Old 01-29-2007, 11:29 PM   #1 (permalink)
Send a message via AIM to rockets10510
oil bypass installed. pics if anybody wants to see.
i put the kit together my self and i installed it a few nights and so far after bout a thousand miles of travel the oil looks almost brand new. here is wher you can view the pics at
www.bscontracting.com/images
let me know what yall think
thanks anthony
1997 Ford F350 2WD SRW White Crew cab 260,xxx miles, 4" exhaust, tymar, oil bypass changed oil at 10k, diesel site 6 pos chip. B & W turn over, coolant bypass filter.
Parts Replaced:
Water Pump 213,000 $120.00 Napa
Alternator 224,000 $64.00 Ebay
Fuel Pump 221,000 $64.60 Ebay
Radiator Core 252,000 210.00 (All Alum) Preference Radiator
1997 Ford F350 2WD SRW Green Crew cab 236,xxx miles, AFE exhaust, oil bypass, coolant filter, intercooler, 6pos Tony Wildman Chip
Parts Replaced
Fuel Pump 234,000 $65.00 Ebay
Ford Reman Trans 234,000 $2100.00
rockets10510 is offline
Old 01-30-2007, 12:03 AM   #2 (permalink)
Re: oil bypass installed. pics if anybody wants to see.
Nice job.
Looks similar to my set up except mine is mounted on the outside
of the frame under driver door and is mounted horizontally.
Cheers.
Brian. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
94 PSD. Supercab, LB. 5spd.
Autometer oil & coolant temp gauges.rancho 9000
shocks.Smitty tube step bars.Pulsetech battery
maintainer.Rhino spray on box liner.Towing mirrors.$20 exhaust brake.Inside/outside thermometer.Radio shack CB.Still a building.LUK single mass flywheel and clutch.DIY oil bypass filter.DIY air filter.
Brian Cloke is offline
Old 01-30-2007, 12:06 AM   #3 (permalink)
Fordpowrstroke73's Avatar
My Photos: (6)
Send a message via AIM to Fordpowrstroke73
Looks like a pretty good install. What exactly is the purpose of it though, is it to have a better filtration system?
'95 Ford F-350, CC,4x4, 7.3 Powerstroke,RDS Stage 1's,Tony Wildman 6 position chip,3.55LS,modded IDM(Thanks Dan),3" downpipe-5" mitre cuts,ebpv gutted, 6" tip,Napa 6637 air filter,Autometer ultra lite triple pillar gauges,Dana 60,Rancho RS 5000 schocks,E40D junk trans,,Aluminum tool box with 7 LED's, headache rack,bed protectors,Hayden Trans. Cooler,Custom Homemade SD Stainless Steel Nerf Bars,285/75/16 BFG All Terrains on Factory Alcoa's,'02 SD Intercooler with homemade IC pipes,Gooseneck hitch
Fordpowrstroke73 is offline
Old 01-30-2007, 12:23 AM   #4 (permalink)
yeah it filters down to 1 micron and gets out the carbon and other particles that the factory oil filter doesnt. it also extends oil change intervals. anthony
Parts Replaced:
Parts Replaced
Old 01-30-2007, 02:03 AM   #5 (permalink)
AlaskaRedneK's Avatar
How much did a kit like that cost?
Thanks,
-Matt
'97 F-350 CC/LB 7.3L PSD 4x4 4.10's, ~111K miles/ 3-4" Down Pipe hooked to 5" Turnout Stacks, Isspro EV Guages, Tymar, 6 pos. Northern Diesel Performance TS Chip, 7.3 IC, gutted stock fan- w/ single electric fan, Stage 3 DIY Hybrids
In the garage: RacerX Tranny kit, headstuds, 910s, pushrods
Next: New TW tunes!
AlaskaRedneK is offline
Old 01-30-2007, 03:08 AM   #6 (permalink)
what did ya use for restriction?
What befalls the oil presure?
How about a parts list?
Are you going to have your oil tested?
What do you do about anti foaming additives?
I've thought this would be a great thing to have but the price of a store bought unit is out of range right now. This might make it possible.
Sorry for all the questions but this is the life blood of our engines and any mistake could be fatal.
Black 97 F250 4x4 xc 7.3 psd E4OD 410's 97k on the clock. Wheelchair lift on back, and sometimes a Lance Camper.
mods:
ISS gauges, Home made intake, MSRP Turbo back 3" to 4", variable 10k mod with diodes.
