Old 12-25-2005, 11:27 PM   #1 (permalink)
Mod Limits
I want to buy a set of injectors in the near future, and I am debating on what injectors to buy. I either want to go with a stage 1 (160 cc) or stage 2 (160 cc edm'd), and I am curious as to how far I can go with what I am willing to do. I would not be against going to big oil if I have to, or a bigger turbo, but I think my limiting factor is going to be the stock 99 intercooler. There is NO way I can go to a bigger intercooler, so I don't want to go with a bigger injector than I need. I also don't think I can go any bigger than a 3 1/2 inch down pipe. I don't want to use any drugs on it. What do you guys think?
Thanks for the help!
Tim
"Better to be hated for who you are, than loved for who you're not." - Van Zant
My Truck 1972 F-350 4x4 Extended cab 14-36 Swampers, 97 Powerstroke, 4 position chip with custom tunes, 3" downpipe, 5" exhaust, 99 intercooler, DIY E-fuel, Dana 60 front, 70 rear, lockers in both ends.
<font color="blue">72 POWER STROKE</font> <font color="red"> INTERIOR PICTURE </font> <font color="blue"> ENGINE PICTURE </font>
Wifes' Grocery Getter 99 F-250 SD 4x4 XLT Lariat 4 door. 7.3, Auto, 4 pos Bullydog chip, 3 1/2" downpipe, 5" straightpipe, Genuine Tymar, Stage 1 Monsterbox, 33-12.50-16.5's
72Pstroke is offline
Old 12-25-2005, 11:38 PM   #2 (permalink)
Re: Mod Limits
Dude, you still have the coolest truck in the world. [img]/ubbthreads/images/graemlins/grin.gif[/img] I love that thing!!
That being said (again), you can get away without big oil on both, but it would be benificial. I am just running an SD pump on the Stage I's and it made a load of difference over the stock pump. You could still run it on the II's but they will definitely be happier with oil.
I think the SD cooler will be just fine, just look at tubzz's signature. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
SD-IC,GTS-MOTORSPORTS 3"Y &amp; PIPE KIT,4"EXSHAUST/ULTRA-LITE GAUGE/203T-STAT
1/4 mile 13.35 @ 100.11 on #2
The turbo, IMHO, will want to be upgraded either way. I don't have my intercooler in yet and I am seeing 36psi if I try. I will probably expect closer to 30 after the intercooler is in, and that is still more than I am comfortable with, since I do not plan to upgrade my turbo and intend on keeping it alive as long as possible.
Stage I's you'll be just fine with your stock turbo and HPOP, but at least I'd do the SD pump.
IMHO from all I've gathered, to better support the Stage II's will involve more fuel, oil (definitely will want at least the SD HPOP), and a turbo, then that will probably give means for head studs.
Those are my concerns personally about the II's over Stage I. I still hope to get them someday and just see what I can do with the stock turbo, fuel and my current oil, as I do not plan to upgrade them (fuel maybe).
FWIW, the Stage I injectors with programming are already an unreal difference over stock. [img]/ubbthreads/images/graemlins/smokin.gif[/img] I know you will be happy there. But, or so I hear, the II's are that difference all over again. [img]/ubbthreads/images/graemlins/grin.gif[/img]
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
ryanPSD is offline
Old 12-25-2005, 11:42 PM   #3 (permalink)
My Photos: (9)
Re: Mod Limits
I think your 99 i/c will work with about whatever you want to do. Tubzz has stage 3 injectors with the Stealth pump with a Super Duty i/c. I put BDP stage 1's in my truck and the stock turbo lasted 4 months, but it had 140,000 on it when the injectors were installed. With the stock HPOP I could only stay in the throttle for about 4 seconds till I got a CEL. But now I have a H2E turbo,BTS dual HPOP, and BDP stage 1's and everyhting is working well together.
Chris
97 F-350 cc srw 4x4,White,cab hi Leer,E4OD,4.10's,Hypermax H2E,Banks intercooler,BDP stage 1 injectors and fuel system,BTS tranny,BTS twin hpop,4 postion chip programmed by Cale,Skyjacker 4" system,35" BFG's W/Welds,Rear air bags,Hayden 26,000 trans cooler,4" exhaust,Tymar intake&hx mod,Amsoil dual bypass filter w/Amsoil syn. oil, and diff. lube, Ford aic, Joe Servo idm.
