Old 03-26-2008, 11:06 PM   #1 (permalink)
PSDfreak's Avatar
Looking for Tool Box (Short Bed)
Everything is listed by measurement and not make/model which makes sense. I don't have access to the bed to take measurements right now so was wondering if someone could help me out or let me know what they are. Its for a regular styleside short box bed.
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is online now
Old 03-26-2008, 11:10 PM   #2 (permalink)
Styleside is like the indent just past the cab. The only difference on the long bed vs short is the length of the bed not the width.
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Racerxautomotive.com for your upgraded E4OD/4R100 needs
BlindViper is offline
Old 03-26-2008, 11:28 PM   #3 (permalink)
DIESELDUTTON's Avatar
I could measure mine tomorrow, but I bought a Lowes brand (Kolbalt, aluminum) it sits below the bed rails and has alot of room.
Frank
http://community.webshots.com/user/dieseldutton
2004 Pitbull Motorsports rigid chopper
121 TP 130rwh 250 avon
04 CRF250 mine
02 CR80 sons
03 XR100 daughters
425 Polaris magnum
500 Polaris sportsman and 300 lakota everyones
1998 27.5 Wilderness 5th wheel
DIESELDUTTON is offline
Old 03-26-2008, 11:30 PM   #4 (permalink)
PSDfreak's Avatar
I believe styleside is the "regular" bed as opposed to the stepside. Im lookin for a chest style (below the rails)...Just want to make sure it'll fit and clear the wheels wells (being a short bed)
Old 03-26-2008, 11:40 PM   #5 (permalink)
murrays discount auto parts for 125$
1997 F-250 Heavy Duty 4x4 Off Road EX.Cab Short Bed.
-4" Suspension Lift
-4" exhaust
-3" Downpipe
-5" Stacks
-10Kmod
-Shimmed FPR
-Home made air intake
ohiopsdx17 is offline
Old 03-26-2008, 11:47 PM   #6 (permalink)
PSDfreak's Avatar
Thanks for the tip, but I am still looking for a way to find the correct box size.
I was at Tractor Supply today and all of their boxes are by dimension, no make/model. I know I will need one that will fit width wise as well as one that will clear the wheels wells in the bed being that its going into a shortbed. They have a few different sizes that are very close...
Old 03-27-2008, 12:11 AM   #7 (permalink)
BadDogPSD's Avatar
Casey, I'll call you in a few and measure what you need...
1997 F250 4x4 Crew Cab PSD; Dana 60; Sky RSK w/SuperDuty springs.
BadDogPSD is offline
Old 03-27-2008, 12:35 AM   #8 (permalink)
PSDfreak's Avatar
Thanks for the call Craig...got the measurements!
Old 03-27-2008, 09:08 AM   #9 (permalink)
Any box that says full size will fit. Whenever I went shopping for a box It always says for fullsize pickups. Most boxes will only come to a little bit more than the middle on the bed rails too so don't expect to find one that goes edge to edge.
-4" Suspension Lift
-4" exhaust
-3" Downpipe
-5" Stacks
-10Kmod
-Shimmed FPR
Old 03-28-2008, 03:03 AM   #10 (permalink)
Jcart's Avatar
PSD....,
How did you make out? I had one made that is 60"wide X 25" high and 24" deep. The bottom 10" is a fuel cell and the top 15" is a dry box. Also had it configured to fit a SD box inthat I had the bottom sides beveled at 45 degrees. Have pix in sig.
jrc
96 XLT F350 CC ZF-5 355's 16x8 aluminum rims 285/75R 16 Dick Cepek F-C IIs. T Wildman programs, Map regulator, DIY CCV & HX mod, TDS exhaust brake, BD gauges, downpipe 4" exhaust, custom SS resonator, LUK, SD I/C, Custom Shackle Reversal, Custom Moose Bar and Velvet rides, RS 9000x shocks, Custom Aluminum Drybox/fuel tank, Swamp's Baby Injectors, SD Hpop, DIY Oil by pass filtration, DIY electric fans, DIY E-Fuel system, Lighting by VisionX, LightForce and PIAA and other stuff.
http://community.webshots.com/user/jcart44
Jcart is offline
