What is everyone doing to deal with the low sulpur diesel fuel?
I researched the archives and it seems to be all over the place. Some use oil, Some trans fluid and some use different kinds of additives. All responses seem to be fairly old.
Your thoughts are appreciated.
Terry
1997 PSD 4x4 F250 Crew Cab, Red, Auto w/Trans Cooler, DP, NAPA 6637 Air Cleaner, Cat Deleted, Autometer Gauges on Pillar, 3.55 gears, 195,000 miles, 16 to 19 MPG, 10 MPG towing 30' fifth wheel and 20' Bass Boat, Wildman 4 position chip, Fuel Heater Mod.
Full force Stage I's. Modified turbo ped, Gutted EBPV, 6.0 IC., CCV Mod.
I have been running some Wal-Mart SuperTech ash less 2 stroke oil in mine and have noticed a quieter engine along with a little bit on the mpg scale. I usually run it 1 oz to 1 gallon. I have also ran Stanadyne Performance Formula but didn't notice any difference one way or the other by running it.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter with coolant eye
I run 50/50 diesel to waste oil/tranny fluid whatever is dumped into my waste drum. filter it through a 5 micron filter from ebay and pour it right in the tank, excelent lubrication quieter engine and better fuel economy. Some even run as much as 75% oil to diesel but i don't have the balls for that. cuts my fuel bill to $2.30 a gallon. I have also run used peanut/olive/canola oil in there too. I usually only run about 3-5 gallons and fill the rest up with #2. Anymore than that and it cuts down on mileage, but hey free peanut oil is free and it burns.
96 7.3 f250 4x4 ext cab , longbed, DIY intake, 3" downpipe, Cat delete,Gutted ebpv, tw 4chip. Clean fpr screen and a shot of power service in the tank. 19 mpg on and off the foot.
Some one told me to put some atf in the fuel, put half quart in my front tank but have not drove much, said it will clean up the fuel system and lube up the motor beter, is this true? if so what would be a safe amount?
1994 F250HD, Single Cab XLT, 7.3 PSD, 5 Speed, 33in tires, level kit, South Bend ConO clutch, DP, straight piped, Tymar, ICP MOD, IDM MOD, IPR MOD, Edge, 12000lb warn, Canada made, 234000miles w/97 parts truck (can't wait to get it back to sea level!)
1994 Explorer XLT, paid only $300 and tune up and its good to go! hope the tranmission will last! 128000miles
1964 F350, 24v 5.9 Cummins not even close to broke in, New Nv4500, Turned Np205, Custom Dana 70s Front and Rear, Two 20000lb PTO winchs, 14' lift, 49" iroks!, 97 PSD acc. with wire harness swap, 87 F350 frame (still sits in shop with fresh coat of JD green paint "Built Not Bought" 0 miles,
I use this in my fuel:
BG DFC Plus
BG DFC (Diesel Fuel Conditioner) Plus combines all of the ingredients of BG DFC with DPL, Part No. 227D, plus a pour depressant/flow improver. Special pour depressant additives isolate wax crystals as they are formed during cold weather and prevent their growing together; thus, fuel flows freely at sub-zero temperatures. BG DFC Plus cleans the entire fuel system, controls engine deposit formation, improves diesel engine combustion and power, eliminates injector plunger sticking, eliminates nozzle fouling, extends injector life, reduces exhaust smoke caused by a dirty fuel system, stabilizes fuel in storage, is soluble in all diesel fuels, protects fuel system components from rust and corrosion, contains no metallic ash producing materials, and provides the necessary film strength and lubricity to low-emission diesel fuel to prevent pump parts from scoring or seizing. Catalytic converter and oxygen sensor safe. This diesel fuel additive complies with the Federal low-sulfur content requirements for use in diesel motor vehicles.
Part No. 230 32 oz. (946 mL) bottle
I know our BG rep personally and he and his crew have done a ton of tests on the Des Moines city bus fleet to test his product with incredible results.
I recommend you talk to your local BG distributor and get all the latest info and decide for yourself. My local International dealer turned me on to him when I was questioning the ultra low sulfer issue.
One thing that was discussed was adding trans fluid to our fuel. According to their research it's not doing what you want it to.
(In no way am I affiliated with BG)
I too use ashless 2 stroke oil .... varies on what is cheapest. Gander Mountain here had Citgo 2-stroke for $9.99/gal on sale. bought some and reusing the pint bottles. I just dump 1 pint per tank. I'm getting better mileage too but at $4.68/gal for fuel my driving habits have changed too. EGT's seem to be less by a couple hundred also and quieter.
