Well, while I wait for my truck to come out of the shop (F250 vs Mazda at 60mph... [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] ), I've been pretty set on some BDP Stage I's, chip, all the good stuff. Not that I haven't been before, but now I know what I want...and I want it now!
Anyways, I know I'll need a new clutch, I'm looking at the SBC Con O. $700 I'd rather not spend but I know I have to [img]/ubbthreads/images/graemlins/smile.gif[/img] My question is, can I run the stock clutch for long? I mean am I going to risk breaking anything else down there, or can I just simply wait for it to burn up and have a new one ready?
Oh also, I know the DMFW is crap and should be replaced, but what actually happens to it when it "goes out" (something I can't seem to find for the life of me)??!
Total rookie here, but I love this place. I've been reading these forums for months researching everything I can think of. I even learned all the cool terms everyone uses [img]/ubbthreads/images/graemlins/tongue.gif[/img] gotta say it took me a lot more searching on each one to figure it all out though. Took me forever just to figure out what HPOP stood for! [img]/ubbthreads/images/graemlins/frown.gif[/img]
Expect me back with more q's [img]/ubbthreads/images/graemlins/smile.gif[/img]
- Ryan
<font color="red">7.3 POWERSTROKE DIESEL</font> F-250 Flatbed 4x4 -- full info and pics inside
<font color="black">DOB 6/10/1996</font>
<font color="red">bdp</font> <font color="#8B7162">Stage I injectors and custom programs</font>
<font color="orange">SBC</font> <font color="#8B7162">Con OFE</font>
<font color="green">2002</font> <font color="#8B7162">SD HPOP</font>
285HP
Live in SoCal? Check out SoCAPS! [img]/ubbthreads/images/graemlins/grin.gif[/img]
Well, if you know for sure you are going to get the injectors, get the clutch first, cuz once you feel the power, your stocker won't last long. Unless you grenade the dmfw, your clutch will just get to where it slips so bad the truck won't move, which will take about 3-4 days after injector install if you hammer it.
The other option you have is to order the injectors and a chip and then tell them to keep the chip until you get your clutch in, that way you won't have the power available.
99.5 F-350 C/C Dually, Stealth HPOP, Full Force Diesel stroked A code injectors, Holset turbo, AEM intake.
The flywheel will begin to rattle throughout the rpm range. It will be very noticable at stop lights etc. It sounds like it wants to come through the floorboard. When you shut the truck off if will also shake "violently". It really sounds like something is coming apart.... you'll know it when you hear it. When it comes apart it can really cause some damage... ask Travis (MoreMPH).
If you are going to put injectors and a chip in it, you are definately going to need a clutch. I am going to be putting a SBC Con OFE in my truck tonight. The OFE will give you a little more insurance than the Con O, and you will need this even with the small injectors.
Craig
__________________ 2000 Ford F250 Lariat 4x4 Auto SuperCab LB PSD
2L Motorsports transmission (Precision 3 disk converter, valve body, upgraded clutches), V10 tranny cooler, TS chip, MBRP 4" exhaust, 4" to 5" tip, Auto Meter Z Series Boost, Pyro and Tranny, Poor Man's DIY intake, Boost Relief Valve, Crank Case Vent routed under truck, AIH plug
Craig
Cracked bellhousing, which pretty much trashes the tranny, as you can't replace just the bellhousing, i would just do the clutch as soon as you can.
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's Try the SEARCH Button Because It's Probably already been asked
I think a lot of people might try to talk you into the OFE, that's what I have and I'd recommend it. Not much more $ for the extra holding power, and it really drives as smooth or better than the stock clutch.
Talk to Bean about a total package, the stage I's, a chip with custom burns and your clutch, could make a package deal for you...there is no one, in my expierence, that works harder for his customers... BDP
I'm looking at Bean's 340hp mod package (Stage I's, all exhaust and intake, chip...) as my truck is completely stock. I doubt I will be putting enough power to need the OFE though? No plans for mods past these....yet
I know I need to do some sort of clutch replacement anyways. My flywheel will probably be going anytime now...no rattling or anything with it running, but I get a nice distinctive rattling/shaking sound when I shut the engine off. It's been there for about as long as I can remember having it (maybe 30k miles, it was my dad's before that, not sure if I've noticed it then or not).
- Ryan
285HP
RyanPSD, there's no one on this forum that knows what to do and how to do it any better than Bean.....this is how he earns his living. Give him a call. Even if you never do any business together, he will still help you out with good advise and recommendations....best of both worlds...
<font color="red">bdp</font> Custom Injectors
<font color="red">bdp</font> Custom Fuel systems
<font color="red">bdp</font> Custom Turbo systems Stealth Dual HPOP Systems Get Destroked W/Destroke Cummins Conversion Kits
Whatever else you may need to go fast or tow with your truck. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
95 5SPD F350 4X4 4:11LS For Sale
New Truck- 02 F350 Dually 4x CC 6spd- 05 CR Cummins Built For Pullin And Raisin Hell
I don't pull/haul anything so that was my initial reasoning for seeing how long the stock clutch would last with this setup. I doubted it would very long anyways...also why I think the Con O will be fine as opposed to the OFE.
Jim-
That's about all I've heard on these forums...definitely the first place to go, and I will [img]/ubbthreads/images/graemlins/smile.gif[/img]
Ryan-
That is _exactly_ what I am looking for. [img]/ubbthreads/images/graemlins/grin.gif[/img] You can expect a call from me in the near future. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Unfortunately I need my truck back, probably not for a few weeks still. [img]/ubbthreads/images/graemlins/depressed.gif[/img] I will keep reading up (gotten plenty of use out of that search button at the bottom) and I will return with more questions, I promise!
- Ryan
285HP
Unfortunately I need my truck back, probably not for a few weeks still. I will keep reading up (gotten plenty of use out of that search button at the bottom) and I will return with more questions, I promise!
Ryan bring on the questions, a few months back I was in your shoes, wanting to find out where my hard earned dollars would do the most good. I've been reading this forum since 2002 and it has been amazing watching the progression of knowledge passed along from the guys that have been there, done that, to all of us who are still learning...Good people here.
definately do the SMFW updrade mine took a crap un expectedly , now has an extreme vibration through entire rpm range. but it quit making the rattling sound at shut down, lol i guess it finally threw a spring or something so now my truck is down a month after i bought it plus im paying for it to sit in my driveway till i get the etra $$$$ to replace it. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
My Truck; 97'F-250 RC,2wd,ZF5-speed,POWERSTROKE.173,000 miles
Mods:Pa-2818 filter,fpr mod,Valeo SMFW conversion Dead kitty.SCMT set on tow till exhaust & gauges
Coming Soon, Down pipe, and full 4" out
