King Ranch Seats in 1997 F350 - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 03-24-2008, 05:31 PM   #16 (permalink)
are your door panels a brownish color? In the pics it looks like they are don't you think? Or is it just playing tricks on me and is the actual gray?
96 F250 PSD ext cab SB, 5 spd 3'' DP with straight piped exhaust, tymar intake. 150k mi. Dana 60, SD v code springs, RSK
psu927 is offline
Old 03-24-2008, 07:53 PM   #17 (permalink)
gnxtc2's Avatar
How did you mount the seats? Did you drill new holes or used some type of adapter plate to line up to the stock holes. Any pics of the mounting means?
Billy T.
gnxtc2@aol.com
'97 Black F250HD,XLT, SC, LB, 4x4, Suncoast E40D, Triple Disk Converter, Dana 60, 3.55LS, built 12/97, 3"-4" DP, Bilstein 5125s, VDO EGT, Trans Temp, and Boost gauges, Hellwig rear swaybar, CA fuel regulator, 4" Exhaust-Straight piped,FORD AIC, welded EBPV, B&M Transpan, Cryo slotted rotors, Tony Wildman 4 position chip, Joe Servo IDM, MAP sensor mod, Blackbird rear disc conversion, RSK w/ "V" & "F" code SD springs, Hydroboost conversion, replacement 38 gal rear tank, Swamp's Baby Hybrids, CJC Traction blocks, 209K <---STOLEN
PICTURES OF IT ALL
Fort Lee, NJ
gnxtc2 is offline
Old 03-25-2008, 08:15 AM   #18 (permalink)
Due to the Super Duty seats sitting a little higher than the OE seats, using an adapter would have caused the seats to sit higher than I wanted.
Place the new seats (with uncut brackets) into the cab area once all OE seats and carpet was removed. Be sure the seat it not slid all the way to the front or rear. I chose a neutral position. From that you can get an idea of where you want them to sit. It just so happened for me that where I wanted them to sit would work great once I flattened the mounting brackets. That's why I cut the triangles out of them. Then, lay them flat and weld. Next, I placed them back into the cab and marked the holes with a Sharpie. I then drilled out those holes. Put the seats back in and bolt to the floor.
We just ran some 7/16" bolts through the floor and secured with lock nuts. This would be impossible with one person, so make sure you have someone in the cab to help you. You could go one step further and just tack the bolts to the floor from the under side of the truck, but I am hoping these seats never come back out again, so it wasn't that big of a deal to me. Plus, they're much less permanent this way if for some strange reason I needed to go back to OE seats.
I didn't take any pictures of the mounts, because there's just really nothing to see. Just a bolt through the floor.
Current PSD pictures - 1996, PSD, Dually, 4x4, Auto
King Ranch seat swap
My last lifted F250: http://isoaxis.com/truck/
bmzero is offline
Old 03-25-2008, 11:24 AM   #19 (permalink)
The OE interior is brown/tan.
bmzero is offline
Old 03-25-2008, 01:12 PM   #20 (permalink)
You might want to ad something on the bottom side to keep the bolts from pulling threw in a accident.
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3&quot; downpipe, 3.5&quot; adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Some people are blinded--because they have all the answers
Racerxpower.com for your upgraded E4OD/4R100 needs
BlindViper is offline
Old 03-25-2008, 01:17 PM   #21 (permalink)
Nice Find & Write-up! I hope to be doing this in my OBS someday. Probably just gray leather though (gray interior...)
SOLD - 96 F350
CC/LB/SRW XLT 4x4 AT PSD 4.10 Toreador Red
3" SKY-RSK, SD springs front and rear, properly valved Bilstein 5100's , Genuine Tymar Intake
& 315 Pro Comp AT's on 16x8 series 118 Eagle wheels
SOLD - Early 99 F250
CC/SB/SRW Lariat 4x4 AT PSD 3.73 Black overTan
WRECKED 11/05/03 - 01 F350
SC/SB/SRW Lariat 4X4 AT PSD 3.73 Hunter Green
Photos
CHRI7S is offline
Old 03-26-2008, 08:24 AM   #22 (permalink)
Correct me if I'm wrong, but the force from an accident will be applied to the seat belts, which are still attached in their OEM location. The only force applied to the seats would have to come in a side impact, at which point nothing is going to hold the seats to the body. Also, there is probably more surface area covered by the Grade 8 washers (under the Grade 8 bolts) than the stock mounts cover.
Please don't take that the wrong way though. I appreciate any feedback on this project, even if it is negative. That's the only way we can all learn, myself included.
bmzero is offline
Old 11-15-2009, 04:43 PM   #23 (permalink)
man i had a completly different experience doing some super duty lariat seats- I wonder if they are different- The only front seat bracket i had to notch was the passenger inside bracket and the rear seat im still working on- It doesnt fit at all
97 F350 2wd PSD 5 speed
tymar chip, downpipe, ebp delete,
96 F350 Crew cab 4x4,
96 F800, 12v cummins, Eaton 6 speed
scotzilla is offline
Old 11-15-2009, 06:32 PM   #24 (permalink)
well the rear fit i just had to shorten the brcket because of the subwoofer box behind the seat. i should have just ditched the music but the mid and mid amp are back there as well and im too lazy to redo it all. I just the people in the back will have to live with 3 inches less leg room.
Old 11-16-2009, 07:19 AM   #25 (permalink)
Post some pictures when you get it done. I would love to see how you did it.
bmzero is offline
Old 11-16-2009, 10:30 AM   #26 (permalink)
fronts
this front bracket towards the inside of the car is the only one I had to hack.
The seats can go all the way back to where there is only inches of room for the rear pasengers and forward to where a 4 ft china man could reach the pedals. If i would have cut them to where they all mounted on the flats i would have been sitting in the rear seat. Im 6"4 250- Whats the range of motion like your your king ranch set-up?
the back brackets before shotening them 3 inches
Old 11-16-2009, 10:32 AM   #27 (permalink)
after
Still need to trim the center consol a little bit to fit the floor better and figure out seat belts. Also the power motors work but they labor a little since they dont fit the floor perfectly- Im gonna play with them this week and see if I can get hem shimmed to where they glide nice and easy
Old 11-16-2009, 08:46 PM   #28 (permalink)
Therien's Avatar
Very Inspiring Projects
F-250 1996 7.3 Powerstroke E4OD 4x4 4.10 XLT / Ext. Cab / Long Box / K&N / Larger Tranny Cooler / TS Performance / 3in DownPipe to Straight 3.5 / Autometer / Stadium / Firestone AirlLifter 5000 / BF Goodrich Commercial T/A / http://rides.webshots.com/album/575969161OVOTMg
Therien is offline
Old 11-16-2009, 09:01 PM   #29 (permalink)
Ragdude's Avatar
Very nice job, I would LOVE this but mine has a grey int also
Protect the 2nd Amendment!
It's the original homeland security act.
'96 F350,Dually,CC,5 spd.,stock.
'02 Excursion Limited, stock
B100 baby! Bring it home, to the American farmers!
Remember 9/11, and don't become complacent again
Ragdude is offline
Old 11-17-2009, 08:08 AM   #30 (permalink)
I sold this truck quite a while back or I would go out and snap some more pictures for you. I'm 6'3", so when I put them in, I put them in to fit me, but I think you're right, I proabably put mine back too far. My mother-in-law needed to borrow the truck one day and she couldn't reach the pedals, so it didn't happen. I'll refrain from any mother-in-law-proof jokes.
bmzero is offline
« ECM | Better MPG »
