Old 10-06-2005, 12:46 PM   #1 (permalink)
Tom S's Avatar
My Photos: (20)
New Stainless Steel HX hose available
I see that ITP has the new stainless steel cross over hose up and on the site. I have been waiting for this to come out. It does not require the rerouting of the drivers side HP hose. I was never all that happy with having to do that as it puts a semi-short bend in the hose. From what I have caught in the 99up threads they have been working out very well. You can take a look here: http://www.itpdiesel.com/store.php?c...on=show_detail
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Tymar intake, Cowl Hood, 4" Stainless Magnaflow/Aeroturbine exhaust
14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 10-06-2005, 08:21 PM   #2 (permalink)
Re: New Stainless Steel HX hose available
I've been waiting for that too..... Read carefully on weather or not you have to reroute the L hpop to head hose. I looked at the instructions that they hane posted there and realized they are 99 up instructions I think? Reroute or not still a great idea. But I have one question..... How much of the results of adding the HX hose (now line) is cuased by the natural flex or give of the walls of the hose acting as a damper? Yes I know the usual hoses are a high pressure braided stainless, but I'm sure there is some degree of flex in th sidewalls. Just a ????? for thought. I'n going for the KCM hardline.
Diesel Mechanic 28 yrs
Garbage_Mechanic is online now
Old 10-06-2005, 09:38 PM   #3 (permalink)
Tom S's Avatar
My Photos: (20)
You do not have to reroute the right hose. It taps in one port forward from where a standard HX hose does.
Tom
96 F250SC 4X4 AUTO
Tom S is offline
Old 10-06-2005, 10:47 PM   #4 (permalink)
Banned
do you think it would fit with 3" intakes and y-pipe,dual hpop and h2e? i will have to go out and look to see now.
tubzz is offline
Old 10-07-2005, 10:16 AM   #5 (permalink)
Tom S's Avatar
My Photos: (20)
I have seen a picture and it looks like it would not interfere with any of that stuff. It comes straight across the motor like a regular HX then has a bend to take it towards the front of the motor towards the port one more forward. The only thing I could see possiblly getting in the way would be some large turbo or something.
Tom
Tom S is offline
Old 10-07-2005, 11:30 AM   #6 (permalink)
Why would you need this with a Stealth [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Cary
1971 EB Hard Core Crawler
2006 Yamaha FJR1300
2005 Suzuki King Quad
caryt is offline
Old 10-08-2005, 12:37 PM   #7 (permalink)
Banned
i have kind of a choppie idle that i got after the injectors not the pumps and was told by the maker of the stealth pump to try a hx line.he sayed he put one on his truck and it help with that.
tubzz is offline
Old 10-08-2005, 09:45 PM   #8 (permalink)
The natural flex or give in a hydraulic hose might be very helpful in keeping an even pressure to all the injectors. The flexible hose can swell or contract more easily than a metal line. Both the flexible hose and the metal line will swell and act like an oil accumulator. The main difference between metal line and flexible line is the amount of accumulated oil and the rate that the accumulated oil is delivered to the system.
The metal line would provide very little accumulator effect.
The metal line would deliver it's accumulated oil at a faster rate.
The flexible line would accumulate more oil.
The flexible line would take longer to deliver it's oil to the system.
In my opinion, the flexible line will perform better than a metal line. The metal line will not provide enough accumulated oil. The metal line is too stiff to accumulate enough oil to help stabilize the pressure at the injectors.
Andrew
Original designer of the 10k mod
Original designer of the EOT mod
Original designer of the HX mod
LarryS and I were co-designers of the MAP simulator and the black box on the ICP
asmithIII is offline
Old 10-08-2005, 10:49 PM   #9 (permalink)
Tom S's Avatar
My Photos: (20)
Andrew, I am glad you looked in on this thread. For me I have to say I like the idea of not having to put the extra bend in the drivers side HP hose. I have not had a lick of trouble with it or the HX hose I got from Tymar. I just really do not like that bend in there. I take it you feel that the acumulator effect of the flex line is as beneficial as tying together the HP galleries on the two heads is?
