Old 01-11-2007, 12:51 AM   #1 (permalink)
need IC install pics/write up and have questions
Well I have an early 99 intercooler (metal ends) pipes and spider pipe coming and have some general questions. One is, who has some good pics and writeups for install? I remember a good one called tims ic page but cant find it. Ive looked at gts' and some on webshots but it couldnt hurt to look at a few more.
Also do you need the heat tape on the hot side?
And what additional "stuff" will I need to make the superduty pipes work? It looks like theyd work pretty good.
Dan
1997 PSD #34 15.093 @ 88.63mph(on BDPstage1s) Beans electric fuel, FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (3" DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre turbo pyro), E4OD auto, 4.10LS, TC ind light, DIY EBPV brake w/ ind lights, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox with light, ford manual hub conv., ext trim gone.
Highest hp 362, highest tq 723 corrected onstage 1s
future mods: bigoil, 2nd fuelpump, H2E
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97's Photos
Big_Dan97 is offline
Old 01-11-2007, 01:39 AM   #3 (permalink)
Re: need IC install pics/write up and have questions
You might want to contact robs96stroker here on teh forums, he just got done installing a 6.0 cooler in his truck. I know he fabbed everything up himself, maybe he could help you out
Thanks to:
DP Tuner
ITP Diesel
Wide Open Performance
Terminator Engineering
Diesel Innovations
http://www.myspace.com/rockinjwutah
http://community.webshots.com/user/rockinjw
RockinJW is offline
Old 01-11-2007, 01:14 PM   #4 (permalink)
Nit
I have some pics and a write up in mine, TimC63 is the one your looking for his was really good, teh best tool you need is an air power jigsaw.
1997 F250 FireTruck Red,CC SB,auto( Prescion TC, HD-2Tugger),5" exhaust, custom Swamp 195cc Hybrid injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, 225,000km,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,Ramsey 15k# winch, BFG/AT 315's, F450 rear springs, home of Craig's Performance Diesel
pictures
" lying is a cheap way out of reality, the real cost is the loss of respect and trust"
dirty30
Nit is offline
Old 01-11-2007, 05:26 PM   #5 (permalink)
tjbeggs's Avatar
this is the link NIT referenced. very good write up with pics.
Thanks TIMC63!!!
1997 F-350 CC LB 4x4 Auto, AD's, Chip, IC, 4Wh. Disk Brakes, and other stuff
Truck Pics
tjbeggs is offline
Old 01-11-2007, 06:26 PM   #6 (permalink)
Briansshop's Avatar
Dan,I don't have a write-up,but have a few pics in my album that might help ya out.
Brian
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,open intake,SD IC,1.0 Housing,Pedestal Mod,Gutted EBPV,dp,5"no muff, Baumann TCS controlled e4od,"I LOVE that thing"!,Baumann VB kit,UCC Custom Billet T/C-VERY low stall speed,Mag-Hytec pan,dual True-Cools,remote filter,3 pos.T/C lock-up switch w/LED,Elec.fans on trans.& engine w/Derale adj.stats,Gauges,Kingpin D60 w/Lock Right,Detroit Locker in the 10.25,4.88s,4" Nat. springs w/ORU-SRK in fr.,crossover steering,10" Atlas springs in rear-no blocks!,Bilstein 5100s,38" PJ Dirt Grips on 16x12" M/T Classic Locks w/Centramatic balancers,Warn hubs,Powerslot rotors,Hawk pads,Can-Back canvas top.
http://s77.photobucket.com/albums/j70/Briansshop/
Just getting broken in, 50,000 miles!
Briansshop is offline
Old 01-11-2007, 08:18 PM   #7 (permalink)
Thanks for all the great links, Im gonna try to PM tim he had a really good writeup, just wish I could find it now. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
And what about the heat wrap on the hot side pipe? Need it, dont need it? That design confuses me anyways, wouldnt you want that on the cold side, cold air stay cold [img]/ubbthreads/images/graemlins/shrug.gif[/img] I know there must be a reason though.
Old 01-11-2007, 08:42 PM   #8 (permalink)
Ya don't need the heat wrap. Reading on superduty forums, it sounds like they were put on to reduce noise(whistle) from the turbo. Don't make sense to me to heat wrap a the side your trying to cool????
1994 F-250 PSD ext cab 5spd 4x4 Gutted ebpv ,Valeo smf and clutch,3 pos Tony Wildman chip!, 3-4" Dp, 4" exhaust,Tymar intake, shimmed fpr, HPX crossover, 1.0 A/R exhaust housing, vdo gauges, 279,000k
http://community.webshots.com/album/549770704UdvVUs
1996 F-250 PSD CC SB 4x4, 5spd, 4:10's SMF clutch, 3" dp, gauges, 6oh intercooler(GTS Kit), Tymar intake, HPX, .84a/r housing, 203* stat, 4pos Wildman chip!
ltfox is offline
Old 01-11-2007, 08:52 PM   #9 (permalink)
Ok so heat wrap keeps heat in, i thought it kept heat out [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] still learning [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 01-11-2007, 09:32 PM   #10 (permalink)
tjbeggs's Avatar
um well I said I posted a link to Tim's write but I forgot to paste the link sorry
here is TimC63's write up
http://members.localnet.com/~boys3/
Truck Pics
tjbeggs is offline
Old 01-12-2007, 02:40 PM   #11 (permalink)
My Photos: (32)
Hey Big Dan!
Got your PM but I see that the guys on the board already got you pointed to my page!
Good luck with the install and I hope the page is helpful! [img]/ubbthreads/images/graemlins/smile.gif[/img]
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
TimC63 is offline
