Lift - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 08-25-2007, 02:21 PM   #1 (permalink)
rickygasser's Avatar
Lift
Hey guys,
I looking to get about 1 inch more of lift out of my front end (TTB). I've already done the add-a-leaf and had the springs re-shaped. i was wondering if anybody made longer shackles or something of that nature.
Any suggestions would be appreciated, Thanks
'97 red PSD short box ext cab, 5 spd, 330,000 km, Wildman 4-position chip,DIY stage 1's, EBV brake, 4" lift, timbrens, DIY open air filter, Gooseneck in box, 3" DP, 5" turn-out stack
Volunteer FireFighter for 7 years
Farmer my whole life
Hers: 01 F-350 PSD, Reg cab, dark green, 2" front leveling kit, Wildman chip, Open intake, pyro and boost gauge, rolling on 315/75-16 BFG All Terrains
Fisher MM2 8'
FIL: 03 Excursion Limited, 6.0, 260 000kms, Banks monster exhaust, pyro and boost gauges. New head gaskets at 200,000kms, Arnott Air Bags
Other Toys: 2001 Mustang Bullitt Highland Green
2007 Mustang Cobra GT500 Red w/ white stripes
rickygasser is offline
Old 08-25-2007, 07:06 PM   #2 (permalink)
My Photos: (6)
Re: Lift
If all you want is another inch of lift I would look into Tuff Country's 2.5 inch lift system and scrap the add-a-leaf; (with the add-a-leaf removed this would give you the height you want.) I have this kit installed on mine and am very happy with it. You can use your stock shocks and pitman arm, but you have to install drop brackets which are not hard to do. Also, if you added another inch of lift to what you have right now without drop brackets you may run into some serious alignment issues.
1997 F350 XLT CC SRW 4x4; 4.10's, Tymar intake, 120k. SKY reverse shackle kit. Super duty V codes front, ICON 5 inch Super Duty springs in the rear. TS 6 pos Wildman tunes. MBRP exhaust. Adrenaline HPOP. 17x8 Cepek DC-2 wheels 285x75x17 Dura Grapplers.
mag7rht is offline
Old 08-26-2007, 12:53 PM   #3 (permalink)
jimzpsd's Avatar
Re: Lift
Have you replaced all of the bushings w/new? That alone can give you one more inch.
1997 F-350 XLT, 4wd, crew cab, E-4OD,TDE-1, 4:10's
jimzpsd is offline
Old 08-26-2007, 09:15 PM   #4 (permalink)
Re: Lift
I all ready have the drop brackets installed but now I need another inch in order to align the wheels properly. Thats why I was wondering if I could just extend the shackles
Fisher MM2 8'
