no TQ Conv Lock up
alright went through a core tranny and put in a 95 (due to a cracked case in the origial) The core was believed to be a 96 or newer per the rough casting identifiers printed on the valvebodies indicating a 96 build year. The tranny was built and with a transgo tugger kit tuned to around 300hp and a rebuilt single disc suncoast convertor was installed
The convertor will not lockup on it's own or forced manually with a lockup switch.
The solenoid pack was acting goofy so i replaced that first with a known good 96+ pack Still no go i can here the pack clicking when the lock up switch is thrown but no lockup
Next thought rebuilt convertor was fubared... Replace that with a new HD single disc unit and still no lockup
Then i start investigating deeper, per the rough casting numbers on the new tranny case it is a 90 model case, I then pulled the valvebodies and verified this by comparing the worm tracks to my manuals it is indeed a 90 model (9 ball case) And when i recived it it had 96+ valve bodies (the pan was loose and had been off so who knows what they had done)
I reinstalled 1990 model valvebodies (and the 96 solenoid pack) and still no lockup, can here it click but no lock up
ANY IDEAS!!
Thanks Travis
SWAMP'S Extreme Powerstroke Performance
2L Motorsports
Charter Member of www.FOKISD.ORG
99 F350 ext dually 2crueL (moded somewhat)
86 F250 4x4 - C6 3.55Ls[b]
The Mule 1995 F350 CC - 4x4
95 E350 PSD 190k miles
97 F250 ext lb 160k 4x4
97 FSuperduty Plumbers Truck
93 Ranger (soon to have twinned 4bt)
My Webshots
