Old 06-10-2007, 09:57 PM   #1 (permalink)
kingpin d60, whats involved in the swap?
I have a 250 (96) and want a D60, I found one out of an 89 350 (kingpin) for a decent price in my area and want to know how much I would have to do on my truck. already has my gear ratio.
96 F250 PSD ext cab SB, 5 spd 3'' DP with straight piped exhaust, tymar intake. 135k mi.
psu927 is offline
Old 06-10-2007, 10:55 PM   #2 (permalink)
BadDogPSD's Avatar
Re: kingpin d60, whats involved in the swap?
There are tons of posts on this. The D60 is pretty much a bolt on
swap. If your truck is lifted, most will recommend you swap out the
front driveshaft to the F350 double carden style.
Try to get the tie rod, track bar, sway bar, etc. as not much of the D50 stuff will work with the D60.
Quite a few guys on here recommend that you do the RSK and add SD
springs at the same time to improve the ride.
1997 F250 4x4 Crew Cab PSD; Dana 60; Sky RSK w/SuperDuty springs.
BadDogPSD is offline
Old 06-11-2007, 07:22 AM   #3 (permalink)
I am planning on doing the RSK and SD springs. How much money am I looking at as far as the double cardon driveshaft? Just don't want any surprises. And if I can't get the other stuff (tie rod, track bar, sway bar) those things should be redily available at a salvage yard I would think.
psu927 is offline
Old 06-11-2007, 12:30 PM   #4 (permalink)
u2slow's Avatar
My Photos: (16)
You can probably get a used one for $100 or so that would need new joints.
Your brakes will change. 95-97 are a newer design. That means you need to buy calipers (unless the D60 comes with good ones.)
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw
u2slow is offline
Old 06-12-2007, 07:25 AM   #5 (permalink)
ok, So is 900$ a decent price for the axle, if it does not come with any of that stuff?
psu927 is offline
