Old 10-18-2006, 07:28 PM   #1 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
Larger Front tank
Does anyone know of someone who makes a larger aftermarket front tank for our trucks?
-Michael
Michael Paul
1995 F250: Regular cab, 7.3L PSD, 5-Speed, 4x4, 4.10 LSD, gauges, 2L chip, injectors, turbo, 4" downpipe - 6" tip, clutch, fuel system, Medium oil, Headstuds, Valvesprings, Cab lights, Dana 60 - New Look Soon!
1995 F250: Regular cab, 7.3L PSD, 5-speed, 4x2, 3.55 open, Intake, Downpipe, 4" exhaust, clutch, 2L chip, short throw shifter - To do list!
My Webshots
Dieselfever78 is offline
Old 10-18-2006, 07:45 PM   #2 (permalink)
Re: Larger Front tank
Pretty sure Transfer Flow does, like a 40 or 60 gallon, also known as BIG!! [img]/ubbthreads/images/graemlins/smirk.gif[/img] And aren't you supposed to be doing class work right now? You are in class after all!! [img]/ubbthreads/images/graemlins/grin.gif[/img]
Dave
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD Powered By 2L Motorsports and SWAMPS.
Mods: AM Ultra-Lites, DiPricol HPOP gauge,TS/2L Moto Chip, 4" Straight-Piped, Poor boy's intake, Swamps II's, BTS, 285 BFG A/T's on factory Alcoas. Lots more to install, see below!
On the bench: AirFlo S400, Swamps 275's, Studs Rods and Springs for the top end, and some other stuff.
My Pictures
DD- SILVER 11/97 F350HD XLT RCLB Auto 3.55LS 4x4 OFFROAD
Mods: Redneck straight-pipe, TS/2L Moto chip.
smokyred is offline
Old 10-18-2006, 07:57 PM   #4 (permalink)
Ain't that the truth [img]/ubbthreads/images/graemlins/mad.gif[/img]
Clifford A.Thomas III
Dyno'd 343 hp and 685 ft.lbs. torque #2 tow setting
http://community.webshots.com/user/cliff1972
1996 F250 4x4 Reg Cab,(3rd)rebuilt engine 9/2007.DYI Stage II 170cc,stock turbo,3" dp,ARP mains,open air filter,DP Tuner F5,4 1/2" s.s. exhaust w/ Borala muffler,Joe servo IDM mod,HX MOD,stock E4OD w/ up graded valve body,TCI convertor,4.10 posi,315/75R16 BFG MT's
Waiting to install:stock 6.0 intercooler and DIY hybrid kit
Wanting to buy:head studs, Comp 910,FASS 150/180 and Modded H2E
1964 Impala 468BBC 6.98 at 98 mph in the 1/8th
1969 Nova 408BBC 6.96 at 96mph in the 1/8th
cliff-1972 is offline
Old 10-19-2006, 01:41 AM   #5 (permalink)
Why would they be different between a Regular cab and ext cab or crew cab??
-Michael
Michael Paul
My Webshots
Old 10-19-2006, 02:24 AM   #6 (permalink)
My Photos: (6)
-Michael
Frame is shorter.....not as much room... [img]/ubbthreads/images/graemlins/shrug.gif[/img]
'95 XL SuperCab, LWB, 4X4, 204,000 miles, E4OD, 4.10 LS(when it wants to be!), body lift, 305-70-16 Cooper STT's on 10" Eagle Alloy wheels, "Brand X"-inspired home-made open-element air filter, 3" downpipe & 4" straight pipe with 5" stainless tip exiting in front of the rear wheel, 6 pos. TS Performance chip (going to visit T. Wildman soon, I hope), FPR mod, A/C mod, MileMarker manuals, onboard air (York running off the alternator...1 five gallon tank) with dual Grover air horns