Replaced broken parts:
GPR, 1 4x Auto lock hub, Third tail light, Fuel accumulator.
jlind is offline
Old 01-30-2007, 03:33 AM   #7 (permalink)
BDS
Looks Good! I built the same system for my 96' that I sold a few years back. I went to my local truck parts shop and got a B164 Baldwin filter and the Baldwin by-pass filter base ($25-$30). I think the filters where like $8 bucks a piece. Then I went to my local hardware shop and got all the fittings and bolts to mount it. I went to a hydraulic shop and got some hoses made up...about $50 bucks. I guess the entire kit cost me like $100 bucks. I made the mounting brkt. out of scrap.
I havn't yet built one for my Excursion or F350. [img]/ubbthreads/images/graemlins/shrug.gif[/img] Eventually!
I did a bunch of research on the Baldwin B164 filter and I'll see if I can find it and post it on here. I replaced my full flow every 5k and my bypass every 10k...I had my oil analysis done ~every 20k and it was always good.
Again, Looks Good.
Brent.
96' F350 XLT C/C PSD 4X4 LWB-Green...His, SOLD IT, Stupid Move, Found Another!
97' F350 XLT C/C PSD(for now) 4X4 LWB-White...His
01' Excursion PSD 4X4 Limited...Hers
Trucks
Sled Pull
BDS is offline
Old 01-30-2007, 11:42 AM   #8 (permalink)
Thanks,
-Matt
i put it together my self. took a little research but the whole kit cost about 50 with all parts.
Parts Replaced:
Parts Replaced
Old 01-30-2007, 11:47 AM   #9 (permalink)
i have gone as far as 7k miles with no system b4 an oil change. i dont unerstand the oil pressure question but i have not seen a drop in oil pressure. i am going to have the oil tested at 7k and see what it is at. i know i have to add anti foaming additaves but im not shure at what point i will have to do that. regardless of oil test i will change the oil at 10k if it will go that long. if it is good i might try to extend the next one till 15k if tests are good. oh i will try to put together a parts list and post it. anthony
Parts Replaced:
Parts Replaced
Old 01-30-2007, 11:50 AM   #10 (permalink)
Again, Looks Good.
Brent.
thanks where did you send your oil to get tested? and when did you add the anti foaming agent? anthony
Parts Replaced:
Parts Replaced
Old 01-30-2007, 01:13 PM   #11 (permalink)
Blackstone Labs. They are in Indiana, they are also a sponsor on here. They are super to deal with.
Todd
AKA Toad
1995 Ford F250 7.3L, auto stock 390,000mi, filler neck Mod, 3" DP with test pipe (no cat!), Fumoto oil drain valve, BDP Stage I Injectors, Tymar Intake, DB Electrical High Torque Starter
1965 Ford Mustang Fastback 289 4bbl 75,000mi
1988 Honda CRX Si 1.6L stock
1988 Honda CRX 1.5L stock
1990 Honda CRX 1.5L stock
1991 Honda CRX 1.5L stock
1998 Kawasaki Vulcan 1500 Classic
1981 Honda GL500
1995 F350 7.3L Parts Truck
stang65fst is offline
Old 01-30-2007, 05:20 PM   #12 (permalink)
is that where you also get the additive???
anthony
Parts Replaced:
Parts Replaced
Old 01-30-2007, 08:17 PM   #13 (permalink)
BDS
Anthony, I never did add any additive. I replaced the oil every 5k so the levels in my opinion where fine. Plus the analysis I would get from time to time checked out fine.... I also tried the Amsoil synthetic trending thing with the extended oil drains and after about two years...Lets just say it wasn't for me.
I switched back to SuperTech from Walmart and continued with oil analysis from Amsoils labs for another two years. They said the oil was fine and no signs of premature wear so I continued to use it. Now my Walmart never seams to have it in so I by the RotellaT.
Brent.
Trucks
Sled Pull
BDS is offline
Old 01-30-2007, 08:20 PM   #14 (permalink)
do you think it would be safe to let the oil go to 10k?
Parts Replaced:
Parts Replaced
Old 01-30-2007, 09:45 PM   #15 (permalink)
BDS
I would just take a sample at 5k and send it out to be checked. I installed a test valve on the side of the oil filter housing. I wouldn't take the sample from the pan since it most likely it will give a faulse reading. I would start it up run for about 15 min on high idle...Shut it off and open valve then the oil would come out in a more controlable fashion...Basically I'm draining it from the oil cooler housing...I've have made the driveway pretty messy a few times before I figured this way will work.
Brent.
Trucks
Sled Pull
BDS is offline
