Old 11-22-2006, 04:07 PM   #1 (permalink)
lap top & software ??
Well, as an early birthday gift I recieved a real nice Dell laptop computer from the lovely wife. As a matter of fact I'm posting from it right now, enjoying its versatility and portability. I can only imagine its uses and will never use it to its full potential, however, one application I can think of and at the same time take advantage of its portability is troubleshooting a PS engine and monitoring functions. I promise there is a question here! What software out there is available for that purpose? What kind of supporting equipment would be necessary? I know absolutely nothing about this sort of thing and dont even know where to begin. Thanks.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 4:10 * cc/lwb * RSD Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP 1.0 exhaust housing * Hypermax 3x4" dp * Authentic Tymar intake * gutted ebpv * 4" exhaust & 5" tip * AlumaCraft diamond plate toolbox * custom antenna mount (108" whip) * Uniden cb * diamond plate bed rail caps * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25 * ccv mod * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * poly bushings (front) * Rancho RS9000 shocks * dual steering stabalizer * 60,279 on rebuilt engine (myself) as of 1/08
To do list:IDM mod
94strokerace is offline
Old 11-22-2006, 04:09 PM   #2 (permalink)
Re: lap top & software ??
www.autoenginuity.com
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 11-22-2006, 05:59 PM   #3 (permalink)
Unless I'm missing something, that link only offers products for OBD 2 equipped vehicles, beginning with 1996. My truck is 1994. Does that mean I am OBD 1?
Randy
To do list:IDM mod
Old 11-22-2006, 07:20 PM   #4 (permalink)
Well, you can put a chip on it and activate the obd port.
Old 11-22-2006, 08:11 PM   #5 (permalink)
OK, Venge, I really, really appreciate your help, however, your talking well above my head.
What does that mean in stupid-to-these-things terms? Are you saying that the chip will act as an adapter, or interface?
Randy
To do list:IDM mod
Old 11-22-2006, 09:45 PM   #6 (permalink)
A chip with a later pcm code will generally activate the obd port and make it think it is a later model truck.
Old 11-22-2006, 10:40 PM   #7 (permalink)
js2941's Avatar
Have the stock PCM flashed to a newer code, 97 or later. That will awaken the OBDII port & kill the OBDI. That is what I did to mine. A chip or tuner would not work on my truck until I had this done. Cost me about $40. at Ford dealer where I knew the shop manager. I even told them which code I wanted (don't remember it now). They downloaded it from Ford and fixed me up. Took a couple hours while I waited.
1994 F350 4dr SRW 2WD w/32" sleeper - 1 owner, ZF5, 410, Stock inj, SC1705 tuner, 3" BD dp, Isspro pyro & boost gauges, LUK flywheel & clutch, Kelderman air suspension(rear), YORK conversion air compressor (DIY), DIY Ex Brake & AIC, 340k
js2941 is offline
Old 11-23-2006, 09:29 AM   #8 (permalink)
I see. FWIW, I e-mailed Autoenginuity asking them about an OBDI product. They replied indicating it's coming soon. I'll look into the reflash thing, do I need to supply a specific code or does it matter as long as I'm over 1996?
Randy
To do list:IDM mod
Old 11-23-2006, 09:43 AM   #9 (permalink)
They will only load the latest update, which for the auto is TDE1 and the manny is MLE1
Old 11-23-2006, 10:08 AM   #10 (permalink)
Thanks Venge and js2941. To be honest, I'd be surprised if my stealership will even know how to reflash, I'd probably get the deer in the headlights look.
Randy
To do list:IDM mod
Old 11-23-2006, 10:29 AM   #11 (permalink)
They know how to reflash if they have ever sold a 6.0 off their lot! [img]/ubbthreads/images/graemlins/blush.gif[/img]
Old 11-23-2006, 10:49 AM   #12 (permalink)
I'm not sure if they know what a 6.oh no is. It made front page news down here when they hired a diesel tech a couple of months ago. I dont know his/her experience or background, but this is why I like to do my own work.
Randy
To do list:IDM mod
Old 11-24-2006, 12:03 AM   #13 (permalink)
Contact DP-tuner. Jody can reflash your PCM. A Chip will override the pcm. They sometimes do weird things with the 94 PCM's, but jody can help you out.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
TimMiller is offline
Old 11-24-2006, 03:47 PM   #14 (permalink)
Another option, I like it. Thanks!
Randy
To do list:IDM mod
Old 11-27-2006, 09:17 PM   #15 (permalink)
Paul H's Avatar
My Photos: (10)
Jodi can put what ever preformance program right in the PCM for you when he does it
Paul H
OWNER
2004 Ford F350 6.0L Dualie
1996 Ford F350 7.3L Dualie
FOKISD CLUB MEMBER
FOKISD CLUB SITE WEBMASTER
double U double U double U Dot FOKISD Dot ORG
My Pictures
Paul H is offline
