oil analysis with bypass filter - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Old 08-06-2005, 02:24 PM   #1 (permalink)
back awhile ago i was following a post about the best diy bypass filter set up. most of the people contributing seemed concerned about getting as much soot as possible out of there oil. i ended up using as fleetguard lf 9691 combination filter for my primary and a fleetguard lf 777 as a bypass. after about 7500 miles of 50/50 expressway/city driving using exxon xd-3 dino oil i sent in an oil analysis which came back saying the oil was still good and i should resample at normal change interval. the oil sample only contained 2% soot which is well below any level that you have to worry about. i was just kind of wondering if anyone else using a bypass set up knew how well there oil and engine was doing with it.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
Old 08-07-2005, 02:14 PM   #2 (permalink)
Powerstroke2000's Avatar
My Photos: (17)
Re: oil analysis with bypass filter
Hmmm...how well my engine is doing with my by-pass...I would think pretty well, as I too keep finding after an oil analysis that they tell me to continue on...and resample at the next interval!
I'm using the Amsoil version of which I've had on the truck for several years now. My first time around I ran my oil to 60K, and only changed it then because of an injector change (fuel getting into the oil).
I changed to a 5w - 30w Series 3000 Amsoil synthetic, and haven't yet sent in an oil analysis, but believe all is well.
Dale
2009 F450 Superduty King Ranch
6.4 Diesel, 4.30's.
Also, '95 Ford 7.3 diesel
My truck
Dual Idler Tensioner mod
Superduty HPOP & Mini-Me ~ Swamp Injectors
Powerstroke2000 is offline
Old 08-07-2005, 02:19 PM   #3 (permalink)
My Photos: (22)
Dale
Do yourself a favor and sample that 5w-30. Don't be surprised if you find IRON through the roof compared to your previous 15w-40/5w-40 samples. Amsoil claims this is their best oil but I have seen enough high Iron 5w-30 UOA's to laugh at that claim.
Hammer
Check out what I recently bought:
2002 Quicksilver Z06 Corvette
I still have the:
2001 F250 Lariat CC/SB 4x4 7.3 auto
TERMINATOR HPOS...Ceramic coated Garrett GTP-38R with BBHA & GDS outlet...DP-tuner Big Oil Program...ITPdiesel Fueling and overboost regulator...6.0 CAC...AFE Stage-II PG7... Magnaflow 3.5dp/4exh...5R110 TC, BTS VB, John Wood pump mods, & V10 cooler...Schaeffer's 9000 5w-40...Oilguard bypass...and other stuff
On the shelf collecting Dust: <font color="green"> Stainless Grill Overlay </font>
<font color="red"> Carolina PSD club </font>
Get Your Tuning Here: www.DP-tuner.com and your Fuel kits here: www.ITPdiesel.com
TheHammer69 is offline
