Old 09-27-2007, 08:54 PM   #1 (permalink)
Need an Intake...just called Banks holy #@&!
Well I'm trying to find someone with a cheap intake spyder to use with an intercooler. I really like the banks style but I just called them and they want 6 something just for the intake spyder [img]/forums/images/%%GRAEMLIN_URL%%/crazy.gif[/img] [img]/forums/images/%%GRAEMLIN_URL%%/crazy.gif[/img] I really dont want to spend an arm and a leg but I dont know of any one with a cheap spyder and im not having any luck finding a early 99 one.
So what are my options? I might just have to make my own.
95 Ex. Cab 4x4 Auto, Lots of Oil, Lots of Fuel, Lots of Air=Broke Truck
nycowboy is offline
Old 09-27-2007, 09:23 PM   #2 (permalink)
Tom S's Avatar
My Photos: (20)
Re: Need an Intake...just called Banks holy #@&!
I have the hot side Banks piece I was looking to sell. How much was the cold side part? I think you are getting a price for the entire pipe kit for some reason.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Tymar intake, Cowl Hood, 4" Stainless Magnaflow/Aeroturbine exhaust
14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 09-27-2007, 09:30 PM   #3 (permalink)
well i told him only the twin ram intake piece. not the tubes or ic.
I dont know what the price was for the cold and hot sides individualy he just told me $695 (i think) after i heard the 6 i was shocked n quit listening.
They dont really have any idea what they are talking about any way... they asked me if i had egr. hahaha.
nycowboy is offline
Old 09-27-2007, 10:01 PM   #4 (permalink)
PSDfreak's Avatar
couple months ago a friend on mine on this board bought the FULL PIPE kit from Banks (everything needed other than the charger itself) for just over $500 I believe...Sounds like the guy you talked to was a little off, or their prices have SKYROCKETED!
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
PSDfreak is online now
Old 09-27-2007, 10:26 PM   #5 (permalink)
It's 215.00 from banks.
95 F350 cc, 4x4, 5sp with a short shift kit, 3.55LS, D66 turbo, Beans stage 1's inj, modded ped, IDM mod ,hx mod, DPR intercooler, 3" intakes 3" dp, 4" side out, 2piller w/boost&pyro, steering column mount w/hpop gauge, TW chip, AFE stage 1, ccv mod, DIY oil & coolant filter setups, John Deere coolant eye, ORU RSK, Black Centerline wildcats w/Hankook RT03 315-75-16 mt, One day hope to have a RockDog front bumper w/8" Hellas and a CT performance rear bumper/tire carrier, 05 SD front and rear seats.
Trying to find time to install Con O clutch, 17* HPOP Swamps fuel sys, Ford rear diff cover, Blackbird rear disc brake setup.
I have two Kids and they come first...
http://community.webshots.com/user/TECH5150
TECH51 is offline
Old 09-27-2007, 10:33 PM   #6 (permalink)
ok thanks. He must have given me the price for the whole kit then.
nycowboy is offline
Old 09-28-2007, 04:46 AM   #7 (permalink)
Send a message via AIM to Bobby77ss Send a message via Yahoo to Bobby77ss
In eed that price and the part number for the spider and the pipes to a 99-03 intercooler
1996 F-350 7.3 2WD Crew Cab Dually. 128,xxx miles, 2nd owner, PO was Lead Diesel Tech @ a ford dealer with flawless maintainence records.
K&N FIPK2 Cold Air Intake - Now with Napa Paper Filter, no more sandblasting my turbo wheel!
Diesel Turbo Lifesaver
Brite Box
4" MBRP with Missing kitty, no muff and 3" downpipe
Upcoming:
EGT, Boost, Trans Temp Gauges
99-03 intercooler *acquired*
with GTS or banks install kit
CCV Mod
EBPV into DIY Jake Brake
Custom Chip
D66
Built Trans
Bobby77ss is offline
Old 09-28-2007, 11:54 AM   #8 (permalink)
BadDogPSD's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Bobby_Dezarov</div><div class="ubbcode-body">In eed that price and the part number for the spider and the pipes to a 99-03 intercooler </div></div>
Here's what you need-
25970- Banks Techni-Cooler Systerm 94-97 Ford 7.3L
25504- (delete) Banks Intercooler Assembly 94-97 Ford 7.3L
The 25970 is the entire kit (included the intercooler). The Intercooler part number is 25504. So they sell you the kit but delete the intercooler which is around $1250...
For a current price, you're best bet would be to call Banks directly and tell them what you need. 1-800-601.8072
1997 F250 4x4 Crew Cab PSD; Dana 60; Sky RSK w/SuperDuty springs.
BadDogPSD is offline
Old 09-28-2007, 12:02 PM   #9 (permalink)
mmcspadden's Avatar
If you are looking for an intake I would recommend the Tymar. Check with Cary at http://ctperformanceinc.com/index.html
1999.5 F250 PSD 4X4
Mgf. Date 07/99
http://www.mcspadden.cc/themule.html
mmcspadden is offline
Old 09-28-2007, 12:55 PM   #10 (permalink)
humm which is better banks or THIS ?
Don't RAM It STROKE IT
My
1991 f-150 with 04-07 conversion
http://www.rap3d.net/e107_plugins/au...utogallery.php
1996 F-250 Auto 4wd crewcab sb
chaunbot is offline
Old 09-28-2007, 01:20 PM   #11 (permalink)
BadDogPSD's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: chaunbot</div><div class="ubbcode-body">humm which is better banks or THIS ? </div></div>
I think they are both good kits. The Banks pipes are painted.
I've heard that GTS can take a while to get orders out. When I ordered my kit from Banks, I had it in a few days.
Old 09-28-2007, 01:41 PM   #12 (permalink)
INTERCOOLER PIPE
My
chaunbot is offline
Old 09-28-2007, 01:44 PM   #13 (permalink)
was looking at install pics, looks like a lot of work to put intercooler in : [
My
chaunbot is offline
Old 09-28-2007, 01:59 PM   #14 (permalink)
BadDogPSD's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: chaunbot</div><div class="ubbcode-body"> INTERCOOLER PIPE</div></div>
Depending on the quality, that's a decent price. The kit is for a super duty. For the obs trucks, the pipes would need to be modified...
Old 09-28-2007, 05:29 PM   #15 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: BadDogPSD</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Bobby_Dezarov</div><div class="ubbcode-body">In eed that price and the part number for the spider and the pipes to a 99-03 intercooler </div></div>
For a current price, you're best bet would be to call Banks directly and tell them what you need. 1-800-601.8072 </div></div>
Thank You for the information! And that includes brackets to mount my 99-03 IC as well?
Brite Box
Upcoming:
CCV Mod
Custom Chip
D66
Built Trans
