Old 09-29-2006, 02:07 PM   #1 (permalink)
looking for a sub box for my CC
Time to get subs. I'm thinking about getting 2 10" memphis subs. I cannot find a box for my crew cab anywhere. Friend of mine who works at a car audio place told me i was probably going to have to get one custom made.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
TimMiller is offline
Old 09-29-2006, 02:52 PM   #2 (permalink)
Re: looking for a sub box for my CC
I just went and got a sub and amp from Circuit City and put it behind the rear seat. Go to my pics and check it out.
1997 Ford F250 Crew Cab 4x2 with 7.3L. Tymar Intake, Bores bumper guides, J.C. Whitney chrome cab lights, Steel Horse Stainless Steel grab handles, Hornblasters 3 chime chrome train horns, 3" to 4" downpipe/5" exhaust into a Walker BTM/6" polished Stainless Steel tip. ISSPRO boost/pyro/tranny A-pillar gauges. Pioneer AM/FM/CD player, Polk speakers, kicker amp and 12 inch sub behind the back seat. DP tuner F-5 chip with stock,80hp tow,80hp econo,100hp, and smoke programs. Sonnax/Tricumulator valve and springs transmission shift enhancement kit.
My truck pics
SkidRowe38 is offline
Old 09-29-2006, 03:14 PM   #3 (permalink)
My Photos: (38)
I got mine here, top notch box and fits perfectly.
Mine is an 02 though.
www.subzeromfg.com
some stuff
14.8 @ 90
gregrob is offline
Old 09-29-2006, 04:02 PM   #4 (permalink)
MarkEkberg's Avatar
My Photos: (13)
If you have captain chairs get a center console box. I did mine that way. The new console is higher with storage and everything.
Bought it a few years ago with insulation and hole cut in it from a stereo place. I put a fosgate 12" in it. Sounds good and it functional as well.
MarkEkberg is offline
Old 09-29-2006, 05:03 PM   #5 (permalink)
I have bench seats. I don't mind getting a custom box made, i just don't want to if i don't have to.
Truck pics
Old 09-29-2006, 05:07 PM   #6 (permalink)
Skidrowe38,
does that sub box just sit there, or did you mount it to the floor?
1997 F250HD Powerstroke CC, short bed. Toyo 285's, Tymar intake, Tymar 4" exhaust, Autometer 3-pod, PML Diff cover, Redline gear oil, Tru-Cool #4950 tranny cooler, Tymar HPX Crossover, Bilsteins, Hawk pads.
VoodooSmooth is offline
Old 09-29-2006, 05:14 PM   #7 (permalink)
I HAVE A CUSTOM BOX WITH 2 10'S IN IT IF YOU ARE INTRESTED PM ME.
97' F-350, 4dr, 4x4, 5spd. 00' Lariat heated seats, Tymar intake, BDP stage 2's, Humped HPOP, Super duty turbo with ATS compressor side and banks 1.0 exhaust, 3 inch intakes, Tony Wildman tuning, California kit, Banks intercooler system, fleetguard 777 oil bypass, 5 inch exhaust, LUK Cermatallic clutch, MB Gel cells. 427.3/813.1
AKA: 00GAGUY
Sold - 2000 F-250 (GOODBYE MY LOVE)
00GaGuy is offline
Old 09-29-2006, 08:03 PM   #8 (permalink)
markccalhoun's Avatar
Dave over at DI on 1960, West of 249, on the South side of 1960, has a stereo store in his shop. The have "behind the back seat" sub enclosures on the floor, ready to buy. They also make custom boxes.
Oh, I found their card! Just spent 30 minutes looking for Dave's userID and remembered I had one of the stereo people's cards! Frequency Car Audio & Dealer Services 10541 FM 1960 West, Suite 101, Houston 77070. Talk to AJ. at 713-291-1871. or Singh at 713-240-8198. or the store # 832-912-7600.
