Old 03-06-2006, 11:27 PM   #1 (permalink)
Need more power.. and your opinions..
We have a new to us 97 PSD that is hauling a horse trailer with a goose neck. My wife is the primary operator and she is saying it is lacking in power.. The last couple of months i've been reading all your posts and would like your opinions on my plan for more power.
I think I should do the following to help increase the power but keep it reasonable as the primary function is towing the trailer.
Gauges (Pyro, Boost, trans temp?)
intake (Tymar?)
Exhaust (Downpipe, no cat, new muffler back) please suggest supplier?
Chip 3+ position
Any idea on what HP #'s this combo might make?
Thanks for your help.
97 F350 SC 4x2 DRW E40D 4:10 All stock at the moment. gooseneck hitch for pulling 13,000lb horse trailer.
66 Mustang Convertible, Red, 302 - 340HP, too many mods too list.
RichCM is offline
Old 03-06-2006, 11:40 PM   #2 (permalink)
My Photos: (37)
Re: Need more power.. and your opinions..
you know the jist of power but i could let oyu know if you up grade the valve body, torque converter, or whole new tranny you would improve towing alot [img]/ubbthreads/images/graemlins/grin.gif[/img]
i beat the heck out of my truck and havent gotten tranny temps over 180* for well over a year now
New truck 1984 f-250 xlt ext cab. in progress
Newer truck 95 ctd
*SOLD*1997 f-250 auto, 4x4, 132,000,crewcab,remote start,relocated batteries, beans custom stage II's, beans custom 6 pos. chip, beans headstuds, 2002 intake plentums, 2002 HPOP, custom cold air intake, dual 6-in stacks, 4-in lift, 35-in MTR's, auto meter phantom gauges, (3rd) monsterbox tranny, billet input shaft, triple disk TQ, 4:10 Limited slip, snow performance water/meth injection. block painted sonic blue pearl
HP= 388 TQ= 732 w/o water/meth
1/4 mile= 14.4 @ 96mph with dp tuner 6 position chip
PICS
andrew974x4 is offline
Old 03-07-2006, 12:42 AM   #3 (permalink)
Call Dale @ Tymarperformance. He will help you out. All of that will make a big difference. A good trans kit and cooler is a must also. I pull about the same weight, it's really a load to pull. No matter what you do, it's not going to win any races. Put the horses on a diet and call Dale, you won't be sorry.
95 CCLB 4X4, DP, TYMAR, 5POS CHIP, 4",3 GUAGE POD, 115k, 265/75/16 bfg E, E4OD,4.10s,Putnams hitches front and rear,Air bags rear.
realbadlarry is offline
Old 03-07-2006, 08:22 AM   #4 (permalink)
Get ahold of Craig click here for profile he can help you out.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
Vengeance is offline
Old 03-07-2006, 01:10 PM   #5 (permalink)
Your list of modifications looks pretty good...might add gutting the EBPV unless you plan to use it as an exhaust brake. What is your gear ratio? What size tires are you running? Like someone has indicated...don't forget your transmission. You might want to upgrade your torque converter and transmission along with your horsepower upgrades. I can't give you a horsepower figure...but with your suggestions you should notice the difference [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
95 F250, 4X4, E4OD, 4.10, Hypermax DP and Tymar 4" Exhaust System, Tymar Air & Coolant Filters and HPX Kit, Tymar fuel fill mod, External Transmission Filter, Schaeffer's ATF. Add-a-leaf, Redline Differential gear oil and Redline ATF in Transfer Case. OilGuard By-pass oil filter. Schaeffer's 5W-40 in the engine. A-Pillar...Autometer Boost, Pyrometer and Trans. Temp. Gages, Under dash...Oil Pressure and Water Temperature gages, 1705 Superchip Tuner, Stancor GPR, Factory Tech Valve Body, Evans Waterless Coolant, Two 4590 Tru-Cool Transmission Cooler in series, Explorer Overhead Console, Diesel Turbo Lifesaver, Tymar Fuel Filler Mod.
Griz is offline
Old 03-07-2006, 03:33 PM   #6 (permalink)
RPM outlet has cheap exhaust- I think the 4" was $250 turbo back.
1994 F350 4x4 PSD Single Wheel Crew Cab 5spd K+N Intake 5" Exhaust with 3.5" Downtube. Just purchased (Jan 2006) driven home 1000 miles with really bad tie rods- thankful to be alive.
1994F350PSD4x4CC is offline
Old 03-07-2006, 10:12 PM   #7 (permalink)
I have the E4OD transmission with 4:10 gears, and 215/85/16 tires. This makes for a slow ride on the highway.. Will move up to 235 or 255/85/16's.
Several of you mention that the transmission needs attention.. I have been told that the torque converter is makeing noise and will need replacing soon. (in prepurchase inspection)
What is the best T/C to use for heavy pulling? Also what type of valve body or do I just Redo/buy another trans.
Thanks,
Rich.
RichCM is offline
Old 03-08-2006, 11:36 AM   #8 (permalink)
[/ QUOTE ] Which torque converter you end up with will depend a lot on the amount of horsepower your engine has/will have and how much you are towing. You might want to send NIT or Powerstroke2000 a PM and ask them for a reference to a good transmission shop in your area. I know they both had their transmissions rebuilt in the Vancouver, BC area and they are happy with theirs. Another good source of information is Dale at Tymar. He sells several torque converters and he will make recommendations based on your needs.
Griz
Griz is offline
Old 03-08-2006, 04:34 PM   #9 (permalink)
intake (Tymar?)
Chip 3+ position
Just two comments:
Gauges: Yes to pyro and boost. If you have an auto definitely get the trans temp. You will be amazed at how quickly it can get hot...put a big tranny cooler in it immediately also.
Intake: Yes to the tymar.
'97 F350 PSD E4OD CC 4x4
265/75/16, BB shim=73psi, Open Element, 10K with switch on dash, IDM mod, 30K Hayden tranny cooler, 3" downpipe, 4" straight pipe, the usual gauges, Bullydog 6 position chip. Biodiesel as much as possible.
Tankota is offline
