more gears - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 08-26-2009, 02:29 AM   #1 (permalink)
Question more gears
Running 95f450 powerstroke 5sp.zf trans. I do a lot of heavy hauling ,so am trying to get more gears. 2sp axle, - aux. trans. maybe???? Any ideas?
fordlanefarmer is offline
Old 08-26-2009, 02:49 AM   #2 (permalink)
Got Diesel?'s Avatar
gear vendor
Gear Vendors Under/Overdrive Ford 2-Wheel Drive Manual Transmissions.
Here's the applicable link
2011 F350 6.7 cc, sb, lariat -8611lp Blizzard Plow
2000' F-350 Reg cab 4x4 Plow truck- 8611lp Blizzard plow, FTVB, DP Tuner
2001 F-550 Reg cab 6x6 dump truck with 11ft contractors bed- 8611 Blizzard plow
2005 F-350 ex, lb, 4x4 V-10 Blizzard 8611lp plow
1999 f-250 Reg cab 5.4 western 9' pro plow
2003 Mercury Marauder
1989 Mustang Coupe- Drag car 10.96@ 126
Got Diesel? is offline
Old 08-26-2009, 09:52 AM   #3 (permalink)
SmokeyWren's Avatar
My Photos: (44)
Yeah, the modern equivalent of a 2-speed axle is an auxiliary transmission by either GearVendors or U.S.Gear. Not cheap, at around $3,000 for the parts, but lots of folks wouldn't be without one - especially if they do a lot of empty cruising.
U.S.Gear Dual Range Auxiliary Transmissions, Overdrive and Underdrive
BTW, if folks try to look up a '95 F-450, they're not going to find it. There's no such thing as an F-450 before the 1999 model year. So did you mean the regular cab 4x2 chassis cab truck Ford called the Superduty that was more than an F-350 dually but not as much truck as the later F-450?
SmokeyWren is offline
Old 08-27-2009, 12:55 AM   #4 (permalink)
Unfortunatly the F Superduties are a special gearvendors because of the driveline mounted parking brake, but it was made and I have seen them on ebay. There are two good vendors that regularly have rebuilt units on ebay, I have dealt with both.
My first choice would be a US gear for this truck, it would work just like a 2 speed axle. Since US gear was designed to go between trans and transfer case, and F SD's use a 4x4 trans, the park brake would go on the back of it. You just need a 87-97 ZF 4x4 US Gear box. US Gear is rugged and simple. Gearvendors has electroncs and is smooth but will have problems if left in OD below 20 mph, and has a limit to downhill braking as well.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 08-27-2009, 08:19 PM   #5 (permalink)
Thanks for the feedback,have picked up the same info on gearvender. I often gross out in the 35,000lb. range and was told gvs will not stand up. Am trying to get my mpgs up as well take the strain off the lower rpms.
Old 08-27-2009, 09:29 PM   #6 (permalink)
Go with US Gear. There also used to be a unit called a Mitchell that was very tough. Company is still in business, parts still available, but no new units.
Old 09-03-2009, 10:01 AM   #7 (permalink)
I think you would do a lot better with the auxilary trans. It mounts free-standing behind the trans, not attached, only the front driveshaft and rear driveshaft. Ask RLDSL on here about his. Probably a lot less than GV and I think a bit stronger.
DOWNSIDE : You will have to fabricate the mounting and have the driveshafts made. If you are not able to cut, fab. and a bit of design work. You will also have to fabricate the shifter.
ADVANTAGE ; This, with the under - direct - over plus the 5 speed will give a total of 15 forward gears plus the three reverse.
With a bit of planning and fore-thought this can be better than a handle on coffee cup. I am sure that with the loads you say, you will walk through them with the ease of a Sunday drive.
Just my opinion ( I have used this set-up)
Foxman
96 OBS 7.3 E4OD 4.10 Hand-made Tymar, CCV mod, Cruise added, bucket seats & console, saddle-tool boxes w/68 gallon tank in ctr, all LED tail & body lamps, visor, E350 bus wheels, 9ft goose-neck body
97 F 450 E4OD 7.3 Dana 80 rear w/4.63 Reyco/Granning rear susp. aftermkt leather bucket seats AIC Comming soon: 3.73 rear gearset - complete sound proof - flatbed w/sadle tool boxes and fuel tank between boxes - York on-board air - Visor - Fog lamps in 4" holes in bumper. - adding pwr window and locks adding guages = boost, pyrometer, trans temp, water temp, oil temp, oil press, diff temp and clock
foxman is offline
Old 09-03-2009, 11:49 AM   #8 (permalink)
Feedback Score: 3 reviews
IMO get some HP upgrades..will make towing way easyer than just getting gears. I'd add a bd brake to help stop.
Cary
caryt is offline
