is it possible to use a banks chip and run an edge programer? i know that the superchip programer will do this but not sure the edge will... if it is possible then how do you do it? do i have to remove the chip before the program? thanks..
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
Is that for all programers, cause I know of two people that claim to have a chip stacked with a programmer! I figured that the chip would override the programmer if the chip went second. And that the chip would be reprogrammed by the programmer if the chip was first. It sounds like a bad idea to me, since you are only capable of as much hp as your injectors and other mods will allow
-Michael
It all depends on the year and model of the truck. The 94-97 you can't stack. The superdutys can stack the juice and evo together, but not the evo and predator.
They may have the Edge Ez with a chip, but that is just an expensive 10k mod, so it really isn't a chip or programer.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
