Old 05-15-2005, 03:16 PM   #1 (permalink)
LF777 by-pass filter
I installed an LF777 by-pass filter on my truck this weekend. I found that cummins had a filter base available especially for installing the 777. The base had a restriction already built into it on the return side so i didn't have to worry about any of that stuff. I ended up putting it back and behind my transfer case. I've been driving it around for about a day now and it's been good so far. My oil was about a quart low when i installed the filter and after i fired my truck up i checked it again and it took about a gallon to top off the oil level.
'94 F250xlt ext. cab. ZF5-speed 4x4. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. LF777 bypass oil filter. Electric fans. 70 psi fpr. 10k mod. 1.0 turbo housing. Boost blanket.
sdan27 is offline
Old 05-15-2005, 03:38 PM   #2 (permalink)
Re: LF777 by-pass filter
The filter bases I have seen have a .090 passage. That is too big for a 7.3. What size was yours?
444-4D is offline
Old 05-15-2005, 05:46 PM   #3 (permalink)
according to Amsoil parts list the orfice in their bypass filter bases is .092 inch. so why is it too big for the 7.3?
here is the link. look toward the bottom.
amsoil
Rob
2008 GMC 2500 HD Duramax Crew Cab 4x4
SOLD
1997 F-250HD , 4x4, auto 3.55 LS gears
TYMAR intake,
3" downpipe,4"exhaust
285/75 BUCKSHOT MUDDERS
B&M turnover ball
DMI quickcushion II rear bumper
DIY coolant filter
DIY bypass oil filter
DIY trans filter
deeretrac is offline
Old 05-15-2005, 06:54 PM   #4 (permalink)
if that is the wrong size what is the correct size? [img]/ubbthreads/images/graemlins/confused.gif[/img] i just want to be sure what size is correct i dont want to guess [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
DeiselDaddio is offline
Old 05-15-2005, 07:39 PM   #6 (permalink)
amsoil
Rob
If Amsoil recommends a .092 for a 7.3 you will have to ask them why they recommend it, I don't know why.
I do disagree with the recommendation. I think it is to big. I wouldn't go over .040 on a fixed orifice.
444-4D is offline
Old 05-15-2005, 09:58 PM   #7 (permalink)
why? will it cause to much loss of oil pressure?
im just trying to find the right orfice for my setup without hurting my engine.
Rob
SOLD
TYMAR intake,
B&M turnover ball
DIY coolant filter
DIY trans filter
Old 05-15-2005, 11:12 PM   #8 (permalink)
sea97stroker's Avatar
I went with a 1/16 drill bit that is roughly .060, i have no drop in oil pressure.
Steve
1997 F350 CC 5 Speed 4x4 , BDP Stage 2's, Wildman Chip, Isspro Gauges, 5 inch stacks, SD Turbo Setup,Banks Intercooler,Tymar Intake, SD Leather Seats. Dyno 427hp/813tq
www.BeansDieselPerformance.com
sea97stroker is offline
Old 05-15-2005, 11:13 PM   #9 (permalink)
The only way to know exactly what effect it has is to monitor the before and after oil pressure. My concern would be at hot idle.
444-4D is offline
Old 05-16-2005, 11:27 AM   #10 (permalink)
Rodney
i put a b-100 on my truck with i believe a .060 and have had no problems but this 444-4d dude has been giving Rob grief since we were on the other bypass post and i did check it out(amsoil) i hope for replies from folks like you nit ,joat dale,rob you have this stuff called documentaion or web sites that do so thanks for that a bunch. 2 years ago i couldnt spell diesel and for folks like you all give me a wealth of info thank you kirk [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 05-16-2005, 09:42 PM   #11 (permalink)
I don't see anything wrong with .060, i am not changing mine till someone shows me i'm wrong.
Stevo
Old 05-16-2005, 10:15 PM   #12 (permalink)
i re read the bypass thread and i put a .050 restristion sorry for the miss information also there was something about .035-.090. is the average range of most researched restrictions out there. kirk
