Old 11-20-2005, 08:57 PM   #1 (permalink)
lower egt's
while cruising in my 97 i usually run bout 900 degrees but if i barely get on it at all i can get 1300 easily, makes it no fun when racing a cheevy and winning but have to back out of it cause your creepin up on 1400 ouch, what can i do to lower my egts, this is the 97 in my sig [img]/ubbthreads/images/graemlins/shrug.gif[/img]
95 F250 PSD-auto, ext cab, 2wd, k&n drop in, faubiam motorsports trans.
02 F350 PSD-4dr, 4X4, drw, auto, line-x, sirus sat. radio, single position TWildman Chip, Napa 6637 Open Air Element, de-clawed, sonnax and tricumulator, ebpv delete, faubian motorsports trans.
pawsranch3 is offline
Old 11-20-2005, 09:06 PM   #2 (permalink)
Re: lower egt's
intercooler
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 11-20-2005, 09:24 PM   #3 (permalink)
My Photos: (5)
Re: lower egt's
Tony knows not moderation.
1999.5 cc dually
69 mustang, 472", c/4
9 sec alky injected bracket bomber....
529" in the works as we speak
Richter69 is offline
Old 11-20-2005, 10:22 PM   #4 (permalink)
Re: lower egt's
his burns are awesome i just need to run cooler how much am i lookin at for an intercooler
Old 11-20-2005, 10:50 PM   #5 (permalink)
PSDfreak's Avatar
Re: lower egt's
for a intercooler out of a super duty, they usually run around $200 or so on Ebay...there's a guy on this site that sells a kit with all necessary plumbing for around $595 (i think). Seems like that the cheapest route to go for a good working effective intercooler.
Good Luck,
Casey
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is online now
Old 11-20-2005, 10:51 PM   #6 (permalink)
Re: lower egt's
just an intercooler used I found mine out of a '99 PS for $200 but I don't know what pipes, boots, and clamps cost [img]/ubbthreads/images/graemlins/shrug.gif[/img] haven't got there yet
good luck
2000 Crew Short F250 4x4 Lariat
White over Ebony
Limo Tint all the way around
F350 Blocks- 1 1/2" Shackle kit up Front
Eagle Alloys
265/75/16 Toyo Open Country M/T's
5" straight pipe
~sold~
1992 Ford F250- excab- 4x4- Canary Yellow- 12 valve Cummins Swap- NV4500 5spd-
"Ford Makes It-Cummins Shakes It"
Rip Rook's 4inch straight pipe exhaust
~custom~ fuel plate
Pump Timing Set to 17*
Isspro Pryo and Boost Gauges on the Pillar
rolling on 285's Toyo M55's
bananaboatford is offline
Old 11-20-2005, 10:53 PM   #7 (permalink)
My Photos: (5)
Re: lower egt's
I have never really had an issue with heat, even with some of his nasty stuff. Been a few times pulling I had to back out but trying to maintain 80 on the pike with my rig loaded going up a long grade, but its never really been an issue. I would guess a man would need to spend around 5-6 hundred bucks for a pieced together system. I had a really nice banks set up andnever put it on, in fact I sold it.
1999.5 cc dually
Old 11-21-2005, 12:04 AM   #8 (permalink)
Rtxcoon's Avatar
Re: lower egt's
my egts are REALLY high too...LOL!
luckily, I got a 2002 intercooler BRAND NEW, off ebay last week for
$120 shipped (I got lucky), so am looking to get the pipes and other
stuff together and set it in....
1997 F350 CC 4x4 Auto
a little over 400 at the rear wheels
thanks to Wildman, Bean, Cass, Luke and Visa
www.northtexaspowerstrokes.com
Truck Pictures
Truck Movies
Rtxcoon is offline
Old 11-23-2005, 05:35 PM   #9 (permalink)
ThreeStarJR's Avatar
Re: lower egt's
Yea me too RTX, lucked up on a 6.0 cac (used) for under 130.00 bucks shipped off of e-bay.....now got to create the funds for the pipes, boots and the y-pipe...and find the time to install.....it never ends [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
Jim
529/1220
10 17 08
BDP "DOMINATOR 66,"
BDP/Casserly's stage 3 HI-BIRDS
BDP Fuel system
Hypermax rods
Caltracs
96 F-350 CC, XLT, drw, 2wd,...
TRUCK PICS AND ALBUMS
#3
ThreeStarJR is offline
Old 11-23-2005, 06:38 PM   #10 (permalink)
Re: lower egt's
your sig. doesnt mention a gut CAT or EBPV. if you havent then theres at least 100 degrees and on the cheap as well.
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
<span style="color: #CC0000"> #26</span>
krowell is offline
Old 11-23-2005, 07:03 PM   #11 (permalink)
My Photos: (5)
Re: lower egt's
you need shorter gears, that would help it a bit as well.
1999.5 cc dually
Old 11-24-2005, 12:41 AM   #12 (permalink)
Rtxcoon's Avatar
Re: lower egt's
gears are on the list as well [img]/ubbthreads/images/graemlins/smile.gif[/img]
Truck Pictures
Truck Movies
Rtxcoon is offline
Old 11-24-2005, 12:46 PM   #13 (permalink)
Re: lower egt's
well just won a 01 intercooler for 180 it comes with the pipes too. are the pipes useable, would i just need a y pipe and boots, what sizes, how did this affect your egts. btw my cats gone but the ebpv is not gutted what is the easiest way to do this... thanks guys
Old 11-24-2005, 09:28 PM   #14 (permalink)
WormDrowner's Avatar
Send a message via ICQ to WormDrowner
Re: lower egt's
Hey Pawsranch3,
Here's a link that might be of some help with installing that aftercooler: http://www.exhaustbrake.com/inner-home.html
"You can all go to Hell. I'm going to Texas." - Davy Crockett
1996 F-250 Supercab PSD with Edge Evolution, Grand Rock Powerflow 4" exhaust, AFE Stage II Intake. Isspro Gauges.
1996 MB C220
WormDrowner is offline
Old 11-25-2005, 09:19 AM   #15 (permalink)
Re: lower egt's
get your foot out of it!! oh wait thats not any fun.
INTERCOOLER.
97 F250HD 4X4 210K MI
4 LINKED FRONT AND REAR ON AIR
00 F350 4X4 CC
RIP CHRIS. 03/09/05
http://community.webshots.com/user/barebackjake
barebackjake is offline