Later,
Mark
1997 F-350, 4x4, CC, LB, BTS E4OD, 3.55 Gears. Bean's Stage II 160cc Injectors With Custom EDM'ed Nozzels. Tony Wildman 6 Position Chip. Dieselsite H2E; 203° Thermostat; Tru-Cool Max LPD-47391, V-10 Trans Cooler. DIY Fuel System - 10 Micron Pre, Bosch 984 Pump, 2 Micron Post, Aeromotive Regulator, pressure safety switch. Tymar Intake. Full Boar 4" Open Exhaust w/3" Down Pipe. Warn Premium Hubs. Autometer Pro-Comp II Trans Temp and Pyro, Banks Boost Gauge. HPO Crossover Mod. Dual Tensioner Installed. CCV Mod.
UPCOMING MODS: 17° HPOP, Turbo Timer
http://community.webshots.com/user/markccalhoun
"What is a weed? A plant whose virtues have not yet been discovered." Ralph Waldo Emerson
Mensch tracht, un Gott lacht” (“Men plan, and God laughs”) -Yiddish proverb.
markccalhoun is offline
Old 09-29-2006, 08:42 PM   #9 (permalink)
I know about them. Just my guy can get pretty much anything they can. I was plannin on stoppin by there tomm to talk to Aj.
Truck pics
Old 09-29-2006, 09:52 PM   #10 (permalink)
Mark, where did you get the box you have? Do you remember a brand?
Diesel Mechanic 28 yrs
Garbage_Mechanic is online now
Old 09-30-2006, 09:25 AM   #11 (permalink)
Briansshop's Avatar
Tim, I've got a small Kenwood sub behind the rear seat.Fit great,and the seat still goes all the way back.It makes some good bass for what I listen to,won't make that booming,rattle other cars & houses bass like the "brothers" though.There's a pic in my album.
Brian
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,open intake,SD IC,1.0 Housing,Pedestal Mod,Gutted EBPV,dp,5"no muff, Baumann TCS controlled e4od,"I LOVE that thing"!,Baumann VB kit,UCC Custom Billet T/C-VERY low stall speed,Mag-Hytec pan,dual True-Cools,remote filter,3 pos.T/C lock-up switch w/LED,Elec.fans on trans.& engine w/Derale adj.stats,Gauges,Kingpin D60 w/Lock Right,Detroit Locker in the 10.25,4.88s,4" Nat. springs w/ORU-SRK in fr.,crossover steering,10" Atlas springs in rear-no blocks!,Bilstein 5100s,38" PJ Dirt Grips on 16x12" M/T Classic Locks w/Centramatic balancers,Warn hubs,Powerslot rotors,Hawk pads,Can-Back canvas top.
http://s77.photobucket.com/albums/j70/Briansshop/
Just getting broken in, 50,000 miles!
Briansshop is offline
Old 04-16-2008, 05:03 PM   #12 (permalink)
Just sits in there. sorry for the long wait to the reply. Been out to sea and just got back.
My truck pics
Old 04-16-2008, 10:36 PM   #13 (permalink)
I am making mine myself:
the openings on the left an right is for the subs, and the center is for the amp.
1996 Ford F350, 7.3 PSD, crew cab, 8ft bed, 4x4, 5 speed manual, 4.11 gears. 184,000 miles. 3x4" down pipe, 4" exhaust with 5" polished SS tip, gutted EBPV, chrome nerf bars, autometer ultra lite pyro and boost gauges, alpine cd player, alpine speakers,garmin GPS.
"Real trucks have 3 Pedals, 2 Sticks, and No Spark Plugs"
gilroyracing is offline
Old 04-17-2008, 12:55 AM   #14 (permalink)
97smoker4x4's Avatar
I just installed an infinity bass link which is a powered sub box w a 10" sub and 2 10" passive radiators. Fits easily behind the seat of my reg cab obs, and sounds good, more bass than I will ever need in the cab.
97smoker4x4
97 f-250 4x4 rebuilt (by me) 7.3 & turbo/quick spool turbine housing, superchips programmer, dnpipe, 3gauge pod, pi converter, stancor
97smoker4x4 is offline
Old 04-17-2008, 01:01 AM   #15 (permalink)
sorry I dont have a pic of the box installed behind my seat, here it is on infinity's site, my seat still goes all the way back with the sub installed.
Infinity - Car Audio
97smoker4x4
