Well i'm making progress, all the new tool boxes finally came in . I had to cut out the lower face and the support rod for the door closer of the front and rear compartments to get the tool boxes in thay just fit the door closer support just touches the top of the boxes. I cut 2 more holes for lights and bought new fuel fill holders. I have deceided to paint and clear the body than paint the chassie than mount ....I cant take my truck apart until i know it's not going to snow....check out the pix utility body pictures from trucks photos on webshots
97 F350 dulie knapheid utility body 7.3 PSD 4x4 8611 LP BLIZZARD plow 8' ss sander diomd plate aulimiumn top boxes ladder rack whalen9004 strobe 6 under cover strobes on board air compressor air ride front and rear spin on trany filter 28 gvw trany cooler w/ fan modified ac condencer as trany cooler down pipe power windows and locks piller gauges piro ,bost ,top shelf incloods air pressure gauge trany temp strobe control, sander control and cb 83000 miles 2004 style headlights clear corners and turns plug in jumpers , grill painted to match truck visor over windshield.5" duel stacks,magnaflow muffler,ss simulators,8 way power leather buckets,2002 dodge console,water filter,5 electric fans,air Horns,215 amp altonator,gruip 31 batteries,tymar intake,5200 lbs rear springs http://community.webshots.com/user/earnies2
Got all the tool boxes installed all the panels i had to cutout repaired Thursday i primed and Friday i painted the utility body with 4 coats of urethane flame red paint and 3 coats of clear ....the paint came out excellent I hope the body comes out as nice.... I also painted my visor with silver metalic basecoat and cleared it also......I replaced my windshield (rock chip and leaking)and both door windows(scrached from sand) also replaced all the window rubbers on both doors. and painted my ladder racks.....now i can start to take my old body off and prep and paint the cab,,,,
It's almost done ...body is on stacks are in Running boards on led lights on the only thing left is the hitches,spray in liner,and stripes and lettering.....I cant make up my mind on the striping before it was boxed with Immitation gold paint the sign shop says that is the way all the old school contractors did thier trucks he susjests i do somthing differant the truck is red with a metalic silver visor....stacks over sander extension pictures from trucks photos on webshots this is a pix of the box striping I probbally stripe with silver metalic looking for susjestions ????
Looks good man .Keep up the nice work.Got a question for ya if you dont mind.I noticed in one of your pics your truck has electric fans?Care to share some info on that set up?
Shure the truck has 5 fans 3 are cooling 1 is for the AC and the last one is for the trany cooler, the 3 cooling fans are controled by a ajustible fan controle relay that sends power to 3 40 amp relays that opperate the fans, I also have a manual over ride switch in the truck.... The AC fan runs whean the AC is on.... and the trany cooler fan is actavated by a switch in the truck....thay have been in use for 2-3 years with no real problems, I didnt have the over ride switch at first but I was pulling a excavetator on a trailer up a big hill on a 90+ degree day and the temp started to get up thier so i put the switch in to put the fans on early and avoid any problems... I also belive my MPG is better and she heats up a lot faster here are some pix #15,#18,#19 are the fans and relays and #30 shows the switches
..truck pictures from trucks photos on webshots
Their is no junk yard in my truck all the fans are high CFM fans from summit racing........Remember if you put junk into anything evenually it becoms junk too....never use junk in somthing you need to be dependable....
