You can get a repdlacement power rear window that slides sideways. C.R. Lawrance Power Slider. Mines been working for five years with just an occasional squirt of silicone spray.
I want to use a old bronco window. I just don't know where it would go to when you put it down.
I think that depends on the body man.
'95 F250 Ported Snorkle, Foil Delete and a little more
'02 Excursion Matched Perfect and Staggered Special Total Diesel Performance Custom Tuning
Rockin S Performance BTS dealer
good-times.webshots.com/photo/2120855500037306169oDlfMF Well did you touch it?
There used to be a co that had a kit that used the stock glass. It came down in rails behind the seat. Don't know if they still make them or not. You might do a google search and find something.
Im going out of town um now (supposed to be packing) and i will look into it more when i get home. I havent even done a search yet. I figured someone would have done it here. I know someone with a bronco tailgate with window. he has two, maybe i could use the frame?
