Old 11-03-2007, 11:57 AM   #1 (permalink)
Lights for front bumper
Where did yu get your lights that fit in the front bumper holes?
1996 Ford F350, 7.3 PSD, crew cab, 8ft bed, 4x4, 5 speed manual, 4.11 gears. 184,000 miles. 3x4" down pipe, 4" exhaust with 5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers,garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
gilroyracing is offline
Old 11-03-2007, 10:15 PM   #2 (permalink)
Re: Lights for front bumper
i just bought square fog lights and cut out the middle support in the wholes. took my bumper off(very easy only 4 bolts) mounted them and ran the wires. Make sure you use a relay though.
1995 Ford PSD 7.3L DRW, Specter Intake, 3.5" DP, 4" Pro-Flo turbo back exhaust. 6" MBRP Tip, SuperChips programmer 110hp increase, Marinco Mod, In bumper fog lights.
http://community.webshots.com/user/Ford_Turbo
coltf1991 is offline
Old 11-04-2007, 08:57 PM   #3 (permalink)
kfjensen's Avatar
Mine are discontinued now, have had nothing but problems keeping them grounded good, etc so I wouldnt recommend them anyways, I am going to rip em out and just stick some cheap small JC Whitney lights in them
Kevin
94.5, PSD, F-250, 4x4, Handshaker, Couple Do-Dads
kfjensen is offline
Old 11-04-2007, 11:52 PM   #4 (permalink)
Well I am having zero problems grounding mine. My lights came with preattached wires for grounding and on the back of the stock bumper, inline with the hole you are putting the lights in are pre-drilled holes. i just put a bolt a washer and a nut to keep in intact with the metal.
Old 11-05-2007, 12:19 AM   #5 (permalink)
Jcart's Avatar
Hi Gil....
I put in Bosche Pilot 150s, it's a snug fit but will work. Really depends on what you want from the lights. Functional lights for fog, driving lights, or something just to fill in up close like the SD ones. If I did it again I would check out the VisionX HID ones that are small square (industrial model) with a euro beam. Not sure if they will fit for sure but they would be close....and huge brite...off road only though....
I don't have a direct link but if you searched using VisionX.com something would come up.
jrc
96 XLT F350 CC ZF-5 355's 16x8 aluminum rims 285/75R 16 Dick Cepek F-C IIs. T Wildman programs, Map regulator, DIY CCV & HX mod, TDS exhaust brake, BD gauges, downpipe 4" exhaust, custom SS resonator, LUK, SD I/C, Custom Shackle Reversal, Custom Moose Bar and Velvet rides, RS 9000x shocks, Custom Aluminum Drybox/fuel tank, Swamp's Baby Injectors, SD Hpop, DIY Oil by pass filtration, DIY electric fans, DIY E-Fuel system, Lighting by VisionX, LightForce and PIAA and other stuff.
http://community.webshots.com/user/jcart44
Jcart is offline
Old 11-05-2007, 10:54 AM   #6 (permalink)
BEECHBM69's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Jcart</div><div class="ubbcode-body">or something just to fill in up close like the SD ones. </div></div>
I actually used SD lights for this very purpose. They work very well for what I use them for. And it's somewhat of a novelty item when people recognize what they are.... [img]/forums/images/%%GRAEMLIN_URL%%/cool.gif[/img]
Pics in sig.
Dan
97 F250, SC, LB, 4x4, 7.3 PSD,E4OD, 4.10, Autometer Gauges Warn Manuals, Tru-cool 4590. Tymar Intake. Super Duty Driving Lights. 285/75/16 Pro Comp A/T's, DIY Tow Hooks.Canvas Soft Topper. DPP downpipe. A work in progress.pics
BEECHBM69 is offline
Old 11-06-2007, 09:29 PM   #7 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: BEECHBM69</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Jcart</div><div class="ubbcode-body">or something just to fill in up close like the SD ones. </div></div>
Pics in sig.
Dan </div></div>
ya your set-up looks real clean.
Old 11-06-2007, 10:24 PM   #8 (permalink)
ThreeStarJR's Avatar
Gilroy, check out this thread...lots of good info..... lights
Jim
529/1220
10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
#3
ThreeStarJR is offline
Old 11-06-2007, 11:56 PM   #9 (permalink)
A lot of good tips, thanks guys keep the coming.
Old 11-07-2007, 10:43 AM   #10 (permalink)
Invader1's Avatar
I have these in my front bumper,(see my sig). Only when I bought mine, they were 960's and had higher wattage bulbs. The housing is the same, just with lower wattage bulbs.
They are very functional and you could put any wattage bulbs in them that you like. I use 90 watt bulbs and they light up the road very well. When I drive with the driving lights on, about 1 out of every 40 cars will flash their brights at me. I just flash my brights back. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
Invader
97 F250 XLT SuperCab LB E4OD
Mod's: Tony Wildman 4 page chip, Stealth HPOP, Beans fuel system, JoeServo high voltage IDM, Swamps 175/173 injectors, Hypermax H2E turbo and inter-cooler, open element air filter, Down pipe, open exhaust, exiting in front of rear wheel, with dynomax bullet race muffler. Home made, dual stage, Propane system, ATS TripleLoc billet steel Torque converter. Imperial Shift Kit, BD PressureLok. Mag-Hytec tranny pan and rear cover, ARB air locker in the rear. Cervinis Fiberglass ram air hood ,(part # 112). 4" Superlift lift kit, Air lift air bags with Smart air auto leveling system in the rear, Full instrumentation, Grant steering wheel, on board air system. Putco skins stainless bed rail/tailgate covers. Stainless Nerf bars. Billet front grill and clear lenses all the way around.
My Truck Pic's
Invader1 is offline
Old 07-27-2008, 03:50 AM   #11 (permalink)
redneckabbott's Avatar
Send a message via AIM to redneckabbott
old post but did putting lights in the front bumper not hurt turbo airflow? Wouldnt expect it to hurt much if any at all but curious before i block some airflow.
1997 F-350 CC LWB 4X4 5spd 4.10 gears: South Bend Clutch, 285/75 Terra Grapplers, 16'' Eagle Alloys, Clear Headlights, Bull Hide bedliner, Tymar Intake, 3" Down Pipe, 4" Straight Exhaust, Sony Head Unit, 10'' JL W6, 500w JL amp
redneckabbott is offline
Old 07-27-2008, 11:53 PM   #12 (permalink)
169stang's Avatar
My Photos: (5)
I just finished up mine. I put in some 100W KC lites I purchased from 4wd Hardware-$98 for the pair. Very bright.
1997 F350 7.3L DI diesel CC duelly
Tymar 3" DP, 4" exhaust, intake. Gutted EBPV, modified pedestal. True-Cool Max tranny cooler. Tony "Wildman" 4 position chip. Autometer gauges
2005 Mustang GT street/drag car. 76MM turbo 800rwhp
1996 Mustang Cobra Mystic #93
1969 Mustang Coupe-302
http://good-times.webshots.com/album...ost=good-times
169stang is offline
