Old 11-19-2005, 12:56 AM   #1 (permalink)
New Milemarker 12k,Winch Should I wire it at 12v or 24v???
Whats the pros and cons of each way?I would think it would operate better on 24v and since we have 2 batteries,Walla 24v,Instructions say it can be wired either way
http://community.webshots.com/user/moooboy
69 Dodge Super Bee,383HP,4 speed,#'s match
70 Barracuda Gran Coupe,383hp,#'s Match
95 F250xlt,PSD,SC,LB,4X4OR,Evo,4"ex,800 watt CD,Homemade Tymar,Rancho 9000's W/ Remote,MM 12k Winch/Cradle,F@R Recievers
Suzuki Vinson 4x4 ATV
Ford 1510 Diesel tractor,4x4,loader
2006 Dodge Magnum SXT
2006 Honda VTX 1800S spec 3
AQHA QuarterHorse,1HP,Very Fast
moooboy is offline
Old 11-19-2005, 01:01 AM   #2 (permalink)
Believer45's Avatar
My Photos: (17)
Re: New Milemarker 12k,Winch Should I wire it at 12v or 24v???
In order to run both batteries to the starter they are wired parallel (+ to + and - to -). To get 24 volt you have to wire them in series, battery #1 positive to + on winch, battery #1 negative to battery #2 positive then battery #2 negative to winch to get your 24 volt. That will create a short. You cannot run them in parallel and series at the same time.
Go with 12 volt.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed manual, two wheel drive, 3.55 gears, LUK clutch conversion, 450 lb homemade REAR BUMPER, homemade open element AIR FILTER, aluminum bed cap. With me in the cab (285#) and full of fuel weighs 6,580 lbs (steer 3420 drive 3160)
Believer45 is offline
Old 11-19-2005, 01:04 AM   #3 (permalink)
My Photos: (6)
Our trucks are wired as 12 volt systems. The batteries are in parallel. The driver battery is the secondary battery and the pos cable goes to the pos post on the pass side. If it was 24 volts, the pos on one would go to the neg on the other side. I think the older diesels are 24v systems, but not the powerstrokes.
There is no way to get 24 volts out of our trucks, so you are stuck with 12v..
(whoops someone just beat me to the punch.. heh)
'95 F250 XLT 4X4 Ext Cab long bed, 5 speed, SMFW, custom kevlar LuK clutch by Superior Friction San Jose, 3.55 LSD, '88 kingpin D60, Sky RSK with SD V code springs, 175K miles, ATS 1.15 BB turbo, BDP Stage 2.5 injectors, BDP fuel system, 4 line Stealth, '02 120V IDM, ARP studs, Spearco 7.3 intercooler, 3" intakes, Northern Diesel Performance 6-pos TS chip w/TW tunes, guages, Tymar intake, EBPS bypass mod, IH bellowed uppipes, 4" DP, straight exhaust, 200PSI train horns and 215A alternator..
Home of the 94 and 95 HPOP anti bleed down mod
General Truck pictures..
radarman is offline
Old 11-19-2005, 10:53 AM   #4 (permalink)
thanks everyone
moooboy is offline
Old 11-19-2005, 08:37 PM   #5 (permalink)
There is a way to get 24 volts to the winch. Many old 18 wheelers had 24 volt starters and 12 volt everything else. You need a giant solenoid called a series/parallel switch. But I would wire it 12 volts if it were mine.
444-4D is offline