Tom
Tom
96 F250SC 4X4 AUTO
Tom S is offline
Old 10-08-2005, 11:21 PM   #10 (permalink)
Banned
very good piont andrew,i was thinking about that today,
tubzz is offline
Old 10-09-2005, 08:17 AM   #11 (permalink)
Wolley's Avatar
I have acces to the fittings needed to make my own SS line but have held off doing it because I'm a little concerned about vibration and a rigid line. It has been my experience that rigid tubing will break if there is any high frequency vibration. If rigid tubing is the only answer then it must have expansion loops and use special flare fittings with the sleeve that extends through the fitting nut. Ferrule/compression type fittings always break where the ferrule is biting the tubing.
Was just another Whiny Chevy driver [img]/ubbthreads/images/graemlins/smile.gif[/img]
Since this is my second Ford in two years I guess I may be convert.
99 PSD CC Long Box 4WD 6spd
Southbend Con-O clutch. DVB Boost regulator, Gutted EBPV, Bilsteins all around, DIY Tymar, ATS housing, muff delete
Wildman four position chip. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Gauges of course!
Towing 2001 National Sea Breeze Fiver. 13K #
Wolley is offline
Old 10-09-2005, 08:35 AM   #12 (permalink)
Tom S, yes I feel that the accumulator effect is more beneficial but only under certain conditions.
An accumulator can store oil.
An accumulator can supply oil.
The accumulator effect is most beneficial when the instantaneous volume of oil(demand) is greater than the average output volume of oil(supply).
An injector fires for a short period of time. The injector uses it's oil in a small amount of time but the rate that an injector uses oil can be much higher than the average rate of oil delivery. The demand for oil is greater than the supply of oil.
An accumulator can store oil during the period of time when no injectors are firing. The length of time between firings is longer that the length of time the injectors actually fire. This stored oil in a flexible hose can be very helpful in keeping constant pressure to the injectors.
The proof is in the pudding, I'll have to wait and see if the metal lines are as effective as the flexible lines.
Andrew
Old 10-09-2005, 08:57 AM   #13 (permalink)
I still don't get why ya need a HX with a Stealth [img]/ubbthreads/images/graemlins/confused.gif[/img], with all the hoses that are on the pumps they are only feeding the stock head locations? You would think that the Stealth kit would feed the heads in multiple locations [img]/ubbthreads/images/graemlins/shrug.gif[/img]...guess I need to look at the Stealth pictures again.
Cary
2006 Yamaha FJR1300
caryt is offline
Old 10-09-2005, 09:29 AM   #14 (permalink)
Posts: n/a
Post deleted by JLester
Old 10-11-2005, 01:31 AM   #15 (permalink)
My Photos: (18)
I think I may belly up and give this one a try, I had to remove my HX hose from the old engine to the new one and it is leaking at the hose fittings and no amount of tightening has helped.
It seems to me that the stainless hose will still help balance and stabilize the pressure and flow. But maybe not quite as well as the flexible hose of the standard HX mod. But how much diffenece can there be between the 2?
Tim
2001 F-250 Crew Cab, short bed, 4x4, 4R100 with VB tuned by Travis's Automatic Trans, Lariat, Snugtop shell, Line-X bedliner, 265/75/R16 GY Silent Armor. DIY open element air filter. DIY 4 inch exhaust, from stock DP back to 45 degree turn down. Quadzilla Recon XZT moniter- EGT, Trans temp, Boost. DP tuner Stock, 40T, 40T high altitude, 80E, Curt MFG Q5 20K slider hitch, P3 brake controller, ATS housing. Blue Bullet
Sold-- Bright RED 1996 F350 XLT, 4X4, CC, 4.10 gears ,E40D, SRW, Rebuilt E40D at 190K with a 3yr/36K mile warrenty, by Travis's Auto Tranny 719-574-8104. Big Red
Proud Member of the NRA, helping to protect our American Rights!
New Toy: Can-Am Outlander MAX XT 650 -- AWESOME
5th wheel 2000 Dutchman 24RL with 12' slide
TCH777 is offline
