New downpipe touching firewall? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 11-29-2012, 06:33 PM   #1 (permalink)
Question New downpipe touching firewall?
I finally got my 4in downpipe on last night but it is touching the firewall is this okay or is it something to worrie about?? Thanks for any input you can give me!
shaneI.D.I is offline   Reply With Quote
Old 11-29-2012, 06:35 PM   #2 (permalink)
chuckster57's Avatar
It's gonna vibrate and drive you nuts!! Just bend the cab seam back a little wider than what's touching.
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote
Old 11-29-2012, 08:19 PM   #3 (permalink)
bucklee00's Avatar
^^^. And
Check the cab bushings for sag or rot
Sent from my iPhone using AutoGuide.com App
97 ccsb-7.3-zf5-4x4. WMO burner
bucklee00 is offline   Reply With Quote
Old 11-30-2012, 07:29 PM   #4 (permalink)
4" downpipe?
Snowtow is offline   Reply With Quote
Old 12-03-2012, 11:19 AM   #5 (permalink)
I used a baseball bat against the engine block to bend the seam back so my 4 incher would clear. Even so, sometimes when towing or when articulated offroad the pipe will rub. Try to insulate the backside of the pipe (cab side) or your wife will be complaining how hot the floor gets in the summer.
syjl is offline   Reply With Quote
Old 12-08-2012, 07:55 PM   #6 (permalink)
Just to reiterate the cab bushing being shot or sagging, check out the photo of my downpipe:
That hole is bigger around than a quarter and through all the way. This hole is a result of the cab rubbing the downpipe from said bad cab bushings. Yes, the seam was cut multiple times and persuaded with a concrete crowbar and ballpeen hammer. There was more than a 1/2inch clearance at the time I installed this downpipe. Another result some forget about a cab rubbing on the downpipe is collarteral damage to other parts:
That photo is the upper portion of the downpipe. You can get an idea as to the size of that rub spot based on my phat phinger. It was nearly completely through as well, the cracks were formed and beginning the burn thru. The rub is from the up-pipe. Yes sir, there is that much stress at it happens over a long, long period of time. Pipe was in the truck over 150,000 miles.
Good part is the heat shield was removed when I did the original installation and then put back in place. Difficult to do with everything in the way. However, not damaging the shield probably saved the cab from getting a burn thru onto the passengers feet.
Just something to think about in checking cab bushings....
Bret
97 F250, 4x4, ext. cab., auto, 4:10LS, Turbo back 4" Stainless Diamons Eye exhaust, Autometer Ultra-Lite gauges, TYMAR intake (the real deal), TS Chip, Dual Tensioner mod, Amsoil Dual Remote By-pass with AMS-Oiler (pre-oiler), Amsoil throughout, D60 swap, and 246K miles (still ticking)
Stong supporter of all US Troops, their families, and all waiting for a safe return. Thank you, from a former soldier and his family
Bret_B is offline   Reply With Quote
Old 12-09-2012, 11:15 PM   #7 (permalink)
bucklee00's Avatar
Your pics aren't working for me Bret. Any one else see them?
Old 12-16-2012, 02:59 PM   #8 (permalink)
bugman's Avatar
My Photos: (12)
Pictures still are not showing up.
bugman is offline   Reply With Quote
Old 12-16-2012, 11:01 PM   #9 (permalink)
Old 12-17-2012, 09:52 AM   #10 (permalink)
bugman's Avatar
My Photos: (12)
What are you trying to link to? The properties of the non exsistant photos goes to a gmail url.
Old 12-18-2012, 10:59 AM   #11 (permalink)
Bugman, the pics were in my gmail account. I copied the http out of the properties and pasted. When I preview the post, the pics show up, but when it is posted, the pics go away. I'll try uploading them another way and see what happens.
Old 12-18-2012, 11:22 AM   #12 (permalink)
If you use a "direct link" you'll need to take the HTTP// stuff out of the pop up window for inserting an image.
Old 12-18-2012, 12:20 PM   #13 (permalink)
bugman's Avatar
My Photos: (12)
If you have the pictures stored on your computer you can just upload them to the thread by clicking on the paper clip next to the smillie face. If not they need to be hosted by a site that will allow you to share them.
Old 12-21-2012, 05:38 AM   #14 (permalink)
Had my wife give me a hand with loading them this time, so lets see if it works. Even if I preview the post, I can see the pics. First pic is the rubbing from the exhaust up-pipe. Second pic is the hole that rubbed through at the cab seam.
Old 12-27-2012, 08:34 AM   #15 (permalink)
Originally Posted by Snowtow View Post
4" downpipe?
4"? I've only seen 3" down pipe that taper to a larger diameter. Where does one find a 4" (or even a 3-1/2") down pipe?
Thanks for the pics Bret_B! Any chance you have some pics with the down pipe removed that shows where it was rubbing? This may help future installers focus their clearance efforts in the correct location.
'96 F250, PSD, crew cab/short bed OBS, auto, 4x4, bone stock
LeoJr is offline   Reply With Quote
