Old 11-21-2006, 02:47 AM   #1 (permalink)
moonshiner's Avatar
Need a fuel system & Hpop
So right now I got a slight leak in my OE fuel system near the fuel bowl. I figured this would be the best time to just get a whole new fuel system. So I'm wondering whats the best system out there for under $700?
How well does the Beans reman, HPOP work? probably going to order that to, what else will I need to go along with that Hpop, and can I hook my stock Hpop up with the Reman. Beans hpop?
If it dont burn, it aint good!
1996 F250 4x4 S/C LB, 4.10, Tymar Intake, 4" Strait-Pipe, Marsh E40D, 4" Lift, 35" Pro-Comp Xtreme-Mudders on 16x8 Steelies, 190K miles, TW Chip, Rose 160cc injectors, SD CAC, D66, 2" Rear Aluminum Spacers, Dana 60 Front w/ LockRight Locker
On The List: Oil, Tank, Fuel, Lockers, Modular Flatbed
moonshiner is offline
Old 11-21-2006, 04:55 AM   #2 (permalink)
jna
Re: Need a fuel system & Hpop
get beans fuel and find a superduty hpop off ebay.
1996 F-250 POWERSTROKE , Crew Cab Short Bed, 4x4
Custom Air Ride
BDP Dominator 66
Stetcher Stealth Pump
Total Diesel Chip
150cc Swamp Babies
BDP fuel system
many[color:"blue"] TYMAR mods [/color]
TRUCK
BTS
Dana 60
2008 F-450 4x4
jna is offline
Old 11-21-2006, 11:22 AM   #3 (permalink)
So right now I got a slight leak in my OE fuel system near the fuel bowl. I figured this would be the best time to just get a whole new fuel system. So I'm wondering whats the best system out there for under $700? <font color="blue">For that $$ DYI type </font>
How well does the Beans reman, HPOP work? probably going to order that to, what else will I need to go along with that Hpop, and can I hook my stock Hpop up with the Reman. Beans hpop? <font color="blue">Only way to use your HPOP is with a Stealth </font>
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 11-21-2006, 04:45 PM   #4 (permalink)
GSXRTURBOQUAD's Avatar
Build your own fuel system, it's not that tough. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
As for an HPOP, ebay is hard to beat, unless you want duals, then check the ad's on this site for a couple Stealths. I doubt you'll see a Terminator or a BTS in the ads. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 F350 Crewcab4X4: TE Twin Turbo(BB fed by a Turbonetics TN76 from BWD), DDP BD Injectors, DIIC with custom stainless 3" piping, <span style="color: red">Terminator HPOS</span>, DI headstuds, BTS tranny, TruCool 40GVW cooler, <span style="color: blue">DP LIVE TUNED F5 with Extreme ICP!</span> , Custom fuel system, MagHytec diff cover.
01 F350 Regcab4X4: soon to be sold.
97 F350 Regcab4X4: Project(everything to make power).
02 Excursion4X4Limited: Wifes ride(stock)
<span style="color: red"> www.TerminatorEngineering.com, Proud Sponsor of the Diesel Stop.</span>
<span style="color: blue">Terminator High Pressure Oil Systems</span>
http://community.webshots.com/user/gsxrturboquad
SDRCM #7
GSXRTURBOQUAD is offline
Old 11-21-2006, 04:48 PM   #5 (permalink)
"I doubt you'll see a Terminator or a BTS in the ads."Be nice [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Clifford A.Thomas III
Dyno'd 343 hp and 685 ft.lbs. torque #2 tow setting
http://community.webshots.com/user/cliff1972
1996 F250 4x4 Reg Cab,(3rd)rebuilt engine 9/2007.DYI Stage II 170cc,stock turbo,3" dp,ARP mains,open air filter,DP Tuner F5,4 1/2" s.s. exhaust w/ Borala muffler,Joe servo IDM mod,HX MOD,stock E4OD w/ up graded valve body,TCI convertor,4.10 posi,315/75R16 BFG MT's
Waiting to install:stock 6.0 intercooler and DIY hybrid kit
Wanting to buy:head studs, Comp 910,FASS 150/180 and Modded H2E
1964 Impala 468BBC 6.98 at 98 mph in the 1/8th
1969 Nova 408BBC 6.96 at 96mph in the 1/8th
cliff-1972 is offline
Old 11-21-2006, 05:24 PM   #6 (permalink)
[img]/ubbthreads/images/graemlins/biggrin.gif[/img]Ok, I try. [img]/ubbthreads/images/graemlins/wink.gif[/img]
SDRCM #7
Old 11-21-2006, 06:04 PM   #7 (permalink)
pwrtrip's Avatar
Just couldnt help yourself could ya Joey. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
1996 crew cab 4x4 black psd
BDP 250cc hyrbids
BDP fuel system
Stealthhinator dual ipr hpop
H2E
TDP tuning
515hp 1158tq
99.5 psd reg cab 2wd
334hp 740tq
rdrcm #29
"New opinions are always suspected, and usually opposed,without any other reason but because they are not already common" John Locke
Truck and misc pics
pwrtrip is offline
Old 11-21-2006, 09:46 PM   #8 (permalink)
I just did my own fuel system the past weekend I have a cali truck so I had to remove the turbo but all in all it's about a day job all you need is 2 1/8 pipe at A 45* then you need 2 1/8 to no 6 jic also one 1/8 to male 1/8 pipe at a 90*. you also need 4 jic no6 female push lock fiting 3/8 barbe. once you start in on it you will git your own Ideas on how you want it done.
