one in stock for me but I figured it was just an over priced waste..tell me why its better and maybe ill give it a shot.
Thanks,
Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is online now
Old 04-30-2006, 02:29 AM   #11 (permalink)
My Photos: (38)
Re: K&N Oil Filter
Got this bass ackwards guys, sorry.
LF3974 is the NORMAL-sized one.
LF3374 is the OVER-SIZED one.
See below for comparison pics.
Height Comparison, hammer's pics
Width Comparison, hammer's shots
some stuff
14.8 @ 90
gregrob is offline
Old 04-30-2006, 11:58 AM   #12 (permalink)
Re: K&N Oil Filter
I noticed the oil stayed a lot cleaner for a lot longer. And with my dodge i noticed when my oil started to get old on a regular filter, my oil pressure started to fluctuate. With the K&N the oil pressure stayed the same, where the needle was pointing straight up.
Truck pics
Old 04-30-2006, 03:26 PM   #13 (permalink)
My Photos: (18)
Re: K&N Oil Filter
PSD mobil 1 filter = M1-601
I get them at Auto-Zone.
Tim
Here is a description from their web site:
Does ExxonMobil make oil filters for use with Mobil 1?
ExxonMobil does offer a very high-quality oil filter that can be used with any motor oil, but it is an especially appropriate companion to Mobil 1. Mobil 1 Extended Performance Oil Filters contain synthetic fibers instead of the typical cellulose filter media. With a 99.2 percent efficiency rating (under SAE J1858 Multi-Pass Efficiency Test), the Mobil 1 filter is much more efficient than a typical oil filter, removing more particles per pass through the filter. In addition, the synthetic fibers in the Mobil 1 filter have less resistance to oil flow, reducing the potential for the filter to restrict the flow of oil to your engine.
TCH777 is offline
For advertising information, please visit our AutoForums.com website and Contact Us, or send an email message to sales@autofor
