Old 03-27-2008, 10:56 AM   #1 (permalink)
Catskinner's Avatar
More upgrades or good enough
Hi Guys- Been reading for a long time, but this is my first virgin post. I have a 97 F-250 with several mods. I mainly use it to haul the 5th wheel on vacation, and drive to work once or twice a week. The truck has been virtually trouble free since new. The mods I did really opened her up, but I would like a little more umph when pulling hills. Would you guys recommend a chip? A friend has the superchip, and he really likes it, but I dont want to hurt her. If not a chip, what would you guys recommend I do next?
Late 1997 CA F-250,Extended cab,4:10gears,Tymar intake,4"exhaust & 3.5" downpipe,Tru Cool Trans cooler,PML trans. pan,Trans temp gauge,New radiator,128,000mi
Catskinner is offline
Old 03-27-2008, 11:18 AM   #2 (permalink)
7.3addict's Avatar
i would put pyro and boost gauges in before i did much more.
'94 powerstroke, 4x4, 5spd, 3" bullydog downpipe, 4" magnaflow ss downpipe back exhaust, AFE Stage 2 intake, autometer pyro, boost, & diff gauges, amsiol fully synthetic... and I'm just gettin started!!!
http://community.webshots.com/album/563051484TytFKK
7.3addict is offline
Old 03-28-2008, 02:46 AM   #3 (permalink)
Jcart's Avatar
Hey Catskinner,
Welcome.......As mentioned get a set of gauges and install the pyro probe pre-turbo, I am guessing here that your exhaust includes an aftermarket down pipe Yes...? As it appears you have the 4EOD auto tranny, would look into the "CURE" for better shifting. Do a search on the Cure as some of the guys really like it. I have had two different superchips.....save a bunch of money and get a 4 position chip from Tony Wildman.....rather then waisting a bunch on others THEN going to Wildman....
Where are you located and what final drive ratio do you have, how big, heavy is your 5er.....and what tire size are you running? Depending on your EGT's when towing you may want to install an intercooler as well.
jrc
96 XLT F350 CC ZF-5 355's 16x8 aluminum rims 285/75R 16 Dick Cepek F-C IIs. T Wildman programs, Map regulator, DIY CCV & HX mod, TDS exhaust brake, BD gauges, downpipe 4" exhaust, custom SS resonator, LUK, SD I/C, Custom Shackle Reversal, Custom Moose Bar and Velvet rides, RS 9000x shocks, Custom Aluminum Drybox/fuel tank, Swamp's Baby Injectors, SD Hpop, DIY Oil by pass filtration, DIY electric fans, DIY E-Fuel system, Lighting by VisionX, LightForce and PIAA and other stuff.
http://community.webshots.com/user/jcart44
Jcart is offline
Old 03-28-2008, 10:25 AM   #4 (permalink)
My Photos: (6)
If you are happy with how it runs save your money for fuel. That being said.
With the list in my sig,
I pull my 3 horses GH with LQ (14,000 lbs) on the weekends.
I would recommend gauges. EGT, Trans temp. Don’t worry about a boost gauge in less you are upgrading injectors and a well-programmed chip. Do not get a "off the shelf programmer " The chip I got from swamps Loads the low end with torque and advances the shift points, so your not lugging the motor. The nice part about a switch able chip is you just turn the knob not loading -un loading the program.
upgrading the trans would not hert either.
97 F-250HD Super Cab 4X4
Jasper E4OD, 3.55 gears
Auto Meter Dash Mounted: Trans temp, Boost, EGT, Oil Temp, Oil Pressure.Water temp. Gauges. http://photos.thedieselstop.com/show...t=1&thecat=500
Homemade Open Air Filter, 3 in SS DP, SD, 03 Intercooler. GTS kit. Modified Pedestal, ITP SS HX, CCV Mod, BABY SWAMPS & SWAMPS 6 POS Chip, 17 Deg HPOP, Gutted EPBV, Jasper Stage 1
250,000 Miles, and still going Strong.
TSM Disk Rear Brakes
Cratos is offline