00 CC, LB, DRW, Black F350 4x4, 6 speed, lunar series Boost and EGT. DP tuner 6pos chip SBC clutch,fuel system. GTP 38R BB, by Diesel Inovations. Weld Typhoones rims, Tymar filter,CCV mod and TERMINATOR OIL.
97 CC, SB Green F250 4x4 5 speed, SBC clutch, F5 DP chip, Isspro boost, EGT.Stage II sticks, Tymar, CCV mod, TERMINATOR OIL, Banks pipe kit IC, fuel system, GTP 38R BB Turbo, Weld Typhoones
07 Dodge CTD, QCSB, Dark Gray 4x4, 6 speed, Tinted windows and a B&W hitch, MBRP 4in, AFE Stage 2 Progaurd 7, Centerline Wilderness Grizzly, Smarty CR, Quadzilla Commander, Fass 150, sbc , head studs so far a MPI twin turbo ,DDP 90hp tips also. It still smokes a little
deerezilla9620 is offline
Old 11-22-2006, 12:39 AM   #9 (permalink)
Soaggydogg's Avatar
My Photos: (11)
I doubt you'll see a Terminator in the ads.
[/ QUOTE ] I doubt you'll see $3.00 bills either.
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special
Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
Soaggydogg is offline
Old 11-22-2006, 12:42 AM   #10 (permalink)
Wow, I really like your PSD diagnostics link. That's good stuff! [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
SDRCM #7
Old 11-22-2006, 12:56 AM   #11 (permalink)
Actually, in the past year there has been more than one Terminator in the for sale section, and one BTS pump. Reason I know? Cause they were all no longer for sale when I asked about them [img]/ubbthreads/images/graemlins/frown.gif[/img] Since then, I have learned that you don't need dual hpop's to go fast [img]/ubbthreads/images/graemlins/eek.gif[/img], but if you do want one of them, then you should buy the best one on the market, which is the
'01 F-250,4x4,SC,LWB, Evans coolant/coolant filter, ATS Stage 5 tranny/torque converter, V-10 tranny cooler, 3.73 w/Detroit locker, Truetrac front, Bilstein 5100's, Auto-Meter Phantom's, 5" Hypermax exhaust
BDP
'02 F-250 4x2 CC SWB 4R100, 3.73ls(shimmed carrier), DI chip, CCV mod, 203* t-stat, coolant filter, AIH delete, Tymar HPX oil line, AIS, WW, Banks 1.0 "slowspool" housing, pedistal mod, Banks elbow&BHA, 4" turbo back w/btm, Isspro's
6.0 intercooler install(OBS)&truck pics
<span style="color: red">RDRCM #10 </span>
Sniper's credo "If you run, you'll just die tired"
richmondfarms is offline
Old 11-22-2006, 01:05 AM   #12 (permalink)
I have never seen any. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
SDRCM #7
Old 11-22-2006, 01:20 AM   #13 (permalink)
moonshiner's Avatar
ok thanks guy not really much help debating wether or not theres are darn Terminator on the ad section. How bout we figure out how do get me a fuel system for under $700 and can I put the Beans reman Hpop in-line with my OE hpop?
Deerezilla you told me about the lines and fittings, what about the actual Fuel filter and pump?
Old 11-22-2006, 01:45 AM   #14 (permalink)
You can use a Superduty fuel pump, and various styles of fuel filters. I chose the NAPA 3123 10 micron filter with the NAPA 4309 filter base/mount. Don't forget about a fuel regulator(Aeromotive from Summit Racing). [img]/ubbthreads/images/graemlins/smokin.gif[/img]
SDRCM #7
Old 11-22-2006, 11:00 AM   #15 (permalink)
Be on the lookout for an electric fuel pump for a superduty, and if you really want to get fancy the pump for a 6.0 liter has a built-in filter housing. I wouldn't try doing a homemade dual hpop, think about some hybrid injectors instead unless you want more than 500hp, there are some in the for sale section under power enhancements.
BDP
