Just a general question. I was thinking about installing a Tymar type intake on my 97, and I started to wonder if it would really add any useful performance....
If I understand correctly, a diesel engine typically pumps in more air than it needs under most throttle conditions. The power is regulated by how much fuel is injected. If this is true, how does better breathing help power unless you are really pushing the engine to max power levels?
I usually drive around empty, so the engine doesn't have to work very hard...would a Tymar be a waste of money?
The more air you can feed these beasts the better they like it! Open up the intake and get rid of that pesky kitty and muffler, and let it breath, better low end power without a doubt, will run more efficient with better fuel milage, get the Tymar you can't go wrong!
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Then get rid of that stock smashed down pipe if you still got it, then get ready to hear the turbo whistle!! [img]/ubbthreads/images/graemlins/laugh.gif[/img]
Justin
98 12V QC, 282,000 +, 5 Speed, with a few power enhancements
SOLD
2000 F-350 XLT CC SRW CC PSD, 249,000+Miles, 6 Speed trans with Luk Con-O-FE clutch, 4" ATS Straight piped, Tymar style intake, Ready to start modding.
Meridian Motorsports Dyno Jet 5/13/2006
219 HP 457 TQ
SOLD:
Lifted 95 F-350 XLT Crew Cab Srw Lwb Psd, 268,000 + miles, 35*12.50*16.5 Trail Cutter Radial RT,4.10's, BABY SWAMPS, Humped HPOP, Homeade Tymar setup with custom 4" intake, Gutted EBPV, Modified turbo pedistal, 1.0 turbine housing, CTI AIC, Auto Meter Lunar gauges, BDP 5 position chip, Complete Alpine sound system, Automatic, Billet torque converter, Tru Cool 28,000 lb external trans cooler, Bully Dog down pipe, 5" twin turnout stacks, 6.0 intercooler with custom built pipes, Optima red top batteries, Wanting more mods!!! My webshots homepage
Bully Dog Dog Days Of Summer Dyno Pull 7/9/2005
347 hp 660 torque
By freeing up the air flow it will let the turbo spool more freely. While it most likely won't give you much peak power it will let the power come on sooner because the turbo will be able to spin up faster. Also the more air you can get in the engine the lower your EGTs are going to be. This also holds true for the cooler air you can get in it. I'd go with something like an AFE intake but it is about twice the money but it does come with a heat shield and a reuseable filter that is much better than many other reuseable filters on the market. In the end I guess you get what you pay for.
The Tymar not only gives you more air, it does a much better job of filtering which will extend the life of your turbo and motor. Some guys have had problems with the stock air box and that K&N you are running,(not sealing properly).
1997 F-350 CC lb XLT 4X4 5spd 4:10,s manual hubs new 255/85/16 Wild Country TXR shoes Westin steps Bilstein shocks Velvet Rides Phantom boost & pyrometer in A pillar water shut-off new fan clutch Tymar intake new IPR new ICP Tymar 4" turbo back exhaust no EBPV no kitty Diesel Power 3 pos flip chip new Valeo clutch @ 109750 Redline MTL & D4 in the bottom BDP Stage 1's valve cover gasgets & glow plugs @ 110650 = pushing Curtis Sno-Pro 3000 & pulling 28' Sierra 5th wheel camper & 18' Sylvan Sportmaster hooked behind camper
6.0 IC next
1994 Ford Ranger (off-road project)
God bless the American Soldier,paying the price for my freedom
Favorite Quote:
"Firearms stand next in importance to the constitution itself. They are the American people's liberty, teeth and keystone under independence. When Firearms go, all go's. We need them every hour!"
US President GEORGE WASHINGTON