353 HP 677 TQ on BTS's dyno at 0 correction
SLAPS Treasurer
Member of FOKISD
<font color="red"> #5 </font>
Truck pics at http://community.webshots.com/user/ytee1100
ytee is offline
Old 12-26-2005, 02:09 PM   #4 (permalink)
Re: Mod Limits
That truck rocks would love to have that beauty!!! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
1996 F-350 4X4 SRW w/285/75R-16, 3.55 Loaded, AC,Ford AIC Diamond Eye 3" downpipe, Warpspeed 4" exhaust. Tony Wildman two position chip with Tow/Race. Autometer Phantom's Trans/Boost/Pyro New <font color="red"> JASPER E40D w/AMSOIL TORQUE DRIVE ATF </font> <font color="red"> AMSOIL Series 2000 75w-90 </font> gear oil in diffs, <font color="red"> AMSOIL 15W-40 Heavy duty </font> with <font color="red"> AMSOIL DUAL BYPASS FILTERS </font> , Stanadyne Performance, Napa coolant, Napa coolant filter(with SCA)4071, <font color="red"> Open air intake</font> ,<font color="00FF00"> keyless entry mod, tank mod, and pedal mod(big gain). </font>, Marinco block heater plug. Alpine 9811 with Kenwood six disk changer in back of seat and Poineer three way speakers .
MPG. around town mixed 13-16winter summer
Highway Best 20.1(unloaded)65-75mph
To do list- Babies/BTS
JonG is offline
Old 12-26-2005, 09:04 PM   #5 (permalink)
Banned
Re: Mod Limits
mod limits all depend on you wallit i guess.
if your not against a bigger turbo and maybe big oil.i would do the stage2's. you won't be disapointed either way and the SD ic will be fine.i have a 6.0 IC in the kitchen to put in mine not forsure i need it but it was cheap so why not.
and that is a very sweet truck you have.
tubzz is offline
Old 12-27-2005, 12:29 AM   #6 (permalink)
Re: Mod Limits
Thanks for the compliments, guys; I appreciate it a lot.
I guess to clarify the question a little bit, will the 99 ic flow enough air to clean up the Stage 2's? The head stud comment brings to mind another question. Has anyone ever tried to change to head studs without removing the heads? Could it be done one bolt at a time, without causing the head gasket to leak? Just a thought.
Thanks for the help.
Tim
Old 12-27-2005, 01:18 AM   #7 (permalink)
Dieselfever78's Avatar
Send a message via AIM to Dieselfever78
Re: Mod Limits
Tim
You'll want to talk to Travis(MoreMPH) about that, I believe he has done it.
-Michael
Michael Paul
1995 F250: Regular cab, 7.3L PSD, 5-Speed, 4x4, 4.10 LSD, gauges, 2L chip, injectors, turbo, 4" downpipe - 6" tip, clutch, fuel system, Medium oil, Headstuds, Valvesprings, Cab lights, Dana 60 - New Look Soon!
1995 F250: Regular cab, 7.3L PSD, 5-speed, 4x2, 3.55 open, Intake, Downpipe, 4" exhaust, clutch, 2L chip, short throw shifter - To do list!
My Webshots
Dieselfever78 is offline
Old 12-27-2005, 07:34 PM   #8 (permalink)
Banned
Re: Mod Limits
will the 99 ic flow enough air to clean up the Stage 2's? <font color="red">all in the programming and a bigger turbo </font>
The head stud comment brings to mind another question. Has anyone ever tried to change to head studs without removing the heads? <font color="red">yes,i did mine with the engine in the truck not to bad of a job </font>
Could it be done one bolt at a time, without causing the head gasket to leak? <font color="red">yes but their is a seguence to tq them down </font>
check these out about headstuds
http://forums.thedieselstop.com/ubbt...amp;PHPSESSID=
any question just ask.i don't know how much room you have at the back of the heads,you might have anough to do it with out jacking up the cab maybe. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
tubzz is offline
