Need to lower EGTs..what to do? - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 04-01-2008, 04:29 PM   #16 (permalink)
gls
Amberjax,
I would start by going to a 4" exhaust cat back or other. Towing in OD is not bad unless it is going in and out 3-4 then just shift down. Mt Hood is a good pull for me and it was hitting the 1200 temp and slowing way down for the temp. A few months ago I finished putting in the intercooler. Runs way cooler and I don't have to back off. No going over 1000 now unless I realy push it and then it is no no more that 1050. I was a great way to go for me since I mostly pull with this truck.
96' F250SC, 4X4 PSD,E40D,285 Toyo M55's, 28K trans cooler,Chip, sonix, tricumulator, HX mod, Autometer in overhead console, open air filter, shimmed, 7.3 intercooler, superduty turbo, 17*,electric fuel,4" exhaust, Fumoto Valve, Bigfoot camper. 160cc DIY injectors. ATS turbo housing.
gls is offline
Old 04-01-2008, 04:57 PM   #17 (permalink)
Intercooler dropped my EGT's about 150-200 degrees. But as stated before i lost 1-2 pounds of boost.
96 F-350, Powerstroke, Auto, 6in Lift, 39.5 TSL's.
05 2500, Cummins, Stick, intake, 5 inch exhaust, FASS
Farmy22 is offline
Old 04-01-2008, 09:23 PM   #18 (permalink)
Losing pounds of boost is not a problem! The real objective is NOT pounds of boost but molecules of air entering the cylinders. Since the air that enters your cylinders is denser if cooled your probably have a net gain even though pressures are lower with the intercooler
Don in Austin.
Don in Austin, Texas '96 F250PSD Crewcab with Byron Eddins custom turbo pedestal, empty EPBV, Wildman chip, Baby Swamp 150cc injectors, Sonnax valve, Byron Eddins intercooler, 3" downpipe, 3xgauges, E40D beefed-up locally.
ISTOCK51 is offline
