Old 02-15-2006, 09:22 PM   #1 (permalink)
rickygasser's Avatar
New lift pump and HPOP.... No start
Hey guys,
I just installed a new lift pump (old one leaked out the weep hole) and at the same time I changed the HPOP to one off a SD. Everything went O.K. during the install (except lift pump broke off in the motor [img]/ubbthreads/images/graemlins/phoney.gif[/img] but I was still able to get it out with a pair of pliers [img]/ubbthreads/images/graemlins/smile.gif[/img]). It started after some cranking and ran rough but it eventually smoothed out. I then shut the truck off after maybe 15 min. When I went to start it again, it just turned over but wouldn't fire. I then held the schrader valve open on the FPR while my cousin cranked and it started. There was no fuel at the beginning but then it started spraying out and the truck started. I figured it was air in the system so i took it down the road a couple of times and ran it hard. When I tried starting it later, again no start unless I held the valve open. This continued all morning. Then, this afternoon, it started every time by itself [img]/ubbthreads/images/graemlins/confused.gif[/img]. What does this mean and will it do it again. I geuss I'll find out tomorrow morning.
Another thing, when I downshift from third to second, the truck wants to stall. Any thoughts on this?
'97 red PSD short box ext cab, 5 spd, 330,000 km, Wildman 4-position chip,DIY stage 1's, EBV brake, 4" lift, timbrens, DIY open air filter, Gooseneck in box, 3" DP, 5" turn-out stack
Volunteer FireFighter for 7 years
Farmer my whole life
Hers: 01 F-350 PSD, Reg cab, dark green, 2" front leveling kit, Wildman chip, Open intake, pyro and boost gauge, rolling on 315/75-16 BFG All Terrains
Fisher MM2 8'
FIL: 03 Excursion Limited, 6.0, 260 000kms, Banks monster exhaust, pyro and boost gauges. New head gaskets at 200,000kms, Arnott Air Bags
Other Toys: 2001 Mustang Bullitt Highland Green
2007 Mustang Cobra GT500 Red w/ white stripes
rickygasser is offline
Old 02-15-2006, 09:27 PM   #2 (permalink)
Re: New lift pump and HPOP.... No start
Can't commment on the stalling but as far as hard starting goes I had the same issue when I did injector O-rings. I put nearly a hundred miles on it before it would fire on initial crank, until then it would crank for roughly 3-5 seconds before starting.
96' F-350 single cab 4x4, 5-spd,205K, SB OFE, BHAF, 3"dp with 4" straight, 6-pos chip, shimmed FPR, 18K, 4.11's, Hankook RT03 35's, pyro/boost (pre-turbo), RSK. Losing in Divorce
66' Bronco, roller SEFI 351W,Explorer Serpentine,C6, Atlas, D60's, Detroit/ARB, OBA, 4-link fornt and rear, fully tubed and narrowed, 110" wb, 42's
2005 Dodge Dually CC 4x4, Cummins,6-spd, Leveling kit, BHAF, guages, CFM+, Arson CP3, Smarty TNT, 97K
tatipton is offline
Old 02-15-2006, 09:50 PM   #3 (permalink)
Thats odd i wouldn't think you would have air in your fuel system that long do you think its possibly just coincedence it started when you pushed the schraider valve when really you had air in your injector oil system cause this is what your symptoms sound like to me [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Aric
96 F-350 4x4 regularcab dually 5spd 4.10LS [color:"red"]Home made Bumper[/color]DIY open air intake hypermax dp 4" exhaust DIY exhaust brake [color:"red"]Dump bed[/color]
93 F-250 factory turbo 4x4 extended cab [color:"blue"]MyPics[/color] 4.10 5spd K&N filter ATS outler and down pipe 3in exhaust to twin 5" stacks tweaked wastegate turned up pump LUK clutch boost and pyro and much more to come[color:"blue"]Mickey Thompsons classic II 265 75 16 Courser C/T[/color]
Ford makes it IH shakes it
Don't worry about the mule just load the wagon
93turbo'd_animal is offline
Old 02-17-2006, 05:54 PM   #4 (permalink)
All right,
Has been starting ever since I made this post (exept once last night). Other than that its been starting but harder than normal (air in the system?) It has been three days now so I'm hoping it will clear up real soon.
Fisher MM2 8'
Old 02-17-2006, 10:54 PM   #5 (permalink)
well how many miles have you driven in the three days air in the HPOP can be hard to get out [img]/ubbthreads/images/graemlins/shrug.gif[/img]Is your glow plug system in good working order all that work on the top of the motor any wires maybe get unhooked or damaged [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Aric
Old 02-18-2006, 12:59 AM   #6 (permalink)
could the IPR plug or wires be loose or soaked with diesel? and id the IPR nut nice and snug? the tin one on the end. good luck, Dave
1995 f250 XL Ext Cab 4x4, auto ,3.55 gears , 317,000 miles , K&N filter , muffler Deleted ,Shimmed FPR, hypertech chip (a basic older one of unknown power) ,boost guage , small amount of leaf spring work done rest of is stock , steel wheels with hub caps , carpet delete. My old user name was Daveuz , UPDATE AS OF 11/05 new starter new waterpump LEFT ENGINE FAN OFF, new IPR new CPS replaced injector drive (used) all new under the cover harnessess and GPs and all this and my stalling problem was fixed by replacing the PCM , which I had DP Tuner flash in the 80hp econo. 12/28/05 cleaned the Cat Box UPDATE 12/06 334,000K NEW NEW NEW 11/06 1997 xlt CC LB 4x4 all white with a with topper. 285K all stock.
daveUza is offline
Old 02-18-2006, 03:05 PM   #7 (permalink)
Would that have an effect on the starting??
Fisher MM2 8'
Old 02-18-2006, 04:15 PM   #8 (permalink)
gmpt444epsd's Avatar
just my 2 cents if you want to try. over the summer i pulled my engine and to get everything primed and bleed air out i just filled the fuel bowl, and new oil in the crank case. someone on TDS told me to bleed the system of air you can disconnect the valve cover harness at all 4 connectors and jsut turn the key a few times. (dont let the starter run for more than 15-30 seconds) then reconnect the harnesses and start it. i remember i had no problems at all. it fired up first try and no hard starts after it sat. and just last weekend i pulled my hpop and had the same issue. it would take 1-2 good long cranks to get it to start. about 3 days later im back to hold the key forward for a second and it starts. i think air jsut needs to bleed out.
good luck
geoff
1995 F250 XLT 4x4 7.3L Power Stroke, 3.55LS,E40D,252K+ miles on stock engine, BANKS 3 inch downpipe, winter and summer grille cover, WARN premium hubs,40 channel CB, 2 add-a-leaves in back, NEW 33x12.50x16.50 BFG All Terrains, Pioneer DEH-2700 CD player, Hella Dual Beam Fog/Driving Lights, DeeZee bed rails, Isspro Pyrometer and Boost guages, TSC toolbox with cargo rack on top, Front Tow Hooks
gmpt444epsd is offline
