Old 12-14-2008, 04:41 PM   #1 (permalink)
ohiopsdx17's Avatar
LMC truck body parts
Has anyone here dealt with LMC. Do they have quality parts?? Im looking to buy the wheel well arch panels and front fenders from them. Also how about there replacement interior parts?? Thanks
1997 F-250 Heavy Duty 4x4 Off Road EX.Cab Short Bed. -4" Suspension Lift - 4" exhaust - 3" Downpipe - 5" Stacks - 10Kmod - Shimmed FPR - Home made air intake - Rosewood Stage 1's - TS 6pos Chip - Dana 60 Swap - 4:10 gears -
ohiopsdx17 is offline
Old 12-14-2008, 09:53 PM   #2 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I have bought a few things from them with good results. I would tink that inner fenderwells would be a sure thing from them.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 12-14-2008, 10:05 PM   #3 (permalink)
diesel_brad's Avatar
Their parts are of good quality. Do yourself a favor and get the whole bedside not just the wheel well arch.it takes less time and you will have almost no body work. Its just a matter of drilling out spot weld and welding them back on. JMHO
86 F250 6.9 4spd 4x4 6"+37's(coming soon,D60,zf5 and 315s)
00F350 Xcab Dually 7.3.ZF6, 4x4 SOLD
94 Lightning, Full Bassani exhaust,underdrive pullys, CAI, new paint w/ stripes
96F350, 4dr, 460, ZF5, 6"lift, 35"thornbirds, banks torque tubes, 3"custom bent exhaust, bbk throttle body, stull grill, clear front turnsignals, lund visor, 3.55gears
1980 F350 PULLIN TRUCK, 429, C6, detroit lockers f&r 10.25/D60 33' BFG muds
diesel_brad is offline
Old 12-14-2008, 10:39 PM   #4 (permalink)
ohiopsdx17's Avatar
Brad I would love to get the full bedside but I just can't afford them. Im an experienced welder so it shouldn't be to hard to fix. Im also ordering the drivers side floor pan, rockers, grille, headlight bezels and headlights from them.
Old 12-15-2008, 12:27 PM   #5 (permalink)
I just welded in some new LMC rear bed corners and they are OEM quality as far as I can tell. I also ordered a new dash bezel from them a few years ago and it was an actual ford part.
'96 F250 CC SB 4X4, BTS E4OD, D60, 4.10's w/ARB's, 4" skyjacker lift, BFG 37x12.5r17's, Bilstein 5150's, Tymar intake & downpipe, BDP 6 pos chip, BDP Stage 1's, D66 Turbo, 17* HPOP, SD Intercooler, Buckstop bumper w/M12000, piller pod gauges, CCV mod
Truck
Mtntruck is offline
Old 12-15-2008, 06:48 PM   #6 (permalink)
The only prob is where are you old sides going to rot next. Prob right below your taillight where it is boxed(or worse right next to where you welded in the patch panels. I understand the money issue but it would seem like a waste to do all that time and money only to have it rot out somewhere else on the bedside in 6 months. Hell just spray foam it till you can afford sides
Old 12-15-2008, 11:25 PM   #7 (permalink)
ohiopsdx17's Avatar
haha if only there was enough left to spray foam. lol. I found a rust free bed in TN which is about 6hrs away so we will see how much the guy wants for it??
Old 12-16-2008, 05:39 AM   #8 (permalink)
Be carefull of "rust free" beds too. As you prob know. One day no rust. A month later there is blisters all over. Would suck to pay 500 for a clean bed to have it turn to rust.
Old 12-16-2008, 06:23 AM   #9 (permalink)
ohiopsdx17's Avatar
If I do buy a rust free bed I plan on taking it down to bare metal before it ever sees the road and then repainting it inside and out.
Old 12-19-2008, 12:23 AM   #10 (permalink)
The only body parts I'd buy are made either by Ford or Tabco. Welcome to Tabco
Since you can't get just replacement wheel well arches from Ford (only complete bed sides) I guess that narrows it down. I would not buy LMC's imported sheetmetal parts, as they are only coated with e-coat, and are not made from galvanized steel. OEM Ford and Tabco parts are made in the USA from galvanized steel, and it's the the best corrosion protection available. Just be sure once you cut out the old parts, to sand blast any remaining rust, and coat everything well with a good epoxy primer.
Hope it helps,
K.N.
3/94' F-250XL 4x4,PowerStroke Diesel power, DP-tuner flashed to MLE1, H.D ZF 5-Spd. w/SBC Con-O clutch, Std. cab, 3.55, Mobil 1 syn. in T-case, Castrol TranSynd in tranny, Chevron's DELO 400 & Fleetrite Anti-Foam Additive, Valvoline's Durablend 85w-140 in rear, LT265-75R-16 Goodyear AT/Ss, 309,000 miles, Ported Snorkel & Tymar Intake, TS 6-pos chip, Banks 3" 409 Stainless Downpipe, S.D. 409 Stainless Cat Delete, Hidden Hitch, Stock
http://community.webshots.com/user/kn94psd
K.N.94PSD is offline
