Old 07-22-2007, 09:46 PM   #1 (permalink)
SoB
SoB's Avatar
Knock after injector rebuild
Just rebuilt all eight injectors. Had one broken plunger spring. Restarted the truck but not driven yet. I now have a couple of other issues. 1) A knock that comes and goes,getting progressively louder it will knock 25 or 30 times then fades away. 2) Oil in the fuel bowl. Usual smoke and rough idle after injector R&R.
I vacuumed all the cylinders out several times. Filled the oil pump reservoir up several times. Bumped the starter a lot before ever spinning the motor over.
Buzz test is good. Contri test is all over the place because it is stilling idleing ruff.
Sounds like it is on drivers side but not sure.
Pulled drivers side valve cover 2 is oiling real good 4,6,8 ok.
Any ideas where to start???
Thanks- Steve
Black '96 F250 XLT 4x4 SC,LB,7.3L PSD,Suncoast E4OD,3:55 Gears,Tymar Intake,4"exhaust,Hypermax intercooler,H2E,DIY StageII's, Wildman 4 position chip,Tymar HX mod,2001 HPOP,Ranch Hand Bumpers F&R, Warn 12000LB Winch,305 70R16 MTR's,Oil,Tranny&Pyro pillar mounted, 278K
SoB is offline
Old 07-22-2007, 10:38 PM   #2 (permalink)
My Photos: (14)
Re: Knock after injector rebuild
the knock could possibly be air in the system try driving it 25 miles and see if starts tog et worse or better
but first
oil in the fuel bowl is usually sighns of bad o'rings, oil pressure is higher then fuel so it will actually pump oil back into your fuel rails and into your fuel tank!
Travis
SWAMP'S Extreme Powerstroke Performance
2L Motorsports
Charter Member of www.FOKISD.ORG
99 F350 ext dually 2crueL (moded somewhat)
86 F250 4x4 - C6 3.55Ls[b]
The Mule 1995 F350 CC - 4x4
95 E350 PSD 190k miles
97 F250 ext lb 160k 4x4
97 FSuperduty Plumbers Truck
93 Ranger (soon to have twinned 4bt)
My Webshots
Moremph is offline
Old 07-22-2007, 10:39 PM   #3 (permalink)
Man you need to go drive it and get the air out of the system I usually drivem at least 15 miles.
97 F-250 H/D 4 door 4X4 6'bed.Broke block building new engine! Oh well it ran14.96 at 89mph at Baytown!
Kenworth T-600 aerodyne 3406c CAT, with 18* "B" modle injection pump(was a freakin peak yuk),10 over trans,4.10 rears,Dual 150 gal. fuel tanks,Budwieser inspired custom hot rod flames.Going to work real soon Leasing to Landstar yeah!
89 mustang coupe single turbo 302 ,built c-4,running little rubber.
I hate Dodges, straight piped common rail cummings sound like crap!
Aljay is offline
Old 07-23-2007, 01:00 AM   #4 (permalink)
SoB
SoB's Avatar
Went and drove it some. Put about 35 miles on it. Knock is a lot less often and a lot quieter now. Still has the usual miss and smoke after injector work but getting better. I will check the oil in fuel issue in the morning. I have not had the knock like this before.
Thanks for the help- Steve
SoB is offline
Old 07-23-2007, 11:00 AM   #5 (permalink)
My Photos: (13)
Steve
With the HX hose depending on how its mounted it can entrap air.(loops above or below).
Air tends to build under the ICP. You could remove the IDM relay and bump the motor with the sensor removed. Also be shure that your FPR screen is clean so the air will purge out of the fuel.
Here is my trick guy's for bleeding oil system.
I made a oil line that installs in the ICP location. The other end of line goes to the oil fill of motor. It has a cap on it with a .005 hole in it. First purge is with plug off cranking. Then plug on motor running. ENJOY works great on motors with HX mod.
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 07-23-2007, 04:35 PM   #6 (permalink)
SoB
SoB's Avatar
Knock is all but gone. Smoking faily bad. Whiteish gray with the smell of oil. Smokes from idle to cruising. Fuel in bowl is grey. Missing also consistantly. Have AE scanner software. What should I be looking for besides a bad o-ring on the Injector. Which ring would it be on the injector?
Thanks guys- Steve
SoB is offline
Old 07-23-2007, 04:51 PM   #7 (permalink)
Bill
COOL! Saves having to disturb the little plugs under the valve cover. I don't know if you saw my posts on it lately but I R&R injectors with out any of the hard start, smoking, 25 miles of rough running etc. Just not worth it to abuse my engine that way. Prolly takes me an extra hour but starts right up and runs like nothing happened.
Diesel Mechanic 28 yrs
Garbage_Mechanic is online now
Old 07-23-2007, 05:14 PM   #8 (permalink)
My Photos: (13)
That why i made the hose up.
Eliminates all the Bull Chit.
Bill
MADVAN is offline
Old 07-23-2007, 07:10 PM   #9 (permalink)
Supporting Member
Excavator's Avatar
My Photos: (11)
are you sure all the washers came out of injector hole when you pulled them. If there is 2 washers in one hole that could do it. Also you may have not seated one injector good and that could do it.
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Stock for now Auto trans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 173000 miles
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, Tymar intake, 112000 miles
1997 F350 XL DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 175,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Excavator is online now
Old 07-23-2007, 07:48 PM   #10 (permalink)
SoB
SoB's Avatar
I am sure I got all the old washers out. Bagged and tagged all the old parts per injector. Have checked one bank for seating issue. All ok. Will be pulling both valve covers tonight to check seats on all eight. As of this afternoon still smokeing and missing. Sure not looking forward to pulling all of them out if it is not a seat issue.
Thanks for the suggestions
Steve
SoB is offline
Old 07-23-2007, 09:46 PM   #11 (permalink)
may I ask how you cleaned the oil and fuel off the top of the pistons?
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Racerxautomotive.com for your upgraded E4OD/4R100 needs
BlindViper is offline