2000 Jeep Wrangler Sahara Edition, white w/tan top & interier, 119,000 miles, 4.0L, auto, loaded.....no mods, yet!
Knothead is offline
Old 10-19-2006, 03:22 AM   #7 (permalink)
But a long bed is a long bed
-Michael
Michael Paul
My Webshots
Old 10-19-2006, 05:27 AM   #8 (permalink)
BlueMule's Avatar
My Photos: (12)
-Michael
Yea but from the factory reg cabs get the largest front tank. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
reg cab long bed gets a 22 gallon tank
crew cab and super cab long bed gets 19.5
crew cab and super cab short bed only gets 16.5
BlueMule is offline
Old 10-19-2006, 06:09 AM   #9 (permalink)
So what is the rear capacity on extended cab short bed?I've read here and other posts 18.2 and 20.0.TIA,Calvin
1996 F-250 2wd, ext.cab,short bed,auto trans.,3:55 ratio,3 inch down pipe,4 inch stainless Magnaflow exhaust,"Baby Swamps",TS performance 4 position chip,Tymar air filter, coolant filter, and HPX hose.Autometer gauges(pyro.,trans.temp.,and boost),California FPR kit,gutted and plugged EBPV,ported hood & bug shield,203 Dieselsite thermostat, Extreme spray in bed liner,Wade bed caps,UAW black diamond plate under rail tool box,4R100 trans.pan & filter,LARGE Hayden trans.cooler,Diamond headlights,park lights and side marker lights,Mustang GT hood scoop,Clarion CD player,Kenwood speakers.Billet Torque converter,Extreme duty trans.build with Transgo "Tugger" kit.
Calvin1958 is offline
Old 10-19-2006, 07:38 AM   #10 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Throw a SD tank in there.
MarkEkberg is offline
Old 10-19-2006, 10:42 AM   #11 (permalink)
My Photos: (14)
i know where a SD tank is sitting that you can measure off of
Travis
SWAMP'S Extreme Powerstroke Performance
2L Motorsports
Charter Member of www.FOKISD.ORG
99 F350 ext dually 2crueL (moded somewhat)
86 F250 4x4 - C6 3.55Ls[b]
The Mule 1995 F350 CC - 4x4
95 E350 PSD 190k miles
97 F250 ext lb 160k 4x4
97 FSuperduty Plumbers Truck
93 Ranger (soon to have twinned 4bt)
My Webshots
Moremph is offline
Old 10-19-2006, 10:52 AM   #12 (permalink)
i have heard people taking an expedition saddle tank which is like 35 gallon and bolting it in.
-cutts-
My Picasa Web Album
96 F350 PSD 4x4 CC/LB 5spd XLT Ranch Hands F/R, 6637 mod, 4.5" straight pipe, tymar 3-4" DP, Dominator 66 turbo, Banks IC system, DIY Stage-I's, TW 4-pos chip, 37" SuperSwampers, autometer gauges,RAM laptop mount w/AI OBD diagnostics, fold down g/n hitch, OBA system with York and dual trumpet air horns, bronco 33gal fuel tank
72 bronco 302/435/twinsticked D20/D60/10.25 welded F/R, hydro assist, 39.5" stretched WB to 105", 1410 yokes/shafts, Staz custom double beadlocks, CroMo shafts front shafts with 35 spline outers and sexy lady drive slugs, GLO diamond tread diff covers, custom cage, mesh floor, custom diamond aluminum dash overlay, wristed radius arm, homemade shackle ladder bar
Fishmanndotcom is offline
Old 10-19-2006, 12:14 PM   #13 (permalink)
Anyone know of a front tank that will fit a '97 SB CC?
TFI doesn't make one for this truck. They said that
too few were made to be worth it to them. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed.
Velvet rides installed. Joe Servo IDM mod installed. Rear air lift springs.
Sparkydm is offline
Old 10-19-2006, 12:26 PM   #14 (permalink)
PSDfreak's Avatar
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is online now
Old 10-19-2006, 11:04 PM   #15 (permalink)
Ya know, my Mom's '96 E150 van had a 38 or 40 gallon tank in it, and I think you know of someone with a van that isn't going anywhere right now.........Travis? [img]/ubbthreads/images/graemlins/wink.gif[/img]
Dave
My Pictures
smokyred is offline
